ATC Radar Question
Old June 12th 09, 01:53 AM posted to rec.aviation.piloting
Jackie
Default ATC Radar Question
I understand that ATC radar uses an encoding altimeter and a transponder
operating with Mode C to determine an aircraft's altitude. Let's forget
about Mode C for a moment and switch to Mode A only or just a primary
return.
If an aircraft is at 18,000 ft (approx 3 nm) and 3 nm away from the
radar antenna, as seen on a map, how does the radar correct for slant
distance when distance is displayed (e.g. using concentric circle
distance markers on the scope or relative to a known distance, such as a
marker on the display)?
In other words how does the radar know that the aircraft is actually 3
nm away laterally and not 4.25 nm (approx slant distance at that altitude)?
Old June 12th 09, 02:40 AM posted to rec.aviation.piloting
Matt Barrow[_8_]
"Jackie" wrote in message
operating with Mode C to determine an aircraft's altitude. Let's forget about
Mode C for a moment and switch to Mode A only or just a primary return.
If an aircraft is at 18,000 ft (approx 3 nm) and 3 nm away from the radar
antenna, as seen on a map, how does the radar correct for slant distance when
distance is displayed (e.g. using concentric circle distance markers on the
scope or relative to a known distance, such as a marker on the display)?
In other words how does the radar know that the aircraft is actually 3 nm away
Asquared + B squared = C squared, I'd guess.
Old June 12th 09, 02:51 AM posted to rec.aviation.piloting
Jackie
And how does it separate A and B?
Old June 12th 09, 03:15 AM posted to rec.aviation.piloting
return.
Absent something else, it doesn't.
All a primary paint radar knows is azimuth and slant range.
Jim Pennino
Remove .spam.sux to reply.
Old June 12th 09, 03:22 AM posted to rec.aviation.piloting
Jim Logajan
Without altitude information from the pilot or a Mode C transponder, the
radar system can't extract the horizontal distance from the slant distance.
Where did you read that their systems correct for altitude without Mode C
transponders? If they could do that then they wouldn't have ever needed the
transponders to report altitude.
Old June 12th 09, 04:31 AM posted to rec.aviation.piloting
Jackie
So if a pilot turns his Mode C from off to on, does the radar then
correct the distance plotted (less distance from the antenna) based on
the altitude reported?
Jackie
transponders?
I don't believe I indicated I read this.
Does precision approach radar require a transponder to report altitude?
Old June 12th 09, 04:56 AM posted to rec.aviation.piloting
Jackie
Clark wrote:
Jackie wrote in
[snip]
PAR uses a height finder radar to provide sufficient vertical resolution for
precision approaches.
Could you elaborate on how the "height finder" works?
Old June 12th 09, 05:17 AM posted to rec.aviation.piloting
Bob Noel[_2_]
Jackie wrote:
Clark wrote:
Jackie wrote in
[snip]
resolution for precision approaches.
the elevation radar determines altitude the same way the azimuth radar
determines bearing.
Old June 12th 09, 07:49 AM posted to rec.aviation.piloting
Stealth Pilot[_2_]
On Fri, 12 Jun 2009 03:54:29 +0000 (UTC), Clark
Jackie wrote in
[snip]
Mode C only provides 100 foot altitude resolution. bzzzzt!
Mode C provides a height eg 1252ft which is deemed only accurate to
100ft because the calibration errors are limited to 100ft.
below the radar Philip Stroh Aviation Photos 31 November 27th 06 03:12 PM
Integrating onboard weather radar data with satellite-fed Doppler radar [email protected] General Aviation 3 January 9th 05 08:57 PM
Question about the F-22 and it's radar. Scott Ferrin Military Aviation 128 June 13th 04 01:23 AM
Yet another "Radar Required" question. Roy Smith Instrument Flight Rules 14 April 27th 04 05:07 PM
F15E Radar question. Bill Silvey Military Aviation 5 August 30th 03 06:17 PM
