I stumbled across this earlier today. Below is the quote and link to picture. Although I've seen several areas with similar holes, this particular set is right next to Bastrop Bayou, near the bridge where CR 227 crosses over it. Approximate lat/long is N29.094 W95.290. Usually the holes are near a body of water: a river, stream, bayou, canal, etc. And they are always water filled. Any ideas? http://www.texas-flyer.com/LightFlyer/holes.jpg |
On Dec 24, 4:27*pm, Monk wrote:
I stumbled across this earlier today. *Below is the quote and link to picture. Although I've seen several areas with similar holes, this particular set is right next to Bastrop Bayou, near the bridge where CR 227 crosses over it. Approximate lat/long is N29.094 W95.290. Usually the holes are near a body of water: a river, stream, bayou, canal, etc. And they are always water filled. Any ideas? http://www.texas-flyer.com/LightFlyer/holes.jpg Bombing practice in earlier years ?? It is weird though.... IMHO |
On Dec 24, 5:27*pm, Monk wrote:
I stumbled across this earlier today. *Below is the quote and link to picture. Although I've seen several areas with similar holes, this particular set is right next to Bastrop Bayou, near the bridge where CR 227 crosses over it. Approximate lat/long is N29.094 W95.290. Usually the holes are near a body of water: a river, stream, bayou, canal, etc. And they are always water filled. Any ideas? http://www.texas-flyer.com/LightFlyer/holes.jpg Could be geologic sinkholes? Underlying limestone dissolves in acid- bearing water and caves in underneath? |
Monk writes:
I stumbled across this earlier today. Below is the quote and link to picture. Although I've seen several areas with similar holes, this particular set is right next to Bastrop Bayou, near the bridge where CR 227 crosses over it. Approximate lat/long is N29.094 W95.290. Usually the holes are near a body of water: a river, stream, bayou, canal, etc. And they are always water filled. Any ideas? http://www.texas-flyer.com/LightFlyer/holes.jpg Sinkholes, areas where the ground at the surface has collapsed downwards due to underground erosion or subsidence. |
On Dec 24, 6:27*pm, Monk wrote:
I stumbled across this earlier today. *Below is the quote and link to picture. Although I've seen several areas with similar holes, this particular set is right next to Bastrop Bayou, near the bridge where CR 227 crosses over it. Approximate lat/long is N29.094 W95.290. Usually the holes are near a body of water: a river, stream, bayou, canal, etc. And they are always water filled. Any ideas? http://www.texas-flyer.com/LightFlyer/holes.jpg These look remarkably like what one sees when when is culturing bacteria on a petri dish, except on a different scale. It would appear the only difference is vegetation is not growing in the 'hole' -- it seems to be defined by an absence of leaves, rather than something going on under the surface. I'd suspect some kind of leaf eating insect, or an underwater plant that deprives the floating ones of roots. If you look at growth in the deserts, you see pretty much the opposite of this -- cactii grow spaced because their roots spread out and prohibit other plants from growing nearby by depriving them of water. SInkholes would seem unlikely to affect growth on the surface. |
In article
, a wrote: On Dec 24, 6:27*pm, Monk wrote: I stumbled across this earlier today. *Below is the quote and link to picture. Although I've seen several areas with similar holes, this particular set is right next to Bastrop Bayou, near the bridge where CR 227 crosses over it. Approximate lat/long is N29.094 W95.290. Usually the holes are near a body of water: a river, stream, bayou, canal, etc. And they are always water filled. Any ideas? http://www.texas-flyer.com/LightFlyer/holes.jpg These look remarkably like what one sees when when is culturing bacteria on a petri dish, except on a different scale. It would appear the only difference is vegetation is not growing in the 'hole' -- it seems to be defined by an absence of leaves, rather than something going on under the surface. I'd suspect some kind of leaf eating insect, or an underwater plant that deprives the floating ones of roots. If you look at growth in the deserts, you see pretty much the opposite of this -- cactii grow spaced because their roots spread out and prohibit other plants from growing nearby by depriving them of water. More than that, some cactus and other desert plants secrete chemicals that actively suppress seed germination of potential competitors. SInkholes would seem unlikely to affect growth on the surface. |
On Dec 25, 12:40*pm, Steve Hix
wrote: In article , *a wrote: On Dec 24, 6:27*pm, Monk wrote: I stumbled across this earlier today. *Below is the quote and link to picture. Although I've seen several areas with similar holes, this particular set is right next to Bastrop Bayou, near the bridge where CR 227 crosses over it. Approximate lat/long is N29.094 W95.290. Usually the holes are near a body of water: a river, stream, bayou, canal, etc. And they are always water filled. Any ideas? http://www.texas-flyer.com/LightFlyer/holes.jpg These look remarkably like what one sees when when is culturing bacteria on a petri dish, except on a different scale. It would appear the only difference is vegetation is not growing *in the 'hole' -- it seems to be *defined by an absence of leaves, rather than something going on under the surface. *I'd suspect some kind of leaf eating insect, or an underwater plant that deprives the floating ones of roots. If you look at growth in the deserts, you see pretty much the opposite of this -- cactii grow spaced because their roots spread out and prohibit other plants from growing nearby by depriving them of water. More than that, some cactus and other desert plants secrete chemicals that actively suppress seed germination of potential competitors. SInkholes would seem unlikely to affect growth on the surface. Very interesting theories. Monk |
Anthony said:
Sinkholes, areas where the ground at the surface has collapsed downwards due to underground erosion or subsidence. A true genius in his own mind- so helpful and beneficent. |
I suspect the holes are abandoned oil wells from long ago. Nothing left
but the damage from bringing up the "substrate" to the surface. Limestone, oil soaked earth etc that no plant can grow in or at least is favorable to the local vegetation. That whole area around Galveston is riddled with those holes. I understand years ago that area had hundreds of oil wells in a few block area. Thats my guess! Terry "Monk" wrote in message ... I stumbled across this earlier today. Below is the quote and link to picture. Although I've seen several areas with similar holes, this particular set is right next to Bastrop Bayou, near the bridge where CR 227 crosses over it. Approximate lat/long is N29.094 W95.290. Usually the holes are near a body of water: a river, stream, bayou, canal, etc. And they are always water filled. Any ideas? http://www.texas-flyer.com/LightFlyer/holes.jpg |
Terry wrote:
I suspect the holes are abandoned oil wells from long ago. Nothing left but the damage from bringing up the "substrate" to the surface. Limestone, oil soaked earth etc that no plant can grow in or at least is favorable to the local vegetation. That whole area around Galveston is riddled with those holes. I understand years ago that area had hundreds of oil wells in a few block area. Thats my guess! Terry I disagree. I suspect that the "pilot" at the controls of the UFO that did this was a student and was practicing "touch and go's". :-) |
| Thread Tools | |
| Display Modes | |
| Covering holes | [email protected] | Soaring | 9 | May 2nd 08 06:57 PM |
| Tube Fuse Oil Holes | John[_17_] | Home Built | 8 | March 21st 08 01:11 PM |
| When Poorboys drill holes ...was: Drilling holes in steel tubing | wright1902glider | Home Built | 4 | November 4th 05 02:19 AM |
| Drilling holes in steel tubing | wright1902glider | Home Built | 20 | October 9th 05 04:43 AM |
| Filling Holes | AKperson | Owning | 1 | July 20th 05 04:54 PM |
