Aircraft Recovery Dolly
Old August 6th 09, 08:03 PM posted to rec.aviation.owning
Gary Peek
Default Aircraft Recovery Dolly
John wrote:
I need to acquire a dolly capable of recovering a typical general
aviation aircraft with a flat tire.
I would like something that I can just place the flat tire wheel
assembly onto without removing wheel pants or brakes. It also needs
to be capable of being towed up to a mile using only one tug.
Any ideas?
Have done it with a 4 wheel dolly, but it was one of
the really sturdy ones that moving companies use.
McMaster-Carr has many of them, but I don't know which
model would be it. www.mcmaster.com
Old May 16th 14, 03:53 AM posted to rec.aviation.owning
Any ideas?
go to theirontire.com for the answer
Old August 18th 14, 10:04 AM posted to rec.aviation.owning
On Thursday, April 16, 2009 9:48:26 AM UTC-5, John wrote:
I need to acquire a dolly capable of recovering a typical general aviation aircraft with a flat tire. I would like something that I can just place the flat tire wheel assembly onto without removing wheel pants or brakes. It also needs to be capable of being towed up to a mile using only one tug.Any ideas?
I have built what you wish for. It carries a capacity of 10,000lbs and works great. Hydraulics up to twice as much. Typically you can roll a flat tire 1 1/2 ft Even if rim is damaged the same can happen. If interested visit aircraftrecovery.net
LS4 tail dolly Leigh Soaring 0 May 30th 08 02:02 AM
ASK-21 - is a tail dolly necessary? Dave Springford Soaring 7 December 31st 07 08:43 AM
FS: ASW-24 Tail Dolly [email protected] Soaring 0 December 26th 06 02:40 PM
WTB: used tail dolly David Campbell Soaring 5 April 17th 06 03:19 PM
assembly dolly Udo Rumpf Soaring 0 April 29th 05 04:17 PM
