ATC Radar Question
Old June 12th 09, 08:20 AM posted to rec.aviation.piloting
Morgans[_2_]
Default ATC Radar Question
"Bob Noel" wrote
the elevation radar determines altitude the same way the azimuth radar
determines bearing.
There are actually two radars running for PAR, right? One sweeping left to
right and one sweeping up and down, I think.
Jim in NC
Old June 12th 09, 11:36 AM posted to rec.aviation.piloting
Bob Noel[_2_]
Stealth Pilot wrote:
Mode C only provides 100 foot altitude resolution. bzzzzt!
Mode C provides a height eg 1252ft which is deemed only accurate to
100ft because the calibration errors are limited to 100ft.
I believe that Mode C provides 100 foot altitude resolution because
the least significant bit is 100'
Old June 12th 09, 11:21 PM posted to rec.aviation.piloting
Matt Barrow[_8_]
"Jackie" wrote in message
I understand that ATC radar uses an encoding altimeter and a transponder
operating with Mode C to determine an aircraft's altitude. Let's forget
about Mode C for a moment and switch to Mode A only or just a primary
return.
If an aircraft is at 18,000 ft (approx 3 nm) and 3 nm away from the radar
antenna, as seen on a map, how does the radar correct for slant distance
when distance is displayed (e.g. using concentric circle distance markers on
the scope or relative to a known distance, such as a marker on the display)?
In other words how does the radar know that the aircraft is actually 3 nm
away laterally and not 4.25 nm (approx slant distance at that altitude)?
Asquared + B squared = C squared, I'd guess.
And how does it separate A and B?
"A" is the radar range, "B" is garnered from the encoding altimiter.
Old June 12th 09, 11:22 PM posted to rec.aviation.piloting
Matt Barrow[_8_]
Without altitude information from the pilot or a Mode C transponder, the
radar system can't extract the horizontal distance from the slant distance.
Where did you read that their systems correct for altitude without Mode C
transponders?
I don't believe I indicated I read this.
If they could do that then they wouldn't have ever needed the
transponders to report altitude.
Does precision approach radar require a transponder to report altitude?
At the altitudes involved during approach, it's not so critical (altitude is,
but not the angle), but during
approach the heading data is as critical as the altitude reporting.
Old June 12th 09, 11:23 PM posted to rec.aviation.piloting
Matt Barrow[_8_]
"Stealth Pilot" wrote in message
On Fri, 12 Jun 2009 03:54:29 +0000 (UTC), Clark
Jackie wrote in
[snip]
PAR uses a height finder radar to provide sufficient vertical resolution for
precision approaches.
And when local BARO is not available, the minimums go up.
And why the slop (calibration error) is taken into account when developing the
approach procedure.
Old June 13th 09, 12:44 AM posted to rec.aviation.piloting
Peter Dohm
"Matt Barrow" wrote in message
transponder
forget
return.
radar
distance
markers on
display)?
nm
altitude)?
Interesting thread!
But, for the life of me, I can't figure any reason that atc would really
care about the exact map location of an aircraft--especially when it is both
close enough and high enough for the error to be significant.
Given the two most common uses, surveilance approaches to an airport at
nearly the same elevation as the radar and collision avoidance, the map
distance should be a trivial issue.
Peter
Old June 13th 09, 03:10 AM posted to rec.aviation.piloting
Matt Barrow[_8_]
"Peter Dohm" wrote in message
Interesting thread!
But, for the life of me, I can't figure any reason that atc would really care
about the exact map location of an aircraft--especially when it is both close
Given the two most common uses, surveilance approaches to an airport at nearly
the same elevation as the radar and collision avoidance, the map distance
Given the effort put into the significantly more accurate WAAS infrastructure,
I'd suspect that getting a more accurate fix would be correspondingly desirable.
Old June 13th 09, 04:04 AM posted to rec.aviation.piloting
Brian Whatcott
return.
radar antenna, as seen on a map, how does the radar correct for slant
distance when distance is displayed (e.g. using concentric circle
distance markers on the scope or relative to a known distance, such as a
nm away laterally and not 4.25 nm (approx slant distance at that altitude)?
I am late into the thread.
But you are presumably talking about an area surveillance radar.
Its fan beam does not typically stick 45 degrees up into the sky. Too
wasteful of energy.
Another concept to ponder: if its beam WERE able to steer up at 45
degrees or more, what do you think its path would look like on a plan
position indicator? (a regular display). You've mentioned its slant
range is 4.25 miles at 3 mile distance horizontally. 30 seconds later,
it might be overhead: where would it paint in terms of range?
Three miles?? A circular range ring at 3 miles, all round the display?
Brian W
Old June 13th 09, 04:47 AM posted to rec.aviation.piloting
Bob Noel[_6_]
No.
The beauty of the PAR approach is the aircraft only needs a
functioning radio.
Old June 13th 09, 06:07 AM posted to rec.aviation.piloting
Jackie
Brian Whatcott wrote:
transponder operating with Mode C to determine an aircraft's
altitude. Let's forget about Mode C for a moment and switch to Mode A
only or just a primary return.
altitude)?
wasteful of energy.
That's interesting. So if what you say is correct, an airport
surveillance radar has very little coverage of the area, say at the top
of a class B airspace because to cover that high an angle is "wasteful."
For example, a VFR plane flying legally just above the B ceiling could
very well be out of coverage of the radar that is supposed to be also
monitoring another high performance aircraft poking through that ceiling
at a high rate of speed. I'm not sure I agree with such an energy
saving measure.
My distances where small to keep the math simple for discussion
purposes, not to suggest what an actual display would include. Geez.
below the radar Philip Stroh Aviation Photos 31 November 27th 06 03:12 PM
Integrating onboard weather radar data with satellite-fed Doppler radar [email protected] General Aviation 3 January 9th 05 08:57 PM
Question about the F-22 and it's radar. Scott Ferrin Military Aviation 128 June 13th 04 01:23 AM
Yet another "Radar Required" question. Roy Smith Instrument Flight Rules 14 April 27th 04 05:07 PM
F15E Radar question. Bill Silvey Military Aviation 5 August 30th 03 06:17 PM
