Hi All,
	Hopefully a simple quick question: I pulled my glider out of the trailer after a long winter recently, and found that I hadn't greased my lift-pins quite well enough. There are a few small spots of surface corrosion on them, and I'd like to get rid of it. BUT, given the importance of the lift pins I don't want to just go grinding on them. Anyone have any suggestions on the best/least- destructive way to get rid of minor surface rust/corrosion on parts like this? Thanks a bunch, --Noel  |
On Feb 25, 12:47*pm, "noel.wade"  wrote:
	Hi All, Hopefully a simple quick question: I pulled my glider out of the trailer after a long winter recently, and found that I hadn't greased my lift-pins quite well enough. *There are a few small spots of surface corrosion on them, and I'd like to get rid of it. BUT, given the importance of the lift pins I don't want to just go grinding on them. *Anyone have any suggestions on the best/least- destructive way to get rid of minor surface rust/corrosion on parts like this? Thanks a bunch, --Noel A green scotchbrite pad lubricated with WD-40 or LPS, etc, does a good job of pulling up surface corrosion without significantly influencing the parent material. Craig  |
On Feb 25, 1:53*pm, Craig  wrote:
	On Feb 25, 12:47*pm, "noel.wade" wrote: Hi All, Hopefully a simple quick question: I pulled my glider out of the trailer after a long winter recently, and found that I hadn't greased my lift-pins quite well enough. *There are a few small spots of surface corrosion on them, and I'd like to get rid of it. BUT, given the importance of the lift pins I don't want to just go grinding on them. *Anyone have any suggestions on the best/least- destructive way to get rid of minor surface rust/corrosion on parts like this? Thanks a bunch, --Noel A green scotchbrite pad lubricated with WD-40 or LPS, etc, does a good job of pulling up surface corrosion without significantly influencing the parent material. Craig Good suggestion. But if that doesn't remove it all, try a fine steel wool. Start gently, then buff and lubricate when satisfied. Jeff 7JK  |
On Feb 25, 1:12*pm,  wrote:
	On Feb 25, 1:53*pm, Craig wrote: On Feb 25, 12:47*pm, "noel.wade" wrote: Hi All, Hopefully a simple quick question: I pulled my glider out of the trailer after a long winter recently, and found that I hadn't greased my lift-pins quite well enough. *There are a few small spots of surface corrosion on them, and I'd like to get rid of it. BUT, given the importance of the lift pins I don't want to just go grinding on them. *Anyone have any suggestions on the best/least- destructive way to get rid of minor surface rust/corrosion on parts like this? Thanks a bunch, --Noel A green scotchbrite pad lubricated with WD-40 or LPS, etc, does a good job of pulling up surface corrosion without significantly influencing the parent material. Craig Good suggestion. But if that doesn't remove it all, try a fine steel wool. Start gently, then buff and lubricate when satisfied. Jeff * * 7JK- Hide quoted text - - Show quoted text - Naval Jelly, then rinse well Aerodyne  |
Come on guys, those pins are 10 times stronger than they need to
	be..............sand off the rust with 220 or emery cloth and lube them next time. I keep my pins in two large plastic tubes with lube inside (duct-taped together) as I remove them they pick up just enpough lube to shove them home. JJ wrote: On Feb 25, 1:12*pm, wrote: On Feb 25, 1:53*pm, Craig wrote: On Feb 25, 12:47*pm, "noel.wade" wrote: Hi All, Hopefully a simple quick question: I pulled my glider out of the trailer after a long winter recently, and found that I hadn't greased my lift-pins quite well enough. *There are a few small spots of surface corrosion on them, and I'd like to get rid of it. BUT, given the importance of the lift pins I don't want to just go grinding on them. *Anyone have any suggestions on the best/least- destructive way to get rid of minor surface rust/corrosion on parts like this? Thanks a bunch, --Noel A green scotchbrite pad lubricated with WD-40 or LPS, etc, does a good job of pulling up surface corrosion without significantly influencing the parent material. Craig Good suggestion. But if that doesn't remove it all, try a fine steel wool. Start gently, then buff and lubricate when satisfied. Jeff * * 7JK- Hide quoted text - - Show quoted text - Naval Jelly, then rinse well Aerodyne  |
noel.wade wrote:
	Hi All, Hopefully a simple quick question: I pulled my glider out of the trailer after a long winter recently, and found that I hadn't greased my lift-pins quite well enough. There are a few small spots of surface corrosion on them, and I'd like to get rid of it. BUT, given the importance of the lift pins I don't want to just go grinding on them. Anyone have any suggestions on the best/least- destructive way to get rid of minor surface rust/corrosion on parts like this? Thanks a bunch, --Noel Noel To prevent this in the future try this. Mix some LPS 3 (very waxy) and white lithium grease into a paste and coat any metal surface that you do not want to rust. It's very effective, easy to remove in the Spring and cheap. Paul ZZ  |
On Feb 25, 6:26*pm, JJ Sinclair  wrote:
	Come on guys, those pins are 10 times stronger than they need to be..............sand off the rust with 220 or emery cloth and lube them next time. I keep my pins in two large plastic tubes with lube inside (duct-taped together) as I remove them they pick up just enpough lube to shove them home. JJ Hey JJ - any reason to be concerned about the tightness of the fit of the pins in the bushings? I'd think you wouldn't want a shimmy in flight. Is there any risk of that? Andy  |
			 Hey JJ - any reason to be concerned about the tightness of the fit of the pins in the bushings? I'd think you wouldn't want a shimmy in flight. Is there any risk of that? Andy Some will experience what is known as the "clunk". That is the sound you may hear when rolling into a thermal. It is the fuselage sliding in the lift fittings and going "clunk". If you hear this you need at least a 20 thousands shim on one aft lift fitting, determine which one by measuring from the TE probe on the fin with a steel tape to a common point on each wing, say the aileron cut-out. Don't be surprised to find your prize possession is off by close to an inch! This will tell you where to epoxy the shim onto one of the aft lift fittings. Some will find their lift fittings are too tight which makes getting the wing onto the lift fittings a chore. Clean the fittings and scrub them with magic-marker, then put it together again. Then remove the wing and observe the magic-marked pins. The shinny spots show the interference fit areas. My ship showed a problem on the front end of the forward lift fitting and the back end of the aft lift fitting. It took months of working these areas down with emery cloth every time I flew to finally get the wing to slide on easily. Believe me you don't remove much steel with sandpaper! JJ  |
JJ -
	My fault, I wasn't clear enough - I meant the _other_ "lift-pins". My spar pins are exactly as you describe: Kept in a set of PVC tubes with well-greased felt inside so that they "self lubricate" every time I pull them out or put them back in the holders. I was referring to the alignment pins on each side of the fuselage that plug into the root rib sockets and ensure the wing is at its proper angle of incidence relative to the fuselage. They're a lot smaller and I don't think I want "variable incidence" wings as I fly around... ;-) Thanks, --Noel  |
On Feb 26, 6:32*am, JJ Sinclair  wrote:
	This will tell you where to epoxy the shim onto one of the aft lift fittings. I don't doubt JJ knows this but the Schleicher approved method of shimming the lift pins is to remove the lift pins and put the shims behind them. When I did this job on my 19 I found it best to do a trial fit by putting the shims on the outside face of the lift pins. A little grease will hold them in place. When the right additional shim thickness is found the lift pins are driven out, the shim stack adjusted, and the lift pins driven back in. I set mine up so there was no detectable fore/aft motion at the wing tips but the main spar pins could still be easily inserted. Andy  |
| Rust in tight places | mhorowit | Home Built | 12 | May 19th 09 10:40 PM |
| Rust prevention: Inside fuselage | Michael Horowitz | Home Built | 10 | August 20th 07 11:33 PM |
| Rust Baver 2 | acroman | Aviation Photos | 0 | August 19th 07 05:00 PM |
| Shaking off the Rust | john smith | Piloting | 22 | March 1st 07 01:36 AM |
| Rust inhibitor? | Steve Thomas | Home Built | 10 | August 30th 03 10:34 PM |
