#41
On Jan 20, 7:38*am, vontresc wrote:
On Jan 20, 9:05*am, "Paul Remde" wrote: Hi, I contacted Trig regarding the availability of their new TT21 in the USA. Their response is below. "Thank you for your interest in the TT21, the worlds smallest and lightest Mode S transponder which also features ADS-B Out by the way, at no extra cost. We probably will get certification for the TT21 for the US in April, although I should warn you that the certification process is a long one, and final approval dates are not completely in our control." I plan to sell them in the USA if possible. http://www.trig-avionics.com/tt21.html Good Soaring, Paul Remde Cumulus Soaring, Inc.http://www.cumulus-soaring.com Looks like a neat unit. Any info on the cost though??? Pete Their press releases spoke of street price expected to be around 1,300 UK Pounds, doing a simple conversion puts that at $1,800 at current rates. It does look like a nice product for installation in gliders and other small aircraft. Darryl |
#42
In Germany the call E2 TMZ (Transponder MAndatory Zone).
Robert ASW 28-18E RD brtlmj skrev: My guess is that, sooner or later, airspace class E will be split into two. E1 will be just like current E, and a transponder will be necessary to enter class E2. We could expect class E2 to be established wherever there is a high probability of encountering jet traffic. And we might find it worthwhile to actually support the change. |
#43
On Jan 20, 9:05*am, "Paul Remde" wrote: Hi, I contacted Trig regarding the availability of their new TT21 in the USA. Their response is below. "Thank you for your interest in the TT21, the worlds smallest and lightest Mode S transponder which also features ADS-B Out by the way, at no extra cost. We probably will get certification for the TT21 for the US in April, although I should warn you that the certification process is a long one, and final approval dates are not completely in our control." I plan to sell them in the USA if possible. http://www.trig-avionics.com/tt21.html Good Soaring, Paul Remde Cumulus Soaring, Inc.http://www.cumulus-soaring.com Looks like a neat unit. Any info on the cost though??? Pete- Hide quoted text - - Show quoted text - TT21 Mode S Transponder/encoder $1700 US Richard www.craggyaero.com |
#44
On Jan 20, 10:02*am, Richard wrote:
Are a dealer? There is only one US delaer listed on manufacturer's web site and I don't have a reply from them yet. Andy |
#45
help
how does a transponder assist me in not having a mid air collision with another glider ? or a light aircraft/microlight in class g airspace. |
#46
At 11:00 21 January 2009, Ian Gutsel wrote:
help how does a transponder assist me in not having a mid air collision with another glider ? or a light aircraft/microlight in class g airspace. Zaon MRX. It will alert you to the presence of another transponder in your vicinity. If the other aircraft does not have a transponder, then it is as dangerous to you as you are to it if you do not carry one. Instead of thinking about how a transponder can protect you, think about how you can protect the hundreds of people that will die should an airliner run over you. I have seen airliners below me on numerous occasions, and I am not usually able to climb above 6000'. Finally my conscience forced me to install one. The way I see it, each of us accepts the risks involved when we choose to fly. The traveling public does not, nor would they care whose fault it was if an airliner were brought down by a sailplane. It is interesting that we gladly pay $1600 for a parachute that we hope we will never need, but we can't fathom paying $2000 to install a transponder that could save hundreds of lives and will, over the course of its service life, vector many fast movers around us. |
#47
On 21 Jan 2009 11:00:05 GMT, Ian Gutsel
wrote: help how does a transponder assist me in not having a mid air collision with another glider ? or a light aircraft/microlight in class g airspace. It doesn't. It's the other aircraft's xpdr that helps you avoid a collision, but only if you were wise enough to install a PCAS also. The choice between installing an xpdr+pcas, or an xpdr+flarm, or the three of them is yours, and depends on the environment you fly in. Aldo Cernezzi |
#48
On Jan 19, 4:24*pm, Martin Gregorie
wrote: On Mon, 19 Jan 2009 10:06:40 -0800, Darryl Ramm wrote: I know nothing about UK airspace (besides being stuck in it for far too much time as a passenger holding over Heathrow), but it sounds like the existing separation of airliner and jets in UK airspace is a key point you folks should be arguing. Yes, agreed. The public will be with us on noise grounds if the commuter airlines get their way and start flying direct routes through class G airspace - this is something they can't do at present, but the CAA's transponder consultation seems designed to let them do it. And again only one of the transponder aircraft needs to be talking to ATC/radar facilities or have PCAS or higher. *I don't know PCAS (and higher-end systems) adoption in low-end GA aircraft in the UK, but in the USA it seems pretty high (purely an anecdotal impression). I've asked before but could not get adoption numbers for the USA. I've not seen figures either, but the GA density is probably lower here. There are flying schools on either side of our club field and there's no doubt that our weekend movements vastly outnumber both of theirs. In the Libelle you might be able to make up a mount for a Zaon MRX under the opaque areas of the front of the canopy. There's less space there than you might imagine. The panel is inset no more than 65mm (2.5"), so an end-on cigarette pack would not fit under in font of the panel while anything thicker would start to hide the top row instruments. It might be canted over parallel to the surface, It would have to be. If it was in the center it would interfere with the canopy lock. On the other hand, the antenna is probably not an issue - a remote one could be mounted above the instrument tray that forms the front of the panel. My GPS antenna is mounted there and gets an excellent view of the sky. I wouldn't want anything much bigger than a MH flowmeter on the cockpit wall in front of me: lets just say the cockpit is 'snug'. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | The proponents of transponders in gliders should study a recent Transportation Safety Board of Canada investigation report into a tragic mid-air collision between a Cessna 182 and a Cessa near Toronto in August 2006. Three people died in the collision. The full investigation report is available on the TSB web site at http://www.tsb.gc.ca/eng/rapports-re...6/a06o0206.asp The TSB report states: "Both aeroplanes were operating in accordance with visual flight rules in Class E airspace....Both aeroplanes were equipped with functioning transponders. C-GCHN was also equipped with a traffic information service (TIS) system that can provide a display of nearby aircraft using information provided by ground-based radar; this service is not available in Canada." A transponder can reduce the risk of collision with Traffic Collision Advisory System (TCAS) equipped aircraft, i.e. mostly air transport category aircraft. Maybe that reduction in risk is worth the cost in some places. However, as this accident shows, simply installing a transponder gives no guarantee against collision with non-TCAS equipped aircraft. Ian Grant Ottawa Canada |
#49
Hi Gang
Without belaboring it I think it has been said enough times that currently there is no single fool proof way to guaranty avoiding mid airs. Having an operating transponder, without argument, will diminish your chance of a mid air since both ATC and aircraft with TCAS or PCAS will see you. You may not see them and that is why in my world, without argument, you should also have, at the minimum, a PCAS so that you will see another aircraft with an operating transponder. A Zaon PCAS can be had for only $500 - a trivial amount when it comes to safety. I don't know why we are still discussing these issues - transponders and PCAS are mandatory safety devices in my world. I can't think of a reason why anyone would think otherwise. Dave On Jan 22, 11:35*am, wrote: On Jan 19, 4:24*pm, Martin Gregorie wrote: On Mon, 19 Jan 2009 10:06:40 -0800, Darryl Ramm wrote: I know nothing about UK airspace (besides being stuck in it for far too much time as a passenger holding over Heathrow), but it sounds like the existing separation of airliner and jets in UK airspace is a key point you folks should be arguing. Yes, agreed. The public will be with us on noise grounds if the commuter airlines get their way and start flying direct routes through class G airspace - this is something they can't do at present, but the CAA's transponder consultation seems designed to let them do it. And again only one of the transponder aircraft needs to be talking to ATC/radar facilities or have PCAS or higher. *I don't know PCAS (and higher-end systems) adoption in low-end GA aircraft in the UK, but in the USA it seems pretty high (purely an anecdotal impression). I've asked before but could not get adoption numbers for the USA. I've not seen figures either, but the GA density is probably lower here.. There are flying schools on either side of our club field and there's no doubt that our weekend movements vastly outnumber both of theirs. In the Libelle you might be able to make up a mount for a Zaon MRX under the opaque areas of the front of the canopy. There's less space there than you might imagine. The panel is inset no more than 65mm (2.5"), so an end-on cigarette pack would not fit under in font of the panel while anything thicker would start to hide the top row instruments. It might be canted over parallel to the surface, It would have to be. If it was in the center it would interfere with the canopy lock. On the other hand, the antenna is probably not an issue - a remote one could be mounted above the instrument tray that forms the front of the panel. My GPS antenna is mounted there and gets an excellent view of the sky. I wouldn't want anything much bigger than a MH flowmeter on the cockpit wall in front of me: lets just say the cockpit is 'snug'. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | The proponents of transponders in gliders should study a recent Transportation Safety Board of Canada investigation report into a tragic mid-air collision between a Cessna 182 and a Cessa near Toronto in August 2006. Three people died in the collision. The full investigation report is available on the TSB web site athttp://www.tsb.gc..ca/eng/rapports-reports/aviation/2006/a06o0206/a06o... The TSB report states: "Both aeroplanes were operating in accordance with visual flight rules in Class E airspace....Both aeroplanes were equipped with functioning transponders. C-GCHN was also equipped with a traffic information service (TIS) system that can provide a display of nearby aircraft using information provided by ground-based radar; this service is not available in Canada." A transponder can reduce the risk of collision with Traffic Collision Advisory System (TCAS) equipped aircraft, i.e. mostly air transport category aircraft. Maybe that reduction in risk is worth the cost in some places. However, as this accident shows, simply installing a transponder gives no guarantee against collision with non-TCAS equipped aircraft. Ian Grant Ottawa Canada |
| Feds Want to Equipe Gliders With Transponders and Radios | Larry Dighera | Piloting | 155 | May 10th 08 03:45 PM |
| Feds Want to Equipe Gliders With Transponders and Radios | Larry Dighera | Soaring | 12 | May 1st 08 04:42 PM |
| Feds Want to Equipe Gliders With Transponders and Radios | Alan[_6_] | Soaring | 3 | May 1st 08 04:30 PM |
| Feds Want to Equipe Gliders With Transponders and Radios | Larry Dighera | Soaring | 0 | April 28th 08 05:22 AM |
| Gliders, transponders, and MOAs | Greg Arnold | Soaring | 2 | May 26th 06 06:13 PM |
