Moving a glider with a U-Haul Truck
Old February 7th 09, 11:27 PM posted to rec.aviation.soaring
ericrupp@got.net
Default Moving a glider with a U-Haul Truck
Does anybody have any experience moving a Standard/15m class sailplane
with a U-Haul truck or similar?
I see this as an option for self-retrieving from a *long* straight out
XC flight -- no-crew and no returning home to get your trailer (and
then back to the glider and back home -- makes me tired just talking
about it...)
I'm thinking you could do this with a bare, box truck (say a 26' long
U-Haul) with ONLY ratchet tie-down straps and some pads (i.e., stuff
available anywhere). This includes the fueslage and wings. With a
loading ramp I figure you could do it with one helper.
Has anyone tried this?
Eric
ER
Old February 8th 09, 01:15 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
Dave Noyes did it with a Ventus CM, I believe. There was an article about
it in SOARING. Even had pictures of the glider in the trailer. Wing tips
stuck up into the overhead area, often refered to on the side of the truck
as "Mom's Attic".
It can be done, but I understand one way rental and drop-off charges can
be rather high. Best is with a crew and share the adventure. Return the
favor, and have a blast doing it.
Steve
Old February 8th 09, 09:15 AM posted to rec.aviation.soaring
Pete Startup[_2_]
WHY? - the clues in the name.
Old February 8th 09, 02:00 PM posted to rec.aviation.soaring
ulineumann@aol.com
about it...)
available anywhere). *This includes the fueslage and wings. *With a
Eric
ER
It may be possibel to do it but one would need a lot of cushioning
material. Keep in mind that a 26' U-Haul truck is meant to haul a few
tons of cargo and therefore has a suspension that is designed
accordingly. Putting a few hundred pounds worth of glider in the back
will not even deflect the springs resulting in a very rough ride.
Soaring is supposed to be a team sport where you retrieve your buddies
and they will return the favor and get you. It is part of the fun!
Uli Neumann
Old February 8th 09, 08:05 PM posted to rec.aviation.soaring
BT
I remember reading about a cross country trip that started some where in the
Central US.. Ohio?
and ended on the Eastern Massachusetts coast..
That would be a long way to motor back west bound.
And a long way to go west, retrieve the trailer and drive east and west
again.
BT
"Pete Startup" wrote in message
Old February 8th 09, 10:15 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
the Central US.. Ohio?
again.
BT
David Noyes, Ventus CM. Takeoff: Marion, Ohio. Official start: Galion,
Ohio. Landing: Plymouth, Massachusetts. Written up in the January 1995
issue of SOARING. Aritcle titled "Straight out to Cape Cod".
One simple quote from the article about trucking back. "If you're evr
tempted to duplicate this trick, rent at least three dozen pads and have
lots of rope." There is one picture of the plane loaded in the trailer.
I know someone that made his straight out flight, secured the plane,
hopped on Greyhound to get home, then drove down with the trailer to get
his ship back. Now that I think of it, I know of at least two people that
have done that. It is much simpler to have a crew.
Steve
Old February 9th 09, 05:54 AM posted to rec.aviation.soaring
ericrupp@got.net
Eric Greenwell wrote...
What kind of flight are you considering, and from where to where?
Hollister (San Francisco Bay Area) to Phoenix or Tucson would be a
fine flight. Maybe even on to Texas, glider port to glider port in a
few to several hops. My DG-300 seems to think it's doable...
I've been fortunate to have a crew for some of my straight-outs. But
sometimes the weather gods say you've got to go NOW and that can it
hard to pull the team together.
Eric
Old February 9th 09, 02:00 PM posted to rec.aviation.soaring
Jim Beckman[_2_]
that
And if you're such a social misfit that you can't get anybody to crew
for you, just *hire* somebody to drive the trailer rig. Gotta be cheaper
than the U-Haul idea. And takes a lot less time.
Jim Beckman
Old February 9th 09, 02:50 PM posted to rec.aviation.soaring
unclhank@ix.netcom.com
about it...)
Eric
ER
The hours you save on the retreive will likely be exceeded by the hour
needed to fix the damage you will likely do to the glider.
Find a friend.
Good luck and don't let this keep you from trying that great flight.
UH
Moving a glider to Europe connekt Soaring 1 September 1st 07 07:19 PM
truck + 5th wheel RV + glider trailer ?? Steve Koerner Soaring 16 March 27th 07 03:44 AM
Glider Haul from Houston, Texas to Albany, New York Tim Hanke Soaring 0 April 13th 06 01:30 AM
Wanted: Glider Haul from Ephrata, WA to Albany, NY Tim Hanke Soaring 1 January 9th 06 12:57 PM
glider haul available, SJC->MEV ken ward Soaring 0 April 14th 04 02:05 AM
