Rust in tight places
I'm removing surface rust on a 4130 fuselage prior to priming.
Assume I'm in a place where I can't use my sandblaster. I need to get into the tight places of a cluster to remove surface rust. I can get pretty deep in the cluster with emery cloth, but there is the last 1/8". There are rust converter chemicals on the market. Is it OK for me to use a rust converter prior to priming or am I fooling myself? - Mike |
On Feb 5, 5:39*am, mhorowit wrote:
I'm removing surface rust on a 4130 fuselage prior to priming. Assume I'm in a place where I can't use my sandblaster. I need to get into the tight places of a cluster to remove surface rust. I can get pretty deep in the cluster with emery cloth, but there is the last 1/8". There are rust converter chemicals on the market. Is it OK for me to use a rust converter prior to priming or am I fooling myself? - Mike get a finer grade of blasting media.. I can't see how you could get any better results any other way. Ben |
stol wrote:
On Feb 5, 5:39 am, mhorowit wrote: I'm removing surface rust on a 4130 fuselage prior to priming. Assume I'm in a place where I can't use my sandblaster. I need to get into the tight places of a cluster to remove surface rust. I can get pretty deep in the cluster with emery cloth, but there is the last 1/8". There are rust converter chemicals on the market. Is it OK for me to use a rust converter prior to priming or am I fooling myself? - Mike get a finer grade of blasting media.. I can't see how you could get any better results any other way. Ben I think he meant that he was in a location i.e. hanger where sandblasting was forbidden. Charles |
On Feb 5, 4:48*pm, Charles Vincent wrote:
stol wrote: On Feb 5, 5:39 am, mhorowit wrote: I'm removing surface rust on a 4130 fuselage prior to priming. Assume I'm in a place where I can't use my sandblaster. I need to get into the tight places of a cluster to remove surface rust. I can get pretty deep in the cluster with emery cloth, but there is the last 1/8". There are rust converter chemicals on the market. Is it OK for me to use a rust converter prior to priming or am I fooling myself? - Mike get a finer grade of *blasting media.. I can't see how you could get any better results any other way. Ben I think he meant that he was in a location i.e. hanger where sandblasting was forbidden. Charles- Hide quoted text - - Show quoted text - That now does make sense but if the rust is slight there are small, portable sandblasters that would work using the smallest compressors.. |
"stol" wrote in message ... On Feb 5, 4:48 pm, Charles Vincent wrote: stol wrote: On Feb 5, 5:39 am, mhorowit wrote: I'm removing surface rust on a 4130 fuselage prior to priming. Assume I'm in a place where I can't use my sandblaster. I need to get into the tight places of a cluster to remove surface rust. I can get pretty deep in the cluster with emery cloth, but there is the last 1/8". There are rust converter chemicals on the market. Is it OK for me to use a rust converter prior to priming or am I fooling myself? - Mike get a finer grade of blasting media.. I can't see how you could get any better results any other way. Ben I think he meant that he was in a location i.e. hanger where sandblasting was forbidden. Charles- Hide quoted text - - Show quoted text - That now does make sense but if the rust is slight there are small, portable sandblasters that would work using the smallest compressors.. ------------------------------------------------------------------------------------------- The question is rust converter chemicals in tight places. |
On Feb 5, 5:48*pm, "Maxwell" #$$9#@%%%.^^^ wrote:
"stol" wrote in message ... On Feb 5, 4:48 pm, Charles Vincent wrote: stol wrote: On Feb 5, 5:39 am, mhorowit wrote: I'm removing surface rust on a 4130 fuselage prior to priming. Assume I'm in a place where I can't use my sandblaster. I need to get into the tight places of a cluster to remove surface rust. I can get pretty deep in the cluster with emery cloth, but there is the last 1/8". There are rust converter chemicals on the market. Is it OK for me to use a rust converter prior to priming or am I fooling myself? - Mike get a finer grade of blasting media.. I can't see how you could get any better results any other way. Ben I think he meant that he was in a location i.e. hanger where sandblasting was forbidden. Charles- Hide quoted text - - Show quoted text - That now does make sense but if the rust is slight there are small, portable sandblasters that would work using the smallest compressors.. ---------------------------------------------------------------------------*---------------- The question is rust converter chemicals in tight places.- Hide quoted text - - Show quoted text - Rust converters not properly and completely flushed will corrode the parent metal.. I guess I should have mentioned that first but I did assume that is a no brainer. My bad. over and out. |
"stol" wrote in message ... Rust converters not properly and completely flushed will corrode the parent metal.. I guess I should have mentioned that first but I did assume that is a no brainer. My bad. over and out. ---------------------------------------------------------------------------------- Not all brands require a flush. Some convert surface rust to a hard dark grey coating that seems to be an excellent sealer. |
"mhorowit" wrote in message ... I'm removing surface rust on a 4130 fuselage prior to priming. Assume I'm in a place where I can't use my sandblaster. I need to get into the tight places of a cluster to remove surface rust. I can get pretty deep in the cluster with emery cloth, but there is the last 1/8". There are rust converter chemicals on the market. Is it OK for me to use a rust converter prior to priming or am I fooling myself? - Mike Do you have a specific brand in mind? I have never used one on 4130, and never heard of one used on aircraft, but I have had good luck on automotive applications. |
On Thu, 5 Feb 2009 15:43:08 -0800 (PST), stol
wrote: On Feb 5, 5:39Â*am, mhorowit wrote: I'm removing surface rust on a 4130 fuselage prior to priming. Assume I'm in a place where I can't use my sandblaster. I need to get into the tight places of a cluster to remove surface rust. I can get pretty deep in the cluster with emery cloth, but there is the last 1/8". There are rust converter chemicals on the market. Is it OK for me to use a rust converter prior to priming or am I fooling myself? - Mike get a finer grade of blasting media.. I can't see how you could get any better results any other way. Ben use a brass wire brush and Phosphoric acid - MetalPrep or Water Softener Resin Cleaner - same stuff at about 1/4 the price. |
On Thu, 5 Feb 2009 20:49:47 -0600, "Maxwell" #$$9#@%%%.^^^ wrote:
"stol" wrote in message ... Rust converters not properly and completely flushed will corrode the parent metal.. I guess I should have mentioned that first but I did assume that is a no brainer. My bad. over and out. ---------------------------------------------------------------------------------- Not all brands require a flush. Some convert surface rust to a hard dark grey coating that seems to be an excellent sealer. Phosphoric Acid (Metal Prep) does just that - used as an "etch" in auto-body work to give the primer some "tooth" as well as getting rid of any minor surface "flask\h" rust. Makes Iron Phosphate. |
Similar Threads | ||||
Rust Baver 2 | acroman | Aviation Photos | 0 | August 19th 07 04:00 PM |
Rust Flying Service Beaver - 1 | acroman | Aviation Photos | 0 | August 19th 07 03:59 PM |
Shaking off the Rust | john smith | Piloting | 22 | March 1st 07 12:36 AM |
Fly tight for tight bomb patterns on the ground. | ArtKramr | Military Aviation | 120 | August 30th 04 08:42 AM |
Rust inhibitor? | Steve Thomas | Home Built | 10 | August 30th 03 09:34 PM |
