Hyabusa flat 8
Old March 6th 09, 04:34 PM posted to rec.aviation.homebuilt,uk.rec.motorcycles
Catman
Default Hyabusa flat 8
bildan wrote:
snip
Keep in mind how the motorcycle works. The bike has a 6-speed gearbox
whereas the airplane engine would have only one. The standard sport
bike shift technique, approved by the factory, is to apply a large
force to the shift lever and then tap the clutch lever when the rider
wants to shift.
I don't think it is, you know. ISTBC of course.
Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3
Tyger, Tyger Burning Bright (Remove rust to reply)
116 Giulietta 3.0l Sprint 1.7 145 2.0 Cloverleaf 156 V6 2.5 S2
Triumph Sprint ST 1050: It's blue, see.
www.cuore-sportivo.co.uk
Old March 6th 09, 05:19 PM posted to rec.aviation.homebuilt,uk.rec.motorcycles
Grimly Curmudgeon
We were somewhere around Barstow, on the edge of the desert, when the
drugs began to take hold. I remember Catman
saying something like:
bildan wrote:
snip
wants to shift.
Some people just like rebuilding gearboxes.
Old March 6th 09, 05:26 PM posted to rec.aviation.homebuilt,uk.rec.motorcycles
Catman
bildan wrote:
snip
wants to shift.
I must confess I'm not massively keen on it. I tend to stick with the
'pull clutch, change gear, release clutch' technique. Unless I'm doing
clutchless upshift, of course.
  #24
Old March 6th 09, 05:28 PM posted to rec.aviation.homebuilt,uk.rec.motorcycles
bildan
On Mar 6, 10:19*am, Grimly Curmudgeon
bildan wrote:
snip
Keep in mind how the motorcycle works. *The bike has a 6-speed gearbox
whereas the airplane engine would have only one. *The standard sport
wants to shift.
Nope, "pre-load and clutch" is how Sport Bike constant mesh,
progressive transmissions are DESIGNED to be shifted. It just shows
how much abuse these engines and transmission are intended to take.
  #25
Old March 6th 09, 06:08 PM posted to rec.aviation.homebuilt,uk.rec.motorcycles
Catman
bildan wrote:
On Mar 6, 10:19 am, Grimly Curmudgeon
bildan wrote:
snip
wants to shift.
Popcorn, anyone?
  #26
Old March 6th 09, 07:11 PM posted to rec.aviation.homebuilt,uk.rec.motorcycles
Maxwell[_2_]
"platypus" wrote in message
Wicked Uncle Nigel wrote:
Using the patented Mavis Beacon "Hunt&Peck" Technique, "TOG@Toil"
typed
On 6 Mar, 11:03, bod43 wrote:
On 5 Mar, 21:57, "Morgans" wrote:
snip interesting stuff
Maybe someone on uk.rec.motorcycles might have an
idea as to the expected life span of a hyabusa engine
when operated in a constant load regime,
say at 130bhp.
You'd need to boost the low and midrange torque to swing a prop, as
props rotate relatively slowly, don't they? I think a 'Busa engine
would last forever is detuned to 130bhp.
Depends on the prop, but I would think that gearing down would be the
way to go.
The thing that everyone seems to forget when promoting automotive engines
for aircraft is that most piston aero engines have a very hard life.
Take-off and climb is full power or very nearly, then they throttle back
to cruise at 75% or thereabouts. The only roadgoing vehicles that
approach that sort of use are in motorsports, and how long do they last?
Not true at all.
Ever driven a gas powered motor home, pulling a boat trailer. I drove a 6500
series Chevy dump truck years ago, always pulling a Case 580C back hoe. It
was 100% power almost all the time, and always at lease 75% on the highway.
I have seen lots of auto engines successfully suffer MORE abuse than
aircraft engines in many circumstances, and most often do it without proper
maintenance. Some school bus and UHaul truck engines deserve to be in the
Motor Sports Hall of Fame.
But that doesn't solve all the propeller and PSRU issues.
  #27
Old March 6th 09, 07:15 PM posted to rec.aviation.homebuilt,uk.rec.motorcycles
Maxwell[_2_]
"vaughn" wrote in message
"bod43" wrote in message
I have the idea that mechanical failure of the original 4 cyl
engines (or any high performance japanese bike engine) is
pretty much unheard of but I am not at all sure.
It matters little, because now you are making a whole new engine for a
totally different application, with no track record and the distinct
possibility of new and exciting failure modes. Further, the same can be
said about the reiliability for most any automotive engine in its intended
application, but the track record of automotive aero conversions is spotty
at best.
Just thinking outside the box... Since the proposed Hyabusa Flat 8 engine
will need a PSRU anyhow; how about two Hyabusa engines put together into a
twin-pack? The result would likely weigh a tad more than a simple flat 8,
but now you have two known engines combined with twin-engine redundancy.
Eliminate a lot of question marks with the experimental crank and rods too.
  #28
Old March 6th 09, 07:41 PM posted to rec.aviation.homebuilt,uk.rec.motorcycles
bildan
bildan wrote:
snip
wants to shift.
Triumph Sprint ST 1050: It's blue, see.www.cuore-sportivo.co.uk
Of course! You're thinking of ENGLISH bikes - that's different. We
all know how reliable those are. If the tranny can be shifted without
a clutch, it's not a Japanese sport bike.
My Kawasaki can't be shifted without the clutch but it shifts great
with the pre-load & clutch method and has done so reliably since '86.
  #29
Old March 6th 09, 08:10 PM posted to rec.aviation.homebuilt,uk.rec.motorcycles
Catman
bildan wrote:
snip
wants to shift.
Oh dear.
Can't afford a newer one?
  #30
Old March 6th 09, 08:32 PM posted to rec.aviation.homebuilt,uk.rec.motorcycles
Peter Dohm
"TOG@Toil" wrote in message
way to go.
If you're forced to use a higher-revving engine, yes- but gearboxes
or belts and cogs introduce problems of their own, which is why a
relatively large displacement slow-revving engine (which doesn't need
four valves/cylinder, multiple chain drive cams with cam chain
tensioners, etc.) makes a lot of sense for aircraft.
Which was what I was thinking. I mean, what was max revs for a Merlin?
Googles
Hm. About 3000rpm. Just off tickover for a 'Busa.
Hmm, some more...
By that line of reasoning, turbines should be really problematic.
No wonder FAA requires additional certification for pilots to fly turbine
aircraft.
Peter :-))))
There I was, flat on my back... Kyle Boatright Home Built 5 August 16th 07 05:34 AM
Flat tire Viperdoc[_4_] Piloting 11 June 4th 07 02:57 PM
Flat Tires? Jay Honeck Owning 40 August 31st 05 01:59 AM
Wrinkly flat panels [email protected] Home Built 27 March 6th 04 02:12 PM
Flat Spin JJ Sinclair Soaring 34 February 10th 04 05:57 PM
