Tow Signals
Old October 11th 06, 09:02 PM posted to rec.aviation.soaring
Ramy
Default Tow Signals
There had been yet another fatality recently as a result of
misinterpreting the open spoilers signal. True we all passed the
written test and know that wiggeling the rudder means check spoilers
and rocking the wings means release, yet so many students and
experienced pilots alike continiue to confuse this signal and releasing
the tow rope instead, often resulting in accidents. It is not hard to
understand why: The tow plane barely climb, the glider pilot suspects
something must be wrong with the tow plane, then he/she sees the rudder
signal which confirms his thought that something is wrong, then
releases the tow rope in panic, since this is what we were taught to do
if something is wrong with the tow plane.
I think that there is a relatively simple solution for this:
1 - If radio is available (and it always should) - use it instead of
the rudder signal!
2 - If this doesn't doesn't work, the signal should be avoided until
the glider is at least 200
feet, unless of course, the tow plane is in immediate danger.
3 - If the glider pilot sees the tow plane signaling something (wigling
the rudder or rocking the wings)
the FIRST look at the spoilers, then release the tow rope if necessary.
In this case, the pilot will do the correct action regardless of the
signal. I think this is what needs to be taught.
I am not an instructor myself, so this is just my humble opinion...
Ramy
"Signal jamming a factor in future wars, general says" Mike Military Aviation 23 August 24th 11 03:17 AM
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
Glider - Towplane Signals Mike the Strike Soaring 24 March 26th 05 10:33 PM
The wrong signals to send to young visitors. Larry Dighera Piloting 57 November 26th 03 08:05 AM
