Question about the Airbus planes
Old June 23rd 09, 01:00 AM posted to rec.aviation.piloting
Default Other questions about the Airbus planes
Mike Ash wrote:
Tom Duhamel wrote:
Gliders fly at lower altitudes, at lower speeds, in good weather
conditions...
Airliners fly in high altitude, high speed, low temperature, in
thunderstorms...
Don't think airliners fly higher. It's true that *on average* they do,
and they certainly collect *vastly* more time at FL360 than gliders do,
but gliders *do* collect time there. The current glider altitude record,
set in a composite glider, is over 50,000ft. I don't think low
temperatures or pressures have been seen to do anything bad to the
structure. A fellow did tell me once that a rapid descent can do bad
things to the gelcoat due to the temperature change, but that's a
separate issue, and I don't know if an airliner would even use that sort
of coating.
For speeds, that's really just a matter of increased structural strength
and stiffness, which means using more stuff or different shapes. The
question is how the composites tolerate load, which is well known. They
won't change their characteristics suddenly just because they're moving.
How good is composite when lightning strikes? Doesn't is explode or
something? I don't think it will conduct electricity, does it?
This one is a completely open question to me. No, they don't conduct
electricity as far as I know. In the one famous case of a glider getting
hit by lightning, the lightning traveled along metal control rods. The
rods superheated the air inside the wings, blowing the glider to bits.
Obviously this is not a desirable outcome for an airliner carrying 300
people and no parachutes. I can only assume that the smart engineers
working on this stuff have figured out a way to stop this from
happening, but I have no idea at all what that way would be.
Embedded conductive layers.
http://www.lightningtech.com/d~ta/faq1.html
Jim Pennino
Remove .spam.sux to reply.
  #32
Old June 23rd 09, 01:26 AM posted to rec.aviation.piloting
Jim Logajan
The following article titled "Building the 787: When lightning strikes"
may provide some background:
http://seattletimes.nwsource.com/htm..._boeing05.html
Doesn't is explode or something?
Probably depends on its electrical conductivity, which in turn depends
on the composition and construction of the fiber. (With enough current
you can even explode a conductor; something of interest to scientists
studying plasmas - and people who like to blow things up:
http://tesladownunder.com/Pulse_Power.htm
http://etd.caltech.edu/etd/available...022006-104759/
http://www.plasmacenter.cornell.edu/ExplodingWires.html )
Depends on the composite. If it is carbon fiber, then it can be made to
conduct electricity:
"The fiber also finds use in filtration of high-temperature gasses, as
an electrode with high surface area and impeccable corrosion resistance,
and as an anti-static component." From:
http://en.wikipedia.org/wiki/Carbon_fiber
  #33
Old June 23rd 09, 03:19 AM posted to rec.aviation.piloting
Dave Doe
says...
Humans seem to conduct quite well, check out this Indian (meeting his
maker) on top of a train. Warning, some might find it a bit graphic, so
don't watch it...
http://www.liveleak.com/view?i=fc0_1243424473
Duncan
  #35
Old June 23rd 09, 10:05 PM posted to rec.aviation.piloting
george
conditions...
Up until you start flying in wave and get intimate with rotor.
And they (generally) have to be rigged every time you want to go
flying and there are some rough handlers out there !
  #36
Old June 23rd 09, 10:21 PM posted to rec.aviation.piloting
John Smith
conditions...
Or within a cumulus congestus.
But agreed, they don't have a pressurized cabin and are usually stored
in shelter.
  #37
Old June 24th 09, 04:54 AM posted to rec.aviation.piloting
Tom Duhamel
don't watch it...
On the contrary, it's actually because we don't conduct electricity well
that we suffer from it. Since we resist current, we burn (not mentioning
the effect on some of our organs).
Nice video, but not to be shown to children!
  #38
Old June 24th 09, 05:01 AM posted to rec.aviation.piloting
Tom Duhamel
Really good article. Summed up some of my interrogations. Thanks for the
link, Jim
Another AirBus-320 question pintlar Home Built 18 November 7th 11 06:04 AM
Stupid question about birds and planes Peter Hucker[_2_] Aviation Photos 1 January 2nd 08 06:05 PM
airbus - Latest Plane From Airbus.jpg [email protected] Aviation Photos 14 June 26th 07 09:41 AM
A question on Airbus landings [email protected] Piloting 17 July 18th 06 09:05 PM
Question Regarding 9/11 Planes... builderbos Piloting 28 April 26th 04 11:33 PM
