The tire on my Baron looks low. This is impossible, since in MSFS there is
no need to put air in tires. Is there a switch on the panel that inflates the tires? If so, where is it located? Can anyone explain this anomaly? |
Viperdoc wrote:
The tire on my Baron looks low. This is impossible, since in MSFS there is no need to put air in tires. Is there a switch on the panel that inflates the tires? If so, where is it located? It's next to the ejection seat switch. |
Damn, you're just having all kinds of problems. At least your MSFS fuel is
still cheap! ![]() Jim "Viperdoc" wrote in message ... The tire on my Baron looks low. This is impossible, since in MSFS there is no need to put air in tires. Is there a switch on the panel that inflates the tires? If so, where is it located? Can anyone explain this anomaly? |
On 6/1/2007 9:45:12 AM, "Viperdoc" wrote:
Can anyone explain this anomaly? OK, one is funny, two or more are beginning to not be. Is this really ViperDoc or is this an imposter? -- Peter |
Interestingly enough, there is a simulator for a kingair 200 that does
introduce low tires, low oil and such. And the pilot gets to make maintenance decisions. The left engine needs oil, it will cost 18 dollars, proceed? Yes/No Something like that. John Viperdoc wrote: The tire on my Baron looks low. This is impossible, since in MSFS there is no need to put air in tires. Is there a switch on the panel that inflates the tires? If so, where is it located? Can anyone explain this anomaly? |
The Visitor wrote:
Interestingly enough, there is a simulator for a kingair 200 that does introduce low tires, low oil and such. And the pilot gets to make maintenance decisions. The left engine needs oil, it will cost 18 dollars, proceed? Yes/No Something like that. John Viperdoc wrote: The tire on my Baron looks low. This is impossible, since in MSFS there is no need to put air in tires. Is there a switch on the panel that inflates the tires? If so, where is it located? Can anyone explain this anomaly? Oh, God that would be horrible. I can understand maintenance where maybe you'd have to get mx to perform your 100 hour or something, but having to pay for it?? I used to play the Sims a while ago and the more you play it, the more it seems like life without the fun. Go to work, study, clean, eat, try to have some fun somewhere, pay bills, repeat. Hmm. Seems like "The Sims" are a pretty good human life simulator. I should start basing all of my social descisions on episodes of The Sims. Hey, does anyone remember the cheat where you get to move your sims around while in build mode? TIA |
Viperdoc wrote:
The tire on my Baron looks low. This is impossible, since in MSFS there is no need to put air in tires. Is there a switch on the panel that inflates the tires? If so, where is it located? Can anyone explain this anomaly? It's your density altitude. How far below MSL are you. |
"Viperdoc" wrote: The tire on my Baron looks low. This is impossible, since in MSFS there is no need to put air in tires. Is there a switch on the panel that inflates the tires? If so, where is it located? Can anyone explain this anomaly? Click on TOOLS in the menu bar and select the appropriate one. |
Ah!! Found it! TOOLSAIR-COMPRESSORINFLATE
Thanks! Jim "john smith" wrote in message ... In article , "Viperdoc" wrote: The tire on my Baron looks low. This is impossible, since in MSFS there is no need to put air in tires. Is there a switch on the panel that inflates the tires? If so, where is it located? Can anyone explain this anomaly? Click on TOOLS in the menu bar and select the appropriate one. |
"Viperdoc" wrote in news:466022cc$0$9878
: Can anyone explain this anomaly? Bean-O |
Sudden Flat Tire | Kevin Kubiak | Piloting | 27 | October 15th 05 02:17 AM |
Flat Tires? | Jay Honeck | Owning | 40 | August 31st 05 01:59 AM |
Wrinkly flat panels | [email protected] | Home Built | 27 | March 6th 04 02:12 PM |
Flat Spin | JJ Sinclair | Soaring | 34 | February 10th 04 05:57 PM |
P=39's and flat spins. | ArtKramr | Military Aviation | 10 | July 15th 03 05:06 PM |
