#11
Andy wrote:
On Feb 19, 10:25 am, wrote: Hate external antennas on Composite aircraft. Having worked on a lot of homebuilts, thought someone else might have come up with an alternative mount. I won't help solve your problem but I noted that the Schleicher ASH31Mi will have a transponder antenna mounted inside the fin as standard equipment. Andy This is interesting as it will probably require some large coax to keep the antenna loss to less than 1.5 db which is what was recommended in the microair transponder install manual I have. The RG-58 is limited to 10 ft of coax length and that sure isn't going to get you to the fin from the instrument panel... |
A transponder, such as the Trig Avionics TT21, that has the operating panel
separate from the transmitter/receiver box, will allow the transmitter/receiver to be installed behind the pilot and thus considerably reduce the required cable length (and hence losses) to a tail-fin antenna. At 03:10 20 February 2009, Gary Emerson wrote: Andy wrote: This is interesting as it will probably require some large coax to keep the antenna loss to less than 1.5 db which is what was recommended in the microair transponder install manual I have. The RG-58 is limited to 10 ft of coax length and that sure isn't going to get you to the fin from the instrument panel... |
On Feb 20, 7:00*am, Big Wings wrote:
A transponder, such as the Trig Avionics TT21, that has the operating panel separate from the transmitter/receiver box, will allow the transmitter/receiver to be installed behind the pilot and thus considerably reduce the required cable length (and hence losses) to a tail-fin antenna. * At 03:10 20 February 2009, Gary Emerson wrote: Andy wrote: This is interesting as it will probably require some large coax to keep the antenna loss to less than 1.5 db which is what was recommended in the microair transponder install manual I have. *The RG-58 is limited to 10 ft of coax length and that sure isn't going to get you to the fin from the instrument panel... I was about to suggest the same thing. In the ASH-26E/ASH-31Mi fuselage there is a likely location to mount the RF unit in the just behind the engine. With access though a nice large opening provided originally for a barograph and now often used for storage. In that location it should be possible for the factory to relatively easily install something as large as RG-6 or similar cable (~5dB/100' vs. ~14 dB/100' for RG-58). Doing this also ensures that RF coax is not going up to the transponder mounted on the panel and going though a wiring harness that is flexing as the canopy is raised and lowered. And I don't know about others but Becker head units use differential signaling and long cable runs between the head unit and RF unit should not be a problem. Another option would be to join some thick coax to RG-58 under he cockpit floor to handle the transition to the panel, and although the insertion loss of that connection might be 0.1 dB or so on paper I'd want to avoid it. Routing say RJ-6 that far forward may be also difficult. As I mentioned on r.a.s. before the 1.5dB cable loss budget for the Microair transponder is because Microair is trying to meet the TSO- C47c Type 1A (for use above 15,000') transponder specs with a transponder with only 200W output while other manufactures usually have a bit more cable loss budget, using a 250W or more transponder for this. They will typically have at least 3dB cable loss budget (for 250W transponders meeting TSO-C47c Type 1A (use above 15,000') or 3.9dB for 175W transponders meeting TSO-C47c Type 1B (use below 15,000'). There might also be an option of checking with whoever is doing the install and sign off on say havng a 250W transponder install as a having say a 250W transponder install as meeting TSO-C47c Type 1B (below 15,000') and therefore having a 5.5 dB cable loss budget. it's not like we really need the above 15,00o' specs - the important thing is to have a transponder at all in high traffic areas. So bottom line, finding an RF coax solution should not be a issue. A more interesting question to me is the close proximity of the VHF and transponder antennas. It is hard to see how you get a large enough ground plane in there for a 1/4 wave stub antenna and some shielding between the antennas. If a 1/2 wave or similar antenna is used then there would obviously be no shielding between antennas (but trying to line them up exactly co-linear will help. Darryl |
On Feb 18, 8:06*pm, wrote:
Looking for some suggestions on location of Transponder antenna from people who have them mounted on their Nimbus or DUO. Looking for area for placement of a 3rd Battery. Do you have a location that works well? Thanks in advance for the suggestions. Mark Mahan 2K This is not likely helpful for you Mark, sorry but for the non-carbon types this little gem worked like a charm on my ASW20b, inside the fusalage, out of sight, no drag & very easy to produce and install. http://www.as-segelflugzeuge.de/tm/2...2020%20001.pdf Rick 21 |
Transponder Antenna | Rick Fuller | Soaring | 6 | January 30th 08 06:03 PM |
VHF & Transponder antenna | Steve | Home Built | 1 | December 6th 04 04:29 PM |
Nav Antenna Placement | Jim Pensinger | Home Built | 7 | October 4th 04 09:55 PM |
Oil on transponder antenna | Bob | Owning | 12 | May 9th 04 08:59 PM |
Transponder and antenna | Paolo | Soaring | 1 | March 6th 04 03:32 AM |
