unsticking cables
Old January 5th 06, 09:36 PM posted to rec.aviation.owning
Default unsticking cables
The defrost cable is stuck on my Musketeer. It's just a wire encased in
another spirally wound wire.
Any suggestions?
Old January 5th 06, 09:58 PM posted to rec.aviation.owning
Any suggestions?
Spray lube on as much of the exterior of the cable housing as you can
get to. The lube will soak into the spiral wrap, and free up the wire
core (hopefully!). This technique generally works on the older style
control cables that do not have a plastic inner lining.
Happy Flying!
Scott Skylane
N92054
Old January 6th 06, 02:44 AM posted to rec.aviation.owning
"dlevy" writes:
Any suggestions?
Is it seized or sticking? Get lube down the cable while working it.
Somewhere I saw a cable-luber. I suspect it was home made. It was
a block with one end drilled for the threaded cable fitting. The
other had a Zerk fitting. You attached the cable and used a grease
gun to FORCE grease throughout.
Not sure how well it worked and most folks want lighter, less messy
lube.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old January 6th 06, 03:01 AM posted to rec.aviation.owning
Any suggestions?
This is designed for motorcycle cables. It should work for your application.
http://www.dual-star.com/index2/Service/cable_luber.htm
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
Old January 6th 06, 03:02 PM posted to rec.aviation.owning
Would you believe I already have one (the exact one in the picture) and
hadn't thought of using it! Doh!
Thanks for clearing the cobwebs.
"George Patterson" wrote in message
news:Q3lvf.25528$z45.1048@trnddc02...
Any suggestions?
application.
George Patterson
Old January 6th 06, 04:19 PM posted to rec.aviation.owning
Any suggestions?
application.
George Patterson
I've used this product on motorcycles for years, and it is great. I
don't know about Musketeers, but it sure works on lawn mowers, cars & bikes.
Al
Old January 7th 06, 03:05 AM posted to rec.aviation.owning
George Patterson writes:
But George.... is it TSO'ed?
Old January 8th 06, 04:48 AM posted to rec.aviation.owning
Nope, but it's TSW'd. (The Sucker Works). :-)
George Patterson
Old January 6th 06, 01:00 AM posted to rec.aviation.owning
We suffered with this battle for a year with our Mooney's heater cable.
We pulled the cable out, soaked the sheeth in a bucket of goo for weeks
etc. In the end we could never de-goo it enough to make it slide
easily. Since Mooney wanted $500 for a new cable I wasn't going to
replace it. I ended up getting lucky one day and found someone willing
to sell me theirs. We never were able to de-goo the original
cable/sheeth after about a year of actively trying anything we could
think of.
-Robert
Old January 8th 06, 05:06 AM posted to rec.aviation.owning
think of.
-Robert
What about a cable housing hone? Looks like a pipe cleaner but is very long
with hard emery like brissles and hooks to a drill I know it works for
cleaning up motorcycle cable housings.
Cables for LightSpeed Plasma ignition. ELIPPSE Home Built 2 January 14th 05 04:46 AM
Best Prices on Pocket PC and Palm Cables Jim Vincent Soaring 0 April 15th 04 05:52 AM
MiG-29 cables alcatraz Military Aviation 0 March 1st 04 10:01 PM
Copper Cables Work: Update Bud Patterson Owning 0 February 15th 04 01:46 AM
Control cables for gliders mike maskell Soaring 10 January 1st 04 05:08 AM
