Cambridge 302 problem..HELP Please
Old June 24th 09, 07:16 PM posted to rec.aviation.soaring
Andy[_10_]
Default Cambridge 302 problem..HELP Please
On Jun 22, 8:15*am, Robert Holliday wrote:
My 302 seems to work OK at 60 knots but when i fly 80 knots it indicates 10
knots lift (it is set up for super netto). The total energy is set at 0% as
per instructions. It is not set up for electronic compensation. I checked
for leaks in the TE probe and tubing and found none. I just had it
upgraded to the USB port and the software fixed so it would not "fill
up" the flight log storage. Has anyone had this kind of problem? any
ideas?
thanks.
bob holliday
BTW - can anyone explain the difference between Netto and Super-Netto
settings? If I ever knew I have since forgotten.
9B
Old June 24th 09, 07:56 PM posted to rec.aviation.soaring
T8
ideas?
thanks.
bob holliday
9B
"Super Netto" is Cambridge speak for a vario that shows you the climb
(or sink) you would achieve if you slowed to thermaling speed. It's a
cute idea... but it adds another area of "compensation" on an already
highly compensated system. You'll probably find as I do that the
device works best for thermal entry transients when it's set to good
old total energy.
-T8
Old June 24th 09, 10:21 PM posted to rec.aviation.soaring
John Cochrane
ideas?
thanks.
bob holliday
9B
(or sink) you would achieve if you slowed to thermaling speed. *It's a
highly compensated system. *You'll probably find as I do that the
old total energy.
-T8
More simply, super netto = netto - 200 fpm. I use it, unlike T8. If
I'm going 100 knots in 1 kt up air, I want the vario to say -1kt, not
-6 kts, and remind me to slow down. Real netto would do that too, but
I find myself losing track of which mode it's in so I fly too slow.
Some put the needle on TE and the audio on speed to fly, but I find
that confusing too.
John Cochrane BB
Cambridge 302 problem..HELP Please Robert Holliday Soaring 11 June 25th 09 03:15 PM
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 06:31 PM
Cambridge 302 & PDA -- Value of adding Cambridge 303? V1 Soaring 5 July 31st 07 04:51 AM
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 Nathan Whelchel Soaring 4 July 6th 04 12:22 AM
Cambridge 302 problem: "Could not get FAT.(A)" while trying to download flight logs Jason Armistead Soaring 5 July 13th 03 03:36 PM
