We are installing a PT-6 on the top or on the nose of a 747! Can't
tell you where or what company. Can you figure out why we would be doing such a thing? Doesn't a 747 go much faster than anything running a PT-6? We really don't know why this project is happening so I would appreciate hearing your guesses. Thanks, Ricky |
On Jan 16, 4:22*am, Ricky wrote:
We are installing a PT-6 on the top or on the nose of a 747! Can't tell you where or what company. Can you figure out why we would be doing such a thing? Doesn't a 747 go much faster than anything running a PT-6? We really don't know why this project is happening so I would appreciate hearing your guesses. Thanks, Ricky Your engineering team just discovered crystal meth? |
![]() "Ricky" wrote in message ... We are installing a PT-6 on the top or on the nose of a 747! Can't tell you where or what company. Can you figure out why we would be doing such a thing? Doesn't a 747 go much faster than anything running a PT-6? We really don't know why this project is happening so I would appreciate hearing your guesses. Thanks, Ricky Yes that is a strange project! Hi speed blade testing? |
Ricky
A couple of WAGs. 1. Use PT-6 turbo prop to help take offs with max gross, hot day and high altitude field. 2. Make normal 4 engine take off and at cruise altitude start PT-6 turbo prop and shut two engines down. This config would save a lot of fuel and help bottom line. 3. New version of PT-6 and 747 airframe used as test bed. Qualify another (bigger) engine for UAV use to carry heavier load. 4.Testing at high altitude for possible use on UAV . Do you know the project or just fishing for possibilities ![]() Big John ************************************************** ****** On Fri, 16 Jan 2009 01:22:29 -0800 (PST), Ricky wrote: We are installing a PT-6 on the top or on the nose of a 747! Can't tell you where or what company. Can you figure out why we would be doing such a thing? Doesn't a 747 go much faster than anything running a PT-6? We really don't know why this project is happening so I would appreciate hearing your guesses. Thanks, Ricky |
On Jan 16, 1:23*pm, Tech Support wrote:
Ricky A couple of WAGs. 1. Use PT-6 turbo prop to help take offs with max gross, hot day and high altitude field. 2. Make normal 4 engine take off and at cruise altitude start PT-6 turbo prop and shut two engines down. This config would save a lot of fuel and help bottom line. 3. New version of PT-6 and 747 airframe used as test bed. Qualify another (bigger) engine for UAV use to carry heavier load. 4.Testing at high altitude for possible use on UAV . The testbed idea sounds plausible. #2 is probably not likely due to prop's inefficiency at high mach. |
On Jan 16, 10:22*pm, Ricky wrote:
We are installing a PT-6 on the top or on the nose of a 747! Can't tell you where or what company. Can you figure out why we would be doing such a thing? Doesn't a 747 go much faster than anything running a PT-6? We really don't know why this project is happening so I would appreciate hearing your guesses. My first guess extra electrical power generation, the second high atltude tests. Cheers |
On Jan 16, 12:23*pm, Tech Support wrote:
Ricky A couple of WAGs. 1. Use PT-6 turbo prop to help take offs with max gross, hot day and high altitude field. 2. Make normal 4 engine take off and at cruise altitude start PT-6 turbo prop and shut two engines down. This config would save a lot of fuel and help bottom line. 3. New version of PT-6 and 747 airframe used as test bed. Qualify another (bigger) engine for UAV use to carry heavier load. 4.Testing at high altitude for possible use on UAV . Do you know the project or just fishing for possibilities ![]() Big John ************************************************** ****** On Fri, 16 Jan 2009 01:22:29 -0800 (PST), Ricky wrote: We are installing a PT-6 on the top or on the nose of a 747! Can't tell you where or what company. Can you figure out why we would be doing such a thing? Doesn't a 747 go much faster than anything running a PT-6? We really don't know why this project is happening so I would appreciate hearing your guesses. Thanks, Ricky- Hide quoted text - The testbed sounds plausible since this 747 is being fitted with a new, uncertified Pratt turbine engine for testing. I do know the project as last night I was doing layout on one of the doublers that wrap practically all the way around the plane aft of the cockpit. Ricky |
On Jan 17, 11:02*am, Ricky wrote:
On Jan 16, 12:23*pm, Tech Support wrote: Ricky A couple of WAGs. 1. Use PT-6 turbo prop to help take offs with max gross, hot day and high altitude field. 2. Make normal 4 engine take off and at cruise altitude start PT-6 turbo prop and shut two engines down. This config would save a lot of fuel and help bottom line. 3. New version of PT-6 and 747 airframe used as test bed. Qualify another (bigger) engine for UAV use to carry heavier load. 4.Testing at high altitude for possible use on UAV . Do you know the project or just fishing for possibilities ![]() Big John ************************************************** ****** On Fri, 16 Jan 2009 01:22:29 -0800 (PST), Ricky wrote: We are installing a PT-6 on the top or on the nose of a 747! Can't tell you where or what company. Can you figure out why we would be doing such a thing? Doesn't a 747 go much faster than anything running a PT-6? We really don't know why this project is happening so I would appreciate hearing your guesses. Thanks, Ricky- Hide quoted text - The testbed sounds plausible since this 747 is being fitted with a new, uncertified Pratt turbine engine for testing. I do know the project as last night I was doing layout on one of the doublers that wrap practically all the way around the plane aft of the cockpit. Ricky But why would they use a airplane the size of a 747 to test a PT6? Even a big PT6's power is tiny compared to the 747's thrust. Dan |
On Jan 17, 3:20*pm, wrote:
*But why would they use a airplane the size of a 747 to test a PT6? Even a big PT6's power is tiny compared to the 747's thrust. You know, Dan, that's exactly why I posted this. Although I'm working on the mod, the company I work for is hush hush about the reasoning behind what they are doing. I do know that one of the 747's engines will be replaced with another engine for testing & possible certification. I also know this short- body 747 is a bone yard rescue, very old (I was sitting in the pilot's seat during a break & everything is ancient up there), and will have several projects/modifications hanging onto it at various times. We also know that somewhere, either on the nose or directly above/ aside the lounge, there will be a PT-6 mounted. I do know that larger versions of the PT-6 (PT-6C) produce 1600-2300 shaft horse power but why a 747 mount is beyond my ability to comprehend. My thinking is that the speed of a 747 is so much faster than anything running a PT-6 that this project sounds unreasonable. There's gotta be a good reason otherwise Pratt wouldn't be spending the millions on the project they are. & I will fish around at work until I find out. Hopefully I can get a picture or two with the thing on the nose. Won't THAT look interesting?! It'll be kinda like the photo I have of a Beech Baron my dad worked on developing that had a third engine mounted on the nose. Ricky |
More_Flaps wrote:
My first guess extra electrical power generation, the second high atltude tests. Cheers Mine was as an APU for the latest pulsed beam toys. You would want the loads to be separate from any of the rest of the AC. JJ |
PRATT & WHITNEY PROPOSES F-22A ENGINE VARIANT FOR LONG-RANGE STRIKE | Mike[_7_] | Naval Aviation | 0 | May 30th 07 02:44 PM |
Was the Pratt & Whitney Double Wasp the best engine of WW II? | Dave Kearton | Aviation Photos | 18 | January 12th 07 07:20 PM |
Question Pratt & Whitney Tool ... | joseph | Restoration | 0 | October 1st 05 02:57 PM |
World War Two Era U.S. Radial Engines (Curtiss and Pratt&Whitney) | Lincoln Brown | Military Aviation | 10 | February 13th 04 04:30 AM |
