'been scratchin' some paper.
It looks like a 2.6L flat opposed 8-cylinder could be made will not too much difficulty from two Suzuki Hyabusa motorcycle cylinder blocks. The electronic fuel injected 'busa puts out about 130HP so two theoretically could make 260HP. With 8 cylinders, the power pulses overlap a little so wouldn't put too much stress on a planetary PSRU in a nose case. In the opposed configuration, the stock rods work so only the crank, PSRU and case would have to be fabricated. CNC does that sort of thing well. The result would be smaller and lighter than an O-200 - although that doesn't take the liquid cooling system into consideration. Still scratchin' but this thing looks cool. |
bildan wrote:
'been scratchin' some paper. It looks like a 2.6L flat opposed 8-cylinder could be made will not too much difficulty from two Suzuki Hyabusa motorcycle cylinder blocks. The electronic fuel injected 'busa puts out about 130HP so two theoretically could make 260HP. With 8 cylinders, the power pulses overlap a little so wouldn't put too much stress on a planetary PSRU in a nose case. In the opposed configuration, the stock rods work so only the crank, PSRU and case would have to be fabricated. CNC does that sort of thing well. The result would be smaller and lighter than an O-200 - although that doesn't take the liquid cooling system into consideration. Still scratchin' but this thing looks cool. Report back when you have it running and the first 100 hours run ok. THEN it would look cool. Until then it's just another net fantasy... |
On Mar 5, 11:31*am, bildan wrote:
'been scratchin' some paper. It looks like a 2.6L flat opposed 8-cylinder could be made will not too much difficulty from two Suzuki Hyabusa motorcycle cylinder blocks... Interesting. I'd like to see the SolidWorks and FEA on that crank, I bet the webs and bearings get awful narrow when you go and double the number of big ends strung along it. Also, is there any credible evidence that this little motor actyally does put out 130hp for any appreciable amount of time? Having developed and raced tiny Formula IV road bikes, I came to appreciate that the devil is in the details. And the more details you have, the greater the opportunity for bedevilment. The more I study airplane engines and their operating environment, the more I come to appreciate the underrecognized genius of the big, simple, slow-turning flat fours that came out of the 1930s. Parts you leave on the ground will never break in flight. Thanks again, Bob K. www.hpaircraft.com/hp-24 |
![]() "Bob Kuykendall" wrote in message ... On Mar 5, 11:31 am, bildan wrote: 'been scratchin' some paper. It looks like a 2.6L flat opposed 8-cylinder could be made will not too much difficulty from two Suzuki Hyabusa motorcycle cylinder blocks... Interesting. I'd like to see the SolidWorks and FEA on that crank, I bet the webs and bearings get awful narrow when you go and double the number of big ends strung along it. Also, is there any credible evidence that this little motor actyally does put out 130hp for any appreciable amount of time? Having developed and raced tiny Formula IV road bikes, I came to appreciate that the devil is in the details. And the more details you have, the greater the opportunity for bedevilment. The more I study airplane engines and their operating environment, the more I come to appreciate the underrecognized genius of the big, simple, slow-turning flat fours that came out of the 1930s. Parts you leave on the ground will never break in flight. Thanks again, Bob K. www.hpaircraft.com/hp-24 --------------------------------------------------------------------------------------- I have always been a big fan of alternative power plants, but Bob just said a mouthful, and it's very well stated. Forgive me for plagiarizing your analogy Bob, but I really like it. Much like the sound barrier, there is a demon that lives in every PSRU. Although several designs are quite promising these days, I still don't think anyone has found the proper solution. They just can't compare to the overall reliability of the status quo. It's a design thing, that has never been resolve without adding too much weight. |
![]() "bildan" wrote in message ... 'been scratchin' some paper. It looks like a 2.6L flat opposed 8-cylinder could be made will not too much difficulty from two Suzuki Hyabusa motorcycle cylinder blocks. The electronic fuel injected 'busa puts out about 130HP so two theoretically could make 260HP. With 8 cylinders, the power pulses overlap a little so wouldn't put too much stress on a planetary PSRU in a nose case. In the opposed configuration, the stock rods work so only the crank, PSRU and case would have to be fabricated. CNC does that sort of thing well. The result would be smaller and lighter than an O-200 - although that doesn't take the liquid cooling system into consideration. Still scratchin' but this thing looks cool. Cool, indeed! How much do you think you would have to sell it for, if you were to sell them? -- Jim in NC |
On Mar 5, 12:54*pm, Bob Kuykendall wrote:
On Mar 5, 11:31*am, bildan wrote: 'been scratchin' some paper. It looks like a 2.6L flat opposed 8-cylinder could be made will not too much difficulty from two Suzuki Hyabusa motorcycle cylinder blocks... Interesting. I'd like to see the SolidWorks and FEA on that crank, I bet the webs and bearings get awful narrow when you go and double the number of big ends strung along it. Also, is there any credible evidence that this little motor actyally does put out 130hp for any appreciable amount of time? Having developed and raced tiny Formula IV road bikes, I came to appreciate that the devil is in the details. And the more details you have, the greater the opportunity for bedevilment. The more I study airplane engines and their operating environment, the more I come to appreciate the underrecognized genius of the big, simple, slow-turning flat fours that came out of the 1930s. Parts you leave on the ground will never break in flight. Thanks again, Bob K.www.hpaircraft.com/hp-24 The Hyabusa's 130HP from 1300cc is about the most conservative power estimate there is. The bikes will go 180MPH as long as the fuel lasts. The engine is considered bulletproof in the motorcycle application. Well, yes but the cylinder blocks aren't directly across from each other being staggered for wider the webs. Unlike those slow turning fours, there isn't much torque from each power pulse - just a whole lot of them. With a flat 8 you have the choice of a 'boxer' with each rod on its own crank pin or the alternative with rods from opposing cylinders on the same crank pin. |
On Mar 5, 3:59*pm, bildan wrote:
On Mar 5, 12:54*pm, Bob Kuykendall wrote: On Mar 5, 11:31*am, bildan wrote: 'been scratchin' some paper. It looks like a 2.6L flat opposed 8-cylinder could be made will not too much difficulty from two Suzuki Hyabusa motorcycle cylinder blocks... Interesting. I'd like to see the SolidWorks and FEA on that crank, I bet the webs and bearings get awful narrow when you go and double the number of big ends strung along it. Also, is there any credible evidence that this little motor actyally does put out 130hp for any appreciable amount of time? Having developed and raced tiny Formula IV road bikes, I came to appreciate that the devil is in the details. And the more details you have, the greater the opportunity for bedevilment. The more I study airplane engines and their operating environment, the more I come to appreciate the underrecognized genius of the big, simple, slow-turning flat fours that came out of the 1930s. Parts you leave on the ground will never break in flight. Thanks again, Bob K.www.hpaircraft.com/hp-24 The Hyabusa's 130HP from 1300cc is about the most conservative power estimate there is. *The bikes will go 180MPH as long as the fuel lasts. *The engine is considered bulletproof in the motorcycle application. Well, yes but the cylinder blocks aren't directly across from each other being staggered for wider the webs. *Unlike those slow turning fours, there isn't much torque from each power pulse - just a whole lot of them. With a flat 8 you have the choice of a 'boxer' with each rod on its own crank pin or the alternative with rods from opposing cylinders on the same crank pin. I went to check and the 'advertised' HP for the Hyabusa is 191 from 1300cc. |
In article
, bildan wrote: On Mar 5, 3:59*pm, bildan wrote: On Mar 5, 12:54*pm, Bob Kuykendall wrote: On Mar 5, 11:31*am, bildan wrote: 'been scratchin' some paper. It looks like a 2.6L flat opposed 8-cylinder could be made will not too much difficulty from two Suzuki Hyabusa motorcycle cylinder blocks... Interesting. I'd like to see the SolidWorks and FEA on that crank, I bet the webs and bearings get awful narrow when you go and double the number of big ends strung along it. Also, is there any credible evidence that this little motor actyally does put out 130hp for any appreciable amount of time? Having developed and raced tiny Formula IV road bikes, I came to appreciate that the devil is in the details. And the more details you have, the greater the opportunity for bedevilment. The more I study airplane engines and their operating environment, the more I come to appreciate the underrecognized genius of the big, simple, slow-turning flat fours that came out of the 1930s. Parts you leave on the ground will never break in flight. Thanks again, Bob K.www.hpaircraft.com/hp-24 The Hyabusa's 130HP from 1300cc is about the most conservative power estimate there is. *The bikes will go 180MPH as long as the fuel lasts. *The engine is considered bulletproof in the motorcycle application. Well, yes but the cylinder blocks aren't directly across from each other being staggered for wider the webs. *Unlike those slow turning fours, there isn't much torque from each power pulse - just a whole lot of them. With a flat 8 you have the choice of a 'boxer' with each rod on its own crank pin or the alternative with rods from opposing cylinders on the same crank pin. I went to check and the 'advertised' HP for the Hyabusa is 191 from 1300cc. Is it supercharged? It MUST be a high-revving mother! My 1967 Porsche 911S (normally-aspirated) gets 180 hp at 7500 RPM. To reduce the displacement by 35% and add 5% power, there are only three ways to do it: 1. Supercharging 2. High RPM 3. A combination of #1 and #2 above. -- Remove _'s from email address to talk to me. |
In article
, Orval Fairbairn wrote: In article , bildan wrote: On Mar 5, 3:59*pm, bildan wrote: On Mar 5, 12:54*pm, Bob Kuykendall wrote: On Mar 5, 11:31*am, bildan wrote: 'been scratchin' some paper. It looks like a 2.6L flat opposed 8-cylinder could be made will not too much difficulty from two Suzuki Hyabusa motorcycle cylinder blocks... Interesting. I'd like to see the SolidWorks and FEA on that crank, I bet the webs and bearings get awful narrow when you go and double the number of big ends strung along it. Also, is there any credible evidence that this little motor actyally does put out 130hp for any appreciable amount of time? Having developed and raced tiny Formula IV road bikes, I came to appreciate that the devil is in the details. And the more details you have, the greater the opportunity for bedevilment. The more I study airplane engines and their operating environment, the more I come to appreciate the underrecognized genius of the big, simple, slow-turning flat fours that came out of the 1930s. Parts you leave on the ground will never break in flight. Thanks again, Bob K.www.hpaircraft.com/hp-24 The Hyabusa's 130HP from 1300cc is about the most conservative power estimate there is. *The bikes will go 180MPH as long as the fuel lasts. *The engine is considered bulletproof in the motorcycle application. Well, yes but the cylinder blocks aren't directly across from each other being staggered for wider the webs. *Unlike those slow turning fours, there isn't much torque from each power pulse - just a whole lot of them. With a flat 8 you have the choice of a 'boxer' with each rod on its own crank pin or the alternative with rods from opposing cylinders on the same crank pin. I went to check and the 'advertised' HP for the Hyabusa is 191 from 1300cc. Is it supercharged? It MUST be a high-revving mother! My 1967 Porsche 911S (normally-aspirated) gets 180 hp at 7500 RPM. To reduce the displacement by 35% and add 5% power, there are only three ways to do it: 1. Supercharging 2. High RPM 3. A combination of #1 and #2 above. It sounds as if you will have a very expensive grenade if you do it wrong! -- Remove _'s from email address to talk to me. |
On 5 Mar, 21:57, "Morgans" wrote:
"bildan" wrote in message ... 'been scratchin' some paper. It looks like a 2.6L flat opposed 8-cylinder could be made will not too much difficulty from two Suzuki Hyabusa motorcycle cylinder blocks. *The electronic fuel injected 'busa puts out about 130HP so two theoretically could make 260HP. With 8 cylinders, the power pulses overlap a little so wouldn't put too much stress on a planetary PSRU in a nose case. In the opposed configuration, the stock rods work so only the crank, PSRU and case would have to be fabricated. *CNC does that sort of thing well. The result would be smaller and lighter than an O-200 - although that doesn't take the liquid cooling system into consideration. *Still scratchin' but this thing looks cool. Cool, indeed! *How much do you think you would have to sell it for, if you were to sell them? I am not an expert but I doubt that there is any point in doing a flat 8 when compared to the existing V8 conversions based on this engine. The flat 4 Lycoming/Continental configuration makes sense because of the number of cylinders and the use of air cooling. I forget what way the crank is done but it has at least tolerable balance and good enough cooling of the rear cylinder. The proposed Hyabusa flat 8 project does not seem an advantage to the existing V8 Hyabusa conversions that you can just go and buy today. A V8 (with a 2 plane crank as you would use) has perfect balance and even firing. Due to water cooling there is no need to consider cooling air flow round the cylinders. What you just might do is increase the installed frontal area. I have the idea that mechanical failure of the original 4 cyl engines (or any high performance japanese bike engine) is pretty much unheard of but I am not at all sure. Maybe someone on uk.rec.motorcycles might have an idea as to the expected life span of a hyabusa engine when operated in a constant load regime, say at 130bhp. |
There I was, flat on my back... | Kyle Boatright | Home Built | 5 | August 16th 07 05:34 AM |
Flat tire | Viperdoc[_4_] | Piloting | 11 | June 4th 07 02:57 PM |
Flat Tires? | Jay Honeck | Owning | 40 | August 31st 05 01:59 AM |
Wrinkly flat panels | [email protected] | Home Built | 27 | March 6th 04 02:12 PM |
Flat Spin | JJ Sinclair | Soaring | 34 | February 10th 04 05:57 PM |
