#61
cavelamb himself wrote: Alan Baker wrote: Not if you use wedge washers... http://www.instron.us/wa/acc_catalog...ref=http://www .google.com/search The smallest of those are 1" in dimeter. Do you think that's big enough??? Why would it matter if the SMALLEST of something is BIG ENOUGH? Surely even you are bright enough to realize that the there must logically be larger ones than the SMALLEST of something... -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
#62
Alan Baker wrote:
In article , cavelamb himself wrote: Alan Baker wrote: Not if you use wedge washers... http://www.instron.us/wa/acc_catalog...ref=http://www .google.com/search The smallest of those are 1" in dimeter. Do you think that's big enough??? Why would it matter if the SMALLEST of something is BIG ENOUGH? Surely even you are bright enough to realize that the there must logically be larger ones than the SMALLEST of something... BECAUSE WE GENERALLY USE 3/8" OR 1/2" DIAMETER BOLTS ON ENGINE MOUNTS. -- Richard (remove the X to email) |
#63
Alan Baker wrote:
In a glide in a low wing aircraft: Total aerodynamic force (lift and drag!) ^ | | M (Centre of Mass) | C (Centre of Aerodynamic Pressure) | | Weight (no down arrow head... ...sorry) It is late and I'm about to go to bed, but after seeing your force diagrams like the one above I wrote a private e-mail to the original poster with the advice that while you get many concepts correct you also appear to apply them incorrectly on occasion, so your advice should be disregarded as suspect. Nothing personal - but someone's time, money, and life are involved. Getting things wrong is pretty common - we all do it - even Nobel prize winners in physics have had their physical intuition fail them (Feynman wrote of one such case in one of his books.) Anyway, all the force diagrams you drew appear to have important errors. And for what it is worth, I have a BSc in physics and was just reviewing a textbook on basic mechanics a week ago (J. P. Den Hartog's "Mechanics" - inexpensive and worth buying by the way) but even so I would have to think the problem through carefully before attempting even a qualified answer. |
#64
cavelamb himself wrote: Alan Baker wrote: In article , cavelamb himself wrote: Alan Baker wrote: Not if you use wedge washers... http://www.instron.us/wa/acc_catalog...ref=http://www .google.com/search The smallest of those are 1" in dimeter. Do you think that's big enough??? Why would it matter if the SMALLEST of something is BIG ENOUGH? Surely even you are bright enough to realize that the there must logically be larger ones than the SMALLEST of something... BECAUSE WE GENERALLY USE 3/8" OR 1/2" DIAMETER BOLTS ON ENGINE MOUNTS. 1. Do you think this is the only supplier of wedge washers in the world? 2. Why did you ssy, "Do you think that's big enough???"? 3. You don't suppose the original poster could just design the engine mounts to accomodate the different bolt angles do you? I mean, it's not like he's building a kit or something... ....no, wait. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
#65
Alan Baker schreef:
...no, wait. No I won't. Ploink. |
#66
Jim Logajan wrote: Alan Baker wrote: In a glide in a low wing aircraft: Total aerodynamic force (lift and drag!) ^ | | M (Centre of Mass) | C (Centre of Aerodynamic Pressure) | | Weight (no down arrow head... ...sorry) It is late and I'm about to go to bed, but after seeing your force diagrams like the one above I wrote a private e-mail to the original poster with the advice that while you get many concepts correct you also appear to apply them incorrectly on occasion, so your advice should be disregarded as suspect. Nothing personal - but someone's time, money, and life are involved. Getting things wrong is pretty common - we all do it - even Nobel prize winners in physics have had their physical intuition fail them (Feynman wrote of one such case in one of his books.) Anyway, all the force diagrams you drew appear to have important errors. And for what it is worth, I have a BSc in physics and was just reviewing a textbook on basic mechanics a week ago (J. P. Den Hartog's "Mechanics" - inexpensive and worth buying by the way) but even so I would have to think the problem through carefully before attempting even a qualified answer. I'm sorry, but the problem is simple. You want the new engine configuration to behave like the old one. To achieve that, it must have the same effect on pitch as the old one. To achieve *that*, it must have the same moment arm with respect to the center of mass. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
#67
jan olieslagers wrote: Alan Baker schreef: ...no, wait. No I won't. Ploink. Suit yourself, but running from factual arguments never appears to be a good idea to me... -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
#68
#69
On Fri, 14 Nov 2008 07:25:03 -0800, Alan Baker
wrote: In article , Alan Baker wrote: In article , Stealth Pilot wrote: On Thu, 13 Nov 2008 22:20:25 -0500, wrote: How does a person determine what the proper height of an engine should be when building an airplane? If a particular engine design mandates the prop is 4 inches, say, lower than where it would be with the ----------------------------------------^^^^ engine originally installed, what effect will it have on handling, and what changes in downthrust might be advised? Draw few diagrams of the situation and you'll see what I mean. I'm not even going to try to draw that situation here. Basically, if the thrust line was already above the CoM and you move it up, then the change is smaller than the arctangent of h/l and if it was below the CoM the change is a little greater than the arctangent. Did a quick little check: As an example, a Cessna 150 is about 25 feet long and from looking at wikipedia's little jpeg, the centre of mass should be about 5 feet behind the propellor disc. So if you raise the thrust line 4 inches, you need to angle the engine up an additional 3.8 degrees; arctan(4/60). alan his corvair engine has the thrustline lower than the original O-200. so that would be down an extra 3 degrees. Stealth Pilot |
#70
On Nov 14, 2:59*pm, wrote:
On Fri, 14 Nov 2008 13:24:47 -0600, cavelamb himself Lowering the thrust line to below the center of aerodynamic drag would cause nose up - OK I get that. Now where is the center of drag on a peg? and it will DEFINETLY change with flying attitude - ie with the flaps on, or the slats extended. I guess what it boils down to is it will not be a HUGE effect. On a 28" long engine, 3 degrees is roughly 1.5" offset, so 1/4" is roughly 1/2 degree. One 1/8" washer at the firewall and one at the engine rubber on both sides will make 1/2 degree change if I need to do a bit od "fine" tuning. Spec for the O200 mount is 1.5 degrees down IIRC,amounting to .75" offset - guess I'll put in about .875 and see what happens This is all good till you consider that cowling you spent days trimming to get it to fit perfectly will now be junk. |
thrust line for engine and not mounting engine on this thrust line | tommyann | Home Built | 8 | December 15th 06 03:31 PM |
Has something changed | [email protected] | Soaring | 10 | May 3rd 05 08:34 PM |
High thrust line on canard design? | Shin Gou | Home Built | 4 | March 5th 05 03:06 AM |
Getting students to line up with the center line | BoDEAN | Piloting | 27 | April 21st 04 11:23 AM |
I want to tell you something that has changed my life! | C J Campbell | Owning | 11 | January 29th 04 11:34 PM |
