Casting Aluminum question
Old January 29th 09, 10:47 PM posted to rec.aviation.homebuilt
Morgans[_2_]
Default Casting Aluminum question
OK, so there has been a lot of talk around here, about casting aluminum for
VW heads. It was here that I first learned that you can not use iron
crucibles for melting aluminum.
So, what if you need to cast a little job for something that does not to be
a pure aluminum part, for a non-aircraft application, where strength is not
very important? Would it be good enough?
My part is a socket (retainer) to go on top of a tractor shift lever. Think
like a donut, with the inside of the hole shaped like would be formed around
the outside of a sphere, or half of it. It has a retainer that screws down
around the outside of the part, holding the shift lever and ball around it,
down onto the transmission.
I believe the metal part that needs to be replaced is/was made out of what
is usually called "pot metal." What the heck is that, anyway?
So, what do you all think? Contamination from a cast iron crucible OK for
this part?
Jim in NC
Old January 29th 09, 11:57 PM posted to rec.aviation.homebuilt
Charles Vincent
this part?
Lots of people cast aluminum using steel pots. I don't -- but I spent
the money on a selection of graphite crucibles long ago and a big
carbide one as well. The steel "crucibles" will eventually fail with a
burn through (so will graphite for that matter , but there is a very
different event horizon).
Pot metal is generally some zinc alloy, like zamac. Decent strength,
easy pour, given to corrosion. Atlas used to make a lot of chrome
plated die-cast zamac parts for their tools, especially their lathe,
which they marketed directly and through Sears & Roebuck. When you
buy an old Atlas lathe, you have to make sure the gears, handles and
other Zamac doodads don't crumble. Sometimes it almost seems like the
chrome is filled with sand.
Seems to me I saw plans for a cupola furnace made out of flower pots
years ago and fired with BBQ briquettes -- no crucible required. Then
again, flower pots can be deadly too.
Charles
Old January 30th 09, 12:00 AM posted to rec.aviation.homebuilt
Maxwell[_2_]
"Morgans" wrote in message
for VW heads. It was here that I first learned that you can not use iron
be a pure aluminum part, for a non-aircraft application, where strength is
not very important? Would it be good enough?
Think like a donut, with the inside of the hole shaped like would be
formed around the outside of a sphere, or half of it. It has a retainer
that screws down around the outside of the part, holding the shift lever
and ball around it, down onto the transmission.
this part?
Jim in NC
Iron pots or crucibles are often used for melting aluminum. Coat it with a
clay or graphite slurry before each use for best results. Steel will work,
but will not last as long as iron, and coating is a must. Molten aluminum is
very corrosive to clean steel. Rust or blasting will help a clay based wash
adhere to steel or iron, where cast iron is usually rough enough as cast. I
personally prefer to allow new steel ladles to rust outside, then coat
regularly with a graphic based wash. I have never personally used cast iron.
All my crucibles are silicone carbide.
Drying is not terribly important after a wash if you are starting with cold
metal. The time and heat required to melt aluminum will dry the pot or
crucible long before you see molten metal. But if you are coating a ladle to
dip molten aluminum, adequate drying it's an absolute must.
Pot metal is usually just slang for die cast aluminum with high zinc
content. It makes it very difficult, if not impossible to weld, but I'm told
it flows well in high production die casting.
Casting Four Individual VW Heads [email protected] Home Built 23 January 21st 09 11:07 PM
CASTING CALL! [email protected] Home Built 11 January 21st 09 04:51 PM
casting intricate finned heads Stealth Pilot[_2_] Home Built 13 January 16th 09 02:35 AM
misdrilled hole on on tubular aluminum spar question patrick mitchel Home Built 12 October 2nd 06 08:17 PM
Tech: Aluminum Forming Question Scott Rodriguez Home Built 5 March 15th 06 04:42 AM
