removing transparency coating
Old September 19th 09, 07:44 PM posted to rec.aviation.soaring
Default removing transparency coating
http://home.hiwaay.net/~langford/kcf.html
Look at this link towards the bottom of the page. It has some good
details on getting rid of the film covering.
Old September 19th 09, 09:34 PM posted to rec.aviation.soaring
JJ Sinclair
Look at this link towards the bottom of the page. *It has some good
Hey, guess what? Hot water works, I just poured boiling water over a
K-6 canopy that must be 30 years old. The protective covering was hard
as a rock. Boiling water made it soft and rubbery and I was able to
get one side started and then peal the whole covering off. Anyone need
a K-6 canopy? Also have 2 open Cirrus forward canopies and a blue rear
Cirrus canopy (mounted). and a Minstrel canopy, all with rock hard
protective covering that we now know how to remove.
JJ
Old September 20th 09, 07:06 AM posted to rec.aviation.soaring
Brad[_2_]
It's almost 11:00 PM and I just finished removing the last of the
Spray-Lat from my HP-24 transparency. Started this morning around
lunch time and pretty much stuck with the project all day.
Thanks to all for suggestions...................... lessons learned:
Paint on Spray-Lat really makes it tough to remove.
Denatured alcohol helps with removal, but really hurts your fingers.
Fingernails make really good removal tools, but they sorta get bent
back
and make nice places for denatured alcohol to flow.
The best scraper is the George Foreman Grill cleaning tool.
Boiling water works great.
I'll be calling Tim next week for some Plexiglas scratch removal
stuff.
Should have some pics of the cleaned up canopy on the HP-24 website
next week, all in all it turned out great and I am pleased with the
results.
Brad
Old September 22nd 09, 02:13 AM posted to rec.aviation.soaring
Brad[_2_]
http://hpaircraft.com/hp-24/update_21_sept_09.htm
bottom of the page shows the cleaned up transparency/canopy.
Brad
Penalitel anit-corrosion coating Jon Woellhaf Owning 2 June 27th 07 06:11 PM
Coating aluminum Lou Home Built 23 December 24th 05 04:11 AM
How to identify fabric/coating process used? Wallace Berry Home Built 7 October 7th 05 07:14 PM
Doors Open On New Powder Coating Facility Anaheim California United States [email protected] Home Built 0 October 21st 04 02:33 PM
Suitable coating for spring-steel wire? Wright1902Glider Home Built 6 February 9th 04 04:12 PM
