World War Two Era U.S. Radial Engines (Curtiss and Pratt&Whitney)
Old February 3rd 04, 11:35 PM
Lincoln Brown
Default World War Two Era U.S. Radial Engines (Curtiss and Pratt&Whitney)
Okay, online flightsim question time.
Did the Curtiss or P&W Radial engines rotate on a mount and spin the
propellor like their WWI predecessors or were they fixed and drove a
propellor shaft?
I've seen WWI Era fighters with the engine exposed and the cylinders spin,
but
all the WWII aircraft the engine is mostly enclosed in a cowl and not
clearly visible if the cylinders are rotating as well.
Additionally, what effect if any would flying inverted for an extended
period have on a radial engine.
Old February 4th 04, 12:20 AM
Dale
propellor shaft?
No. The engine was bolted to the airplane, the crankshaft turned with
the propellor.
That would depend on the fuel and oil system. It they are setup so as
to provide fuel and lubrication while inverted the engine won't know the
difference (half of it is upside down all the time).
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old February 4th 04, 12:29 AM
Peter Stickney
"Lincoln Brown" writes:
propellor shaft?
but
Radials, as opposed to the WW I Rotaries, are fixed, and the
crankshaft turns. Rotaries were already passing out of favor by the
end of the First World War. Improvements in construction techniques,
and in coolig fin design meant the Rotaries lost any advantage that
they had.
As for inverted flight, that would depend on the oil system of a
particular type of airplane. Radials, like their inline brethren, are
dry-sump engines - the lubricating oil is stored in a separated tank
and pumped through everything that needs it under pressure. The
limiting factor, wrt inverted flight, is the feed from the oil tank,
and cavitation in the oil pumps.
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
Old February 4th 04, 03:37 PM
M. J. Powell
In message , Peter Stickney
writes
propellor shaft?
but
they had.
Is that the same as a 'total-loss system'?
M.J.Powell
Old February 5th 04, 05:31 AM
Peter Stickney
"M. J. Powell" writes:
writes
propellor shaft?
but
they had.
Not quite. If the oil was being dumped overboard, it would be. Whar
usually happens is that the oil is returned to its sorage tank, &
pumped though again.
Although Wrights do have a reputation for using a lot of oil.
Pete Stickney
Old February 5th 04, 01:54 PM
M. J. Powell
writes
writes
propellor shaft?
but
they had.
Right. Thanks.
M.J.Powell
Old February 6th 04, 05:26 AM
writes
propellor shaft?
but
they had.
No, modern Radial and Inline a/c dry sump engines have a
collection system where the used oil is collected and pumped back
through the scavenge filters, the oil cooler then to the tank by
scavenge pumps. I believe the rotaries had a total loss system
where the oil was lost after use (but I'm not very knowledgeable
about them)
-Gord.
Old February 11th 04, 12:20 PM
Cub Driver
No. (Am I the 1,000th or 10,000th person to answer this?)
I fly a Piper Cub with a 65 hp engine, and I have been taken off the
centerline a few times by the torque. Can you imagine what the torque
is like when the engine is turning, and not just the prop? Can you
imagine what it would be like when the horsepower gets up around 900?
all the best -- Dan Ford
email:
see the Warbird's Forum at
www.warbirdforum.com
and the Piper Cub Forum at www.pipercubforum.com
Old February 11th 04, 05:29 PM
Dale
Wasn't torque that took you off the center-line, it was p-factor and
slipstream.
Dale L. Falk
Old February 11th 04, 05:43 PM
Mike Marron
slipstream.
Torque, p-factor, slipstream and gyroscopic precession are *all*
contributors to the left turning tendancies of a prop-driven aircraft.
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 11:14 PM
FS: 1996 "Aircraft Of The World: A Complete Guide" Binder Sheet Singles J.R. Sinclair Aviation Marketplace 0 July 14th 04 08:34 AM
What if the germans... Charles Gray Military Aviation 119 January 27th 04 12:20 AM
Two Years of War Stop Spam! Military Aviation 3 October 9th 03 12:05 PM
U.S. is losing the sympathy of the world John Mullen Military Aviation 149 September 22nd 03 04:42 PM
