Pretensioning cables
Old November 24th 08, 05:44 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
Default Pretensioning cables
Morgans wrote:
"Gig 601Xl Builder" wrote
Yep 6061T6. BUT the problem isn't showing itself in the rudder cables it
is in the ailerons.
Wood wings, or metal?
Metal... also 6061-T6
Old November 24th 08, 05:48 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
it is in the ailerons.
The 601s are all aluminum.
Zodiac designed by Chris Heinz.
Break
Gig, you better dig into that.
It sounds like something has "adjusted" it's position.
It might innocent, but you need to know for sure WHY the change.
My next door neighbor on the airport built an 601-HDS.
It looked pretty solid.
The cables just are not long enough to show any significant stretch.
Not at 40 pounds tension.
Check for a loose pivot point?
Or a bent support?
Or?
Or the cable ends! Thimbles in place?
Have they changed shape any at all?
Check the nicopress collars with a go/no go gage?
Any detectable wear in the connection tangs?
Does this airplane have the hingless aileron hinges?
(Althought I seem to think there was a pushrod to the aileron)
You are right and it could be any of those things but as I mentioned
this hasn't happened yet to my yet to be completed airplane so as I
mentioned I don't have access and the people who have mentioned the
problem SAY they don't see any problems. And you also right that there
is a short push rod between the bell crank and the aileron.
Old November 24th 08, 05:50 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
Bryan Martin wrote:
Bryan, I'd not noticed you on RAH before. You know the issue I'm asking
about. Maybe you can add something that I've left out that could help.
Old November 24th 08, 08:59 PM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
So what do we have in the cable route?
One pulley on each side???
Richard
Old November 24th 08, 10:13 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
there is a short push rod between the bell crank and the aileron.
Nope straight line from the stick to the aileron bell crank. The cable
balance side of the bell crank makes a turn through fair leads made from
some pretty tough nylon.
Old December 1st 08, 02:35 AM posted to rec.aviation.homebuilt
John[_9_]
On Nov 18, 12:33*pm, Gig 601Xl Builder
Anyone have a good method for pretensioning cables. There has been some
issues of late with 601Xl control cables getting loose after the first
few flights.
I'm looking for info on ways to pretension 1/8" galvanized cables that
are tensioned between 22 and 40 lbs.
I have been working on a well known VlJ that recently declared
bankruptcy. It is the first aircraft that I have ever worked on that
discusses pretensioning cables. Basically they tension the cables to a
figure well above nominal. Then back off and retension to nominal.
John Dupre
Old December 1st 08, 10:22 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Sun, 30 Nov 2008 18:35:29 -0800 (PST), John
few flights.
John Dupre
The humble old Cherokee 140 has an interesting pretensioned control
run ...to the ailerons I think.
the cables run from the surfaces via the usual pulleys then terminate
in sections that look for all the world like bicycle chain. these are
run up past two sprockets which are bolted together. the positions
that the sprockets are in when bolted determine the amount of cable
tension in the outer runs. past the sprockets the run to the yolk is
actually almost untensioned completely.
this allows the cables to, in effect, be used in a pretensioned state
while the yolk controls feel light and friction free.
it is a damn cunning arrangement that works superbly.
Stealth Pilot
FS: Piper Jumper Cables Video Man Aviation Marketplace 1 January 29th 07 12:27 AM
Antonov control cables John Home Built 7 October 6th 06 12:40 AM
FS: Piper Booster cables Ottprivatesale Owning 0 July 11th 06 04:36 AM
unsticking cables dlevy Owning 12 January 8th 06 09:39 AM
MiG-29 cables alcatraz Military Aviation 0 March 1st 04 10:01 PM
