aircraft brakes were never designed for stopping aircraft.
Old July 19th 08, 12:54 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
Default aircraft brakes were never designed for stopping aircraft.
some interesting points came out of one guy's query re servicing some
old brake master cylinders.
gringomasloco commented regarding broken brake lines spraying brake
fluid over hot calipers and setting the wheels on fire. hmmmmm.
I am talking about light private aircraft here...
as I put it in the subject line aircraft brakes were never designed
for stopping aircraft. they were designed to hold aircraft.
now that may sound like semantic nonsense but it is true.
aircraft brakes were designed for use in holding the aircraft still
while the engine was started. after the taxy out and the engine has
warmed you do a run up check to make sure that the magneto circuits
are up to the bit of work that lies ahead for them. the brakes are
applied to hold the aircraft while the revs are bought up and each
maggy checked in turn.
from a design aspect that is the end of the use of a light aircraft's
brakes until after landing and we wish to hold the aircraft still for
shutdown and disembarkation.
of course brakes are brakes and people will use them like they were
driving cars. light aircraft brakes were never designed for slowing an
aircraft when landing.
I know that they get used for that by students of bad piloting
technique but the design intent is a fact borne out by their
diminutive size.
I'll give one concrete example. The Stinson 108 is a huge aircraft, 4
seats in 1940's luxury, yet it only has brake pucks the same size as a
5.00x5 cleveland. in fact on the one Chris M-F ownes the brakes *are*
cleveland 5.00x5 calipers.
it is quite ok to be masters of the world and fly however you like.
you'll just wear out your aeroplanes faster.
just remember though that aircraft brakes are for holding the aircraft
not stopping it.
now brakes for commercial aircraft are different and they *are* used
for stopping, but the brakes on little lighties arent.
some people have yet to realise that.
Stealth Pilot
Aircraft parts FS Cleveland Whels Brakes & Discs ! Victor Bravo Home Built 1 August 18th 07 05:00 PM
Aircraft parts FS Cleveland Whels Brakes & Discs ! Victor Bravo Aviation Marketplace 1 August 18th 07 05:00 PM
Commercial rating: complex aircraft required aircraft for practical test? Marc J. Zeitlin Piloting 22 November 24th 05 05:11 AM
Intended stopping point W.J. \(Bill\) Dean \(U.K.\). Soaring 0 February 17th 05 03:04 AM
Experience transitioning from C-172 to complex aircraft as potential first owned aircraft? Jack Allison Owning 12 June 14th 04 09:01 PM
