aircraft brakes were never designed for stopping aircraft.
Old November 8th 08, 10:01 PM posted to rec.aviation.homebuilt
Alan Baker
Default aircraft brakes were never designed for stopping aircraft.
In article , "Highflyer"
"Alan Baker" wrote in message
Stealth Pilot wrote:
aircraft brakes were designed for use in holding the aircraft still
while the engine was started. after the taxy out and the engine has
warmed you do a run up check to make sure that the magneto circuits
are up to the bit of work that lies ahead for them. the brakes are
applied to hold the aircraft while the revs are bought up and each
maggy checked in turn.
from a design aspect that is the end of the use of a light aircraft's
brakes until after landing and we wish to hold the aircraft still for
shutdown and disembarkation.
of course brakes are brakes and people will use them like they were
driving cars. light aircraft brakes were never designed for slowing an
aircraft when landing.
I know that they get used for that by students of bad piloting
technique but the design intent is a fact borne out by their
diminutive size.
Stealth Pilot
Nonsense: complete and utter.
What aircraft brakes aren't designed for is stopping aircraft
*repeatedly*.
The chief advantage of putting larger brakes on any vehicle is that it
providess a greater heat sink to allow for more braking before the
brakes overheat.
Aircraft brakes need to be able to stop an aircraft *once* and then have
an essentially infinite amount of time to cool down again.
Alan Baker
Vancouver, British Columbia
http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg
Right. Almost. Maybe.....
My Stinson has 9 inch diameter drum brakes and has lots of
area on the brakes, but low pressure applied. It uses a largish
master cylinder to pump fluid into an "expander tube" under the
brake shoes inside the drum.
They work great for holding the airplane for runup and are essential
for ground handling and taxiing because the tailwheel is a swivel and in not
connected to anything that could allow it to be used for
steering. As a result, all steering is by differential braking.
You can apply the brakes on the landing roll and it will quickly slow the
airplane. However, if you do so, you may not be able to
leave the runway. Rubbing all that shoe area inside the drum makes
it quite hot inside the drum. My little infrared laser guided remote
reading thermometer gives temperatures in the 400 to 600 degree
range. It takes a while to dissipate that heat from inside the drum
and until it does the brake fluid inside the "expander tube" gets quite
warm. When it does it expands and the brakes tend to remain quite
"ON" until things cool down.
Wow. This is so wrong.
The expander tube expands because when you push on the brake pedals you
force fluid into it. If that fluid is heated, it will try to expand but
since the pressure in the system is determined by your feet on the
pedals, what will happen is that the pedals will push back on your feet.
If you don't push any harder, they will move back until the reduction in
pressure once again balances the system. If that moves the pedals all
the way back to the stops, then the orifice to the reservoir will open
and fluid will get pushed back into it.
Even a long and complicated taxi, like into a parking spot at Oshkosh, will
generally result in a noticeable loss of "differential"
in the braking activity and a substantial increase in the power
required to taxi. I have found that it is wise to NOT attempt a
takeoff if it requires over 1000 RPM to maintain a reasonable taxi
speed. :-)
Then I suggest that there is something wrong with your brakes...
Of course, this airplane weighs generally two tons and lands at 70 mph at
touchdown in a three point attitude. :-)
Ummm... What model Stinson weighs two tons? You're not claiming you fly
a Stinson Reliant, are you?
The general limiting factor in ALL aircraft brakes is heat dissipation. The
wheels are relatively small and the brakes are
in a small space. The more effective the brakes are, the more heat
they produce. All that energy they are dissipating when they slow
you down has to go somewhere. Thermodynamics tells us that most
wasted energy appears as heat! Randomized molecular activity. :-)
To stop the airplane you have to waste the energy. 1/2 M V^2.
You can't get around it.
And you don't have to. The kinetic energy of a 1,000kg light aircraft at
a landing speed of 27.8 m/s is 1/2 mv^2 = 386420 Joules
The specific heat of steel is 500 Joules per kg*K (degrees Kelvin).
So if you have two brakes weigh -- say -- 10kg each, then the rise in
temperature (dT) is
386420 = 20(dT)(500); dT = 386420/10000 = 38.64 K degrees. Even if the
brakes weigh a half of my estimate, the temperature rise is still only
77 K, or 139 F.
Fortunately, a taildragger with the flaps down and the tail on the
ground takes a LOT of energy to keep moving, so you can waste a
lot of the energy you have to get rid of by stirring up the air. Then
apply the brakes to turn off the runway after you have slowed down
without them.
Sorry, but you won't stop a Stinson in 290 feet on aerodynamic drag
alone.
FWIW Department. You scrape a lot more rubber off you tires by
landing and applying brakes vigorously while little weight is on
the wheels than you would in many many miles of taxiing around or
rolling out with the brakes off! :-)
You only scrape off much rubber if you brake close to the threshold of
adhesion.
Highflyer
Highflight Aviation Services
Pinckneyville Airport (PJY)
Alan Baker
  #52
Old November 11th 08, 12:44 AM posted to rec.aviation.homebuilt
diminutive size.
Stealth Pilot
*repeatedly*.
brakes overheat.
Alan Baker
Right. *Almost. *Maybe.....
area on the brakes, but low pressure applied. *It uses a largish
steering. *As a result, all steering is by differential braking.
airplane. *However, if you do so, you may not be able to
leave the runway. *Rubbing all that shoe area inside the drum makes
it quite hot inside the drum. * My little infrared laser guided remote
range. * It takes a while to dissipate that heat from inside the drum
warm. *When it does it expands and the brakes tend to remain quite
required to taxi. * I have found that it is wise to NOT attempt a
speed. :-)
The general limiting factor in ALL aircraft brakes is heat dissipation. *The
in a small space. *The more effective the brakes are, the more heat
they produce. * All that energy they are dissipating when they slow
you down has to go somewhere. *Thermodynamics tells us that most
wasted energy appears as heat! *Randomized molecular activity. :-)
To stop the airplane you have to waste the energy. *1/2 M V^2.
temperature (dT) is
77 K, or 139 F.
lot of the energy you have to get rid of by stirring up the air. *Then
without them.
alone.
FWIW Department. *You scrape a lot more rubber off you tires by
rolling out with the brakes off! *:-)
adhesion.
Highflyer
Alan Baker
Seems to me that the old Goodyear bladder brakes had an
expander tube and a diaphragm-type master. There was no reservoir, so
no relief hole. I think the system was filled up completely and
plugged. Any expansion of the fluid due to heat would cause some brake
drag.
As for the physics, you might have those numbers right--I
wouldn't know; I'm no physicist---but those discs are going to be much
too hot to touch. Even just maneuvering on the ramp can heat them
considerably. Shoot, just dragging them a few hundred feet while
taxiing can ruin them. I regularly see discs damaged from welding of
the semi-metallic lining due to excessive heat.
Dan
  #53
Old November 11th 08, 05:09 AM posted to rec.aviation.homebuilt
diminutive size.
Stealth Pilot
*repeatedly*.
brakes overheat.
Alan Baker
speed. :-)
At about 2300 or so RPM the Deb will happily accelerate with the
brakes locked and the tires skidding. Once it starts to skid it feels
just like it hit ice as the rubber begins to melt/vaporize.
Man, but that's fast!. :-))
The old Deb comes down final at 80 MPH minus 1 MPH for each 100 under
gross. With me and half fuel, final is about 73 MPH. touchdown?
Gotta be in the 40 MPH range. Those big flaps slow it quickly.
Course it only weighs a ton and a half so you're hauling the
equivalent of the entire useful load of the Deb on top of the Deb's
gross.:-))
Those big Cleveland's will fade if they get a lot of use, but it's
rare to ever use them that much. Even after a short field, with
maximum effort they still work. You can lock them up, but after that
the taxi gets kinda bumpy.
Steep final into the round out, firm touch down on the mains,
immediately let the nose down, get on the brakes, and go full up
elevator if the brakes will keep the nose gear down. The aerodynamic
braking with that big wing and tail is very effective giving it the
ability to stop shorter than many 172s (book figures)
I'm certainly not that proficient at present.
without them.
Highflyer
Roger (K8RI) ARRL Life Member
N833R (World's oldest Debonair)
www.rogerhalstead.com
Aircraft parts FS Cleveland Whels Brakes & Discs ! Victor Bravo Home Built 1 August 18th 07 04:00 PM
Aircraft parts FS Cleveland Whels Brakes & Discs ! Victor Bravo Aviation Marketplace 1 August 18th 07 04:00 PM
Commercial rating: complex aircraft required aircraft for practical test? Marc J. Zeitlin Piloting 22 November 24th 05 04:11 AM
Intended stopping point W.J. \(Bill\) Dean \(U.K.\). Soaring 0 February 17th 05 02:04 AM
Experience transitioning from C-172 to complex aircraft as potential first owned aircraft? Jack Allison Owning 12 June 14th 04 08:01 PM
