You can easily convert any IGC file to GoogleEarth format by using the
facility on http://www.gpsvisualizer.com/map_input?form=googleearth Wayne http://www.soaridaho.com/ "uros" wrote in message ... On May 4, 4:57 pm, ContestID67 wrote: On May 3, 3:02 pm, Michael wrote: On May 2, 6:38 am, uros wrote: This spring I have released two new products – flyWithCE Flight Recorder and flyWithCE Logbook. That's a cool little device. Am I reading it right that it has just one button for on/off? I'm assuming that the way you tell it that you're ending one flight and starting another is by cycling the power? Is there any LED to indicate when it has a good GPS lock? --Michael Are there any plans to make this recorder IGC certified (and add a altitude pressure transducer)? In this version pressure sensor could not be added. I am still reviewing the IGC certification possibilities, but I would rather say no than to promise something that I cannot keep. On the other hand I would like to offer an alternative to mainstream IGC certified flight recorders and add new features. One of those features was already added – use of Google Earth to view flights. This is very good program and has as spectacular 2D and 3D views. It is free to use and it also works in offline mode (when you are not connected to the Internet). And you can send KML files to anyone who has Google Earth installed. Best regards Uros |
gpsvisualiser is an excellent facility, but for viewing IGC filesw on
Google Earth, I must recommend IGCReplay. http://www.ywtw.de/igcsim.html (German) http://www.ywtw.de/igcsimen.html (English) It does not require any advance file conversion, Try it! Tim. -- At 00:41 05 May 2009, Wayne Paul wrote: You can easily convert any IGC file to GoogleEarth format by using the facility on http://www.gpsvisualizer.com/map_input?form=googleearth Wayne http://www.soaridaho.com/ "uros" wrote in message ... On May 4, 4:57 pm, ContestID67 wrote: On May 3, 3:02 pm, Michael wrote: On May 2, 6:38 am, uros wrote: This spring I have released two new products – flyWithCE Flight Recorder and flyWithCE Logbook. That's a cool little device. Am I reading it right that it has just one button for on/off? I'm assuming that the way you tell it that you're ending one flight and starting another is by cycling the power? Is there any LED to indicate when it has a good GPS lock? --Michael Are there any plans to make this recorder IGC certified (and add a altitude pressure transducer)? In this version pressure sensor could not be added. I am still reviewing the IGC certification possibilities, but I would rather say no than to promise something that I cannot keep. On the other hand I would like to offer an alternative to mainstream IGC certified flight recorders and add new features. One of those features was already added – use of Google Earth to view flights. This is very good program and has as spectacular 2D and 3D views. It is free to use and it also works in offline mode (when you are not connected to the Internet). And you can send KML files to anyone who has Google Earth installed. Best regards Uros |
yes, but this is already linked into the software provided with the
flyWithCE recorder and without saving files and opening any other program the Logger software can go directly to Google earth or you can simply select the flight log and open in SeeYou Strepla or whatever your PC has installed..it's very seamless and simple... tim "Wayne Paul" wrote in message m... You can easily convert any IGC file to GoogleEarth format by using the facility on http://www.gpsvisualizer.com/map_input?form=googleearth Wayne http://www.soaridaho.com/ "uros" wrote in message ... On May 4, 4:57 pm, ContestID67 wrote: On May 3, 3:02 pm, Michael wrote: On May 2, 6:38 am, uros wrote: |
SN-10b EW flight recorder/PDA combination | Jim Archer | Soaring | 5 | November 18th 08 12:30 PM |
In flight recorder | Lou | Piloting | 23 | March 24th 07 12:45 AM |
EW B-Model flight recorder | BDS | Soaring | 12 | August 19th 06 04:39 PM |
US: Flight Recorder Alert | Judy Ruprecht | Soaring | 8 | July 19th 04 09:04 PM |
who does Flight Recorder calibration... | ken ward | Soaring | 4 | March 5th 04 02:28 AM |
