effect of changed thrust line.
Old November 16th 08, 05:11 AM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
Default effect of changed thrust line.
OK - got some more info.
The center of mass is something like 34 inches behind the firewall
and roughly 7 inches above the top engine mount point on the firewall.
so roughly speeking 13 inches above the prop centerline.
The prop flange with the O200 is 29.75 inches from the firewall.
This means it is 63.75 inches from the prop flange to the CM.(center
of mass)
This means there is NO WAY the thrust line is aligned anywhere close
to the center of mass.
This would require a downward displacement of almost 15 degrees.
THAT is not going to fly - PERIOD. We are hitting about 5.5 inches
BELOW the center of mass
If we aim for the middle of the rear stabilizer, about 183 inches from
the prop flange, 1.5 degrees down is 5.5 inches above the prop center,
which is about the middle of the rear of the fuselage and roughly 10
inches below the center of the rear horizontal stabilizer .
If I want to hit the same spot with the engine down 1.5 inches, i need
to change the angle to 1.875 degrees.
2 inches goes to 2 degrees.
2.5 inches would be 2.15 degrees, +/-
3 inches would be 2.31 degrees
4 inches would be 2.58 degrees.
Does this make any sense??
It sounds right to me.
I'd fly it.
Richard
(remove the X to email)
  #82
Old November 16th 08, 05:17 AM posted to rec.aviation.homebuilt
On Sat, 15 Nov 2008 20:32:00 -0800 (PST), guynoir
On Nov 13, 7:20Â*pm, wrote:
How does a person determine what the proper height of an engine should
be when building an airplane? If a particular engine design mandates
the prop is 4 inches, say, lower than where it would be with the
engine originally installed, what effect will it have on handling, and
what changes in downthrust might be advised?
We are building a Pegazair, and my Corvair engine would need to have
the cowl higher than ideal to keep the crank centerline at the same
hight as say, an O200. Weight wize, the engines are just about
identical as equipped Have not determined the center of gravity of the
engine yet, to determine the overall length of the mount.
For those unfamiliar with the plane it is a highwing STOL 2 placer
roughly the same size as a Cessna 150 Â*(150 sq ft wing,33 ft wingspan,
I've posted a spreadsheet to calculate a new thrust angle based on
changing the waterline location of an engine. The data needed is
horizontal distance from center of propeller to CG, original vertical
distance from center of propeller to CG, original thrust angle, and
new vertical distance from propeller center to CG. The formula is not
sensitive to vertical CG location, an estimate will do. What matters
is the change in the engine location.
http://www.spiretech.com/~guynoir/sl...downthrust.xls
Spreadsheet is not quite right.Prop center is BELOW the CG by about 13
inches.
One inch change in prop height according to your spreadsheat makes a
change of 2.14 degrees.
I cannot buy that. Particularly since it would go from 1.5 down to .64
up.
  #83
Old November 16th 08, 06:28 AM posted to rec.aviation.homebuilt
Dudley Henriques[_2_]
of mass)
I'd fly it.
You would. But you have NEVER been known for your intelligence. ))))
  #84
Old November 16th 08, 06:37 AM posted to rec.aviation.homebuilt
of mass)
I'd fly it.
Richard
  #85
Old November 16th 08, 08:26 AM posted to rec.aviation.homebuilt
There is not one right answer here.
What we are looking for is predictible and managable responses.
That's why the Cooper-Harper index exists and is written the way it is.
http://en.wikipedia.org/wiki/Cooper-Harper_rating_scale
  #87
Old November 16th 08, 07:59 PM posted to rec.aviation.homebuilt
On Sun, 16 Nov 2008 00:58:06 -0800, John Kimmel
inches.
up.
Here is REV A, with a couple math errors fixed:
http://www.spiretech.com/~guynoir/sl...thrustreva.xls
That looks a lot closer.
What is it based on?
  #88
Old November 16th 08, 10:33 PM posted to rec.aviation.homebuilt
Jim Logajan
Alan Baker wrote:
Jim Logajan wrote:
Running the thrust line through M does _not_ guarantee you wont get
any couple.
It guarantees you won't get a couple from the thrust.
I think I see one of your problems. How many forces are needed for a
couple? Can one of those forces pass through the center of mass?
  #89
Old November 16th 08, 11:29 PM posted to rec.aviation.homebuilt
Alan Baker
Jim Logajan wrote:
Alan Baker wrote:
any couple.
One. There only has to be a one force on a body in order for it to
experience to angular acceleration. That force just has to act on a line
that is not through the centre of mass.
Questions for you:
Do you believe that in the absence of any other forces, if the
aerodynamic forces act on a line that is not through the centre of mass,
will the aircraft experience angular acceleration?
If you add thrust acting through the centre of mass to the situation,
will it change the angular acceleration?
Alan Baker
Vancouver, British Columbia
http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg
  #90
Old November 16th 08, 11:33 PM posted to rec.aviation.homebuilt
Alan Baker
In article
Alan Baker wrote:
Jim Logajan wrote:
Alan Baker wrote:
any couple.
I apologize, I was using the term "couple" incorrectly.
But that doesn't matter to my argument. So ignore the first bit and
answer my questions below:
Questions for you:
Alan Baker
thrust line for engine and not mounting engine on this thrust line tommyann Home Built 8 December 15th 06 03:31 PM
Has something changed [email protected] Soaring 10 May 3rd 05 08:34 PM
High thrust line on canard design? Shin Gou Home Built 4 March 5th 05 03:06 AM
Getting students to line up with the center line BoDEAN Piloting 27 April 21st 04 11:23 AM
I want to tell you something that has changed my life! C J Campbell Owning 11 January 29th 04 11:34 PM
