Winch Signals
Old April 9th 09, 08:00 PM posted to rec.aviation.soaring
Gavin Short[_2_]
Default Winch Signals
At 17:45 09 April 2009, Nyal Williams wrote:
Andy,
Funny you should metion that; I used to work on pipe organs, but this
never occurred to me. I'm really interested to know the history of the
phrase.
At 16:54 09 April 2009, Andy wrote:
On Apr 9, 9:31=A0am, Andy wrote:
=A0Pulling a sliding
plate flue damper "all out" gives maximum flue draw and the hottest
fire.
On further reflection the term could have come from pipe organs where
"stops" are pulled out to control airflow and hence sound volume.
Pipe organs predate 1300. ref http://en.wikipedia.org/wiki/Pipe_organ
There must be a reference to the origin somewhere on the internet but
I didn't find it yet.
Andy
I learnt to winch at Dartmoor Gliding Society. We winched using an ex RAF
winch with a 7 Litre Diesel engine. They had previously experimented with
land lines (run around the perimeter fence and then later burying them) but
sheep and other rodents got to eat/chew them. Now there is a dedicated
ground frequency for the club. The launch point, winch and retrieve
vehicle can all communicate with each other. Its more flexible than a
land line because if the launch point is short handed one person can wing
run and talk to the winch using a hand held transceiver. The retrieve
vehicle can communicate which is useful if mending a cable break etc. In
addition the launch point and winch are out of sight of each other due to
the slope on the runway in either direction. No one has transmitted on
our private frequency when we are launching.
The radio calls a
'Take up slack (type of glider) (solo if a two seater and only one pilot)
North/South cable'.
The winch driver then takes the cable in slowly until all slack is taken
up.
When all slack has been taken up:
'All out, All out'
The winch driver give appropriate initial throttle according to
weight/type of glider and wind. When it comes over the crest the winch
diver controls the winch by eyeballing the catenary of the cable. If too
fast the pilot wags the rudder - yaws. If too slow the pilot puts the
nose down to regain speed.
Any problems the launch point calls ' STOP, STOP, STOP' and the winch
driver immediate cuts the power.
Note take up slack is said once,
'all out' is said twice
and
'STOP' three times.
Even if the engine is noisy or the radio distorted then the difference is
always clear.
In Belgium I winch in Flemish and German. Tost V8 auto winch atop a ex
German army truck. We use land lines and field telephones. The routine
is basically the same but a bit more wordy. The differences are that the
cables are colour coded - important because we use a 2 winch set up,
Flemish and German winches side by side and whoever is next in the queue
takes the next cable irrespective of the club membership of the pilot or
whose winch it is.
We don't wag the tail as a signal for too fast but the pilot calls the
speed in kph and the launch point relays the radio call via the land line
(which is permanently open during the winch launch) to the winch driver
who corrects the speed appropriately. The airfield is dead flat so the
winch driver can see everything.
Its horses for courses. After having over 3 years of doing it the British
way and over 3 years of doing it the Belgian/German way there isn't much
in it and I wouldn't be so bold to say that one way is better than the
other.
Whatever calls/routine you do adopt stick to it and make sure everybody
uses the same terminology and calls each and every time. Non-standard
calls causes confusion and accidents.
Gavin
Std Cirrus, CNN now G-SCNN, #173
LSV Viersen, Keiheuvel, Belgium
Old April 9th 09, 09:10 PM posted to rec.aviation.soaring
Bruce Hoult
On Apr 10, 3:51*am, JS wrote:
What was the film about skydiving where someone had a load of laundry
instead of a chute, their friend found out, and wrote NO GO on the
ground, but read upside down it looked like GO ON????
A story circulated in NZ around the time of the Mt Erebus crash that
the phrase "take off power please" had opposite meanings in the DC10
manual/procedures than it did in the Boeing 737's Air NZ operated.
Old April 9th 09, 10:00 PM posted to rec.aviation.soaring
John Galloway[_1_]
At 19:00 09 April 2009, Gavin Short wrote:
The radio calls a
pilot)
North/South cable'.
up.
'All out, All out'
too
and
'STOP' three times.
is
always clear.
The UK verbal launch signals are said once in my experience but on a
similar vein -it had never occurred to me before but only a couple of
weeks ago it was pointed out to me by Don Irving (Chairman of the BGA
Instructors committee) that the best reason for sticking to them is
similar to Gavin's point:
Take up slack = 3 words
All Out = 2 words
Stop = 1 word
The verbal signals are called by the wing runner to the light signaller.
The winch receives the equivalent light signals (long slow flashes, faster
flashes, constant light)
Nowadays the pilot does not call launch commands. When he has accepted a
cable attachment he is deemed to be ready to launch and the the wing
runner (or a designated other) is responsible for making the calls
properly.
John Galloway
Old April 9th 09, 11:28 PM posted to rec.aviation.soaring
Martin Gregorie[_4_]
Only in some clubs. Mine repeats the phrase continuously during that
phase of the launch but with a pause at the end of each repetition. This
makes them unambiguous despite background and/or wind noise. The back
channel is the light on the winch, which has three states:
- off: winch is stopped or out of gear. Cable is safe to handle.
- flashing: winch is in gear, cable is live and must not be touched
or approached
- continuously on: the winch driver has stopped or is holding the launch.
The launch marshal will use the radio to find out why the stop light
is on.
All Out = 2 words
Stop = 1 word
Agreed. I think the exact phrase is important vecause all three are quite
distinctive.
We have a hump in the middle of our field and so we use radio on a
dedicated channel to control winch launches.
Before the launch starts the winch driver is told who the pilot is, the
glider registration and type and which cable is to be used. This is
repeated back to the launch marshal for confirmation.
The pilot accepts the cable when he is ready to be launched and control
passes to the launch marshal for the rest of the launch unless the pilot
releases the cable. If there's an external hold the cable is also
released, this time under the launch marshal's direction.
When the launch marshal has checked and announced all is clear above and
behind he radios:
"winch, for the [TYPE] glider on your [left/right] cable, take up
slack ... take up slack ...", repeating the last phrase until the cable
is tight. Then he changes to:
"all out ... all out ... all out ... " until the glider is high enough to
be clearly visible to the winch driver, at which point transmission
ceases.
If anybody at the launch point sees an emergency developing he can stop
the launch by alerting the launch marshal, who changes his call to
"stop ... stop ... stop".
As you can see, the sound of the three calls is quite distinct, even over
wind noise on the mic and the sound of the winch. Most launch marshals
also emphasize the spoken rhythms to make the phrases as different as
possible.
That's for the winch. We use the same calls for an aero tow, prefixed
with the tug's call sign since this is a shared frequency but without any
repetition except that the stop call would still probably be "stop stop
stop".
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old April 10th 09, 03:43 AM posted to rec.aviation.soaring
On Apr 9, 11:15*am, Nyal Williams wrote:
Our club has yet to try winching, though a half-dozen members have
experienced it elsewhere sometime across the last fifty years.
Reading Piggot, I discover the command "All Out" for the beginning of
the launch. *Is this the customary command in other places besides
England? *Why this? *What does it reall mean? *At first I took it to mean
"Everyone stand clear" or some such, but apparently it means "Give 'er
the gun" in US slang. Does this Britishism have some colloquial meaning
for them that doesn't exist elsewhere?
Seems to me, such a command would be the same one a glider pilot who has
no wing runner (aero retrieve from a landout) uses on the radio to tell a
tow pilot to begin the launch after the rope is taut. *I've heard, "Go,
go, go." which I don't really like but can't say why.
What have you heard? *Anyone have any comments to offer?
In our club (Carolina Soaring Asociation), we use 'Take up slack' ,
'All out - All out' and 'Stop-Stop-Stop'. The glider controls the
speed and if he cannot do so anymore because he is over-speeding, the
pilot calls out 'down 5kts'. So far, this method has worked for us.
Last weekend, we got our fully loaded TwinAstir to 1,800ft several
times :-) The enthusiasm for and interest in winching is growing!
Uli Neumann
Old April 10th 09, 09:15 AM posted to rec.aviation.soaring
Derek Copeland[_2_]
properly.
When I first started gliding in the UK, the pilot used to control the
launch by holding up one finger, stationary, for 'up slack' and then two
fingers, waved in a sort of Churchillian Victory salute, for all out. The
problem was that student pilots often went on signalling all the way up
the launch and would then make a grab for the wrong knob when they got to
the top. I had students who tried to open the canopy, or pull the flap or
airbrake levers, when trying to release the cable!
When the arrangement outlined by John above came into force, there was
quite a lot of British resistance to it, as it was felt to be too
'French'. The French have a system where levelling the wings means 'all
out'. I always used to get shouted at in France for absent-mindedly
picking up wings before the glider was ready to launch, so you can see the
disadvantages of that system; at least when the 'Stupid Roast Beef
English' are around! They now normally back the signal up with a radio
call.
The current UK system also says that one person hooks the cable on and
then walks to the wingtip and picks it up, so less chance of launching
with somebody in front of the glider. The pilot should be holding the
release knob so that he/she can pull off immediately, if a problem such as
a wing drop occurs.
Derek Copeland
Old April 10th 09, 07:12 PM posted to rec.aviation.soaring
Malcolm Austin
One point that others haven't come up with is the number of words used in
each command.
1/ Take up slack = 3
2/ All out = 2
3/ Stop = 1
When you're in a noisy winch, (or tug) that gives another hint to what is
being said.
Malcolm..
"Nyal Williams" wrote in message
the launch. Is this the customary command in other places besides
England? Why this? What does it reall mean? At first I took it to mean
tow pilot to begin the launch after the rope is taut. I've heard, "Go,
What have you heard? Anyone have any comments to offer?
Old April 11th 09, 01:54 AM posted to rec.aviation.soaring
Andreas Maurer
On Thu, 9 Apr 2009 09:16:54 -0700 (PDT), rlovinggood
Nyal,
In our club in Germany, if I can remember, there were three commands.
1. Fertig (Ready, the pilot is ready to be launched.)
2. Seil straff (All of the slack is out of the cable)
3. Frei (The glider has cleared the ground)
These commands were relayed to the winch operator via a "field
telephone", the kind where you would turn the little crank to ring the
bell on the other end of the line.
In this club, winch launching was, and probably still is, the primary
way of launching. They do A LOT of winching. I wonder if they have
changed their ways and have different commands now.
No change at all, Ray.
p.s.: Did you already receive a small booklet from Landau?
Old April 11th 09, 06:49 PM posted to rec.aviation.soaring
Marian Aldenhövel[_2_]
Hi,
The official standardized phraseology as laid down in the SBO
(Segelflugbetriebsordnung)[1] is:
0) Inform the winch driver about type of glider, seats taken,
ballast, anything that may affect his choice of power to be
applied. Also information about things like plans for a
simulated cable-break. And on multi-drum winches identification
of the cable being used. "Am Bonner Seil eine ASK-21,
doppelsitzig, startklar."
1) "Seil anziehen".
2) When all slack is taken up: "Seil straff". At this point we
release the brake on our winch but do not apply any power
above idle.
3) When the glider starts rolling: "Fertig". This is the point
where launch power is (smoothely) applied. This is not
necessarily full power, depending on winch, aircraft and
conditions like wind.
4) "Frei" as the glider leaves the ground. After this point
the winch driver can see the glider.
At any time "Halt Stop! Halt Stop! Halt Stop!" to abort.
It is also required that there is a _reliable_ (emphasis from the SBO)
voice-link between the launch point and the winch. Using aircraft
radio/frequency is explicitly disallowed.
So it usually is a fixed telephone line.
Ciao, MM
[1] http://www.daec.de/se/downfiles/SBOstand01-11-2008.pdf
Old April 11th 09, 09:25 PM posted to rec.aviation.soaring
The Real Doctor
An airliner crashed somewhere in the far east (Taiwan?) after the air
traffic controller departed from standard phraseology with "descend
two five hundred feet"
Ian
patent for bank angle from GPS signals Tony Piloting 7 February 7th 07 12:25 AM
Tow Signals Ramy Soaring 58 October 19th 06 04:46 AM
Glider - Towplane Signals Mike the Strike Soaring 24 March 26th 05 09:33 PM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
The wrong signals to send to young visitors. Larry Dighera Piloting 57 November 26th 03 07:05 AM
