New flight recorder - flyWithCE Flight Recorder
Old May 5th 09, 01:41 AM posted to rec.aviation.soaring
Default New flight recorder - flyWithCE Flight Recorder
You can easily convert any IGC file to GoogleEarth format by using the
facility on http://www.gpsvisualizer.com/map_input?form=googleearth
http://www.soaridaho.com/
"uros" wrote in message
On May 4, 4:57 pm, ContestID67 wrote:
On May 3, 3:02 pm, Michael wrote:
On May 2, 6:38 am, uros wrote:
This spring I have released two new products – flyWithCE Flight
Recorder and flyWithCE Logbook.
That's a cool little device. Am I reading it right that it has just
one button for on/off? I'm assuming that the way you tell it that
you're ending one flight and starting another is by cycling the
power? Is there any LED to indicate when it has a good GPS lock?
--Michael
Are there any plans to make this recorder IGC certified (and add a
altitude pressure transducer)?
In this version pressure sensor could not be added. I am still
reviewing the IGC certification possibilities, but I would rather say
no than to promise something that I cannot keep.
On the other hand I would like to offer an alternative to mainstream
IGC certified flight recorders and add new features. One of those
features was already added – use of Google Earth to view flights. This
is very good program and has as spectacular 2D and 3D views. It is
free to use and it also works in offline mode (when you are not
connected to the Internet). And you can send KML files to anyone who
has Google Earth installed.
Best regards
Uros
Old May 5th 09, 10:30 AM posted to rec.aviation.soaring
Tim Newport-Peace[_3_]
gpsvisualiser is an excellent facility, but for viewing IGC filesw on
Google Earth, I must recommend IGCReplay.
http://www.ywtw.de/igcsim.html (German)
http://www.ywtw.de/igcsimen.html (English)
It does not require any advance file conversion, Try it!
Tim.
--Michael
Best regards
Uros
Old May 5th 09, 08:31 PM posted to rec.aviation.soaring
Tim Mara[_2_]
yes, but this is already linked into the software provided with the
flyWithCE recorder and without saving files and opening any other program
the Logger software can go directly to Google earth or you can simply select
the flight log and open in SeeYou Strepla or whatever your PC has
installed..it's very seamless and simple...
tim
"Wayne Paul" wrote in message
m...
SN-10b EW flight recorder/PDA combination Jim Archer Soaring 5 November 18th 08 12:30 PM
In flight recorder Lou Piloting 23 March 24th 07 12:45 AM
EW B-Model flight recorder BDS Soaring 12 August 19th 06 04:39 PM
US: Flight Recorder Alert Judy Ruprecht Soaring 8 July 19th 04 09:04 PM
who does Flight Recorder calibration... ken ward Soaring 4 March 5th 04 02:28 AM
