I am trying to remove the spray coating that was sprayed on my
transparency for shipping. Stuff has been on there for over 3 or more years now and it might take me that long just trying to remove the damn stuff. Any advice from those who might have some experience with this tenacious film? Thanks, Brad |
What is this "transparency" and what is it made of?
At 22:51 18 September 2009, Brad wrote: I am trying to remove the spray coating that was sprayed on my transparency for shipping. Stuff has been on there for over 3 or more years now and it might take me that long just trying to remove the damn stuff. Any advice from those who might have some experience with this tenacious film? Thanks, Brad |
On Sep 18, 5:15*pm, Nyal Williams wrote:
What is this "transparency" and what is it made of? In the case at hand the transparency is made of 1/8" aircraft grade acrylic plastic, commonly referred to as Plexiglas (tm) or generically plexiglass. It's the clear plastic thingy you look out of when you sit in a sailplane. I don't refer to it as a "canopy" because that word is too often used to refer to the entire assembly consisting of the acrylic transparency, the canopy frame and assorted mechanisms of latching and hinging. Thanks, Bob K. |
Hot water and plexiglass cleaner.
Yeah, really hot water, boiling water won't hurt plexy and may loosen
the stuff some. Scraping with wood will leave a rub mark, but this can be removed with canopy cleaner/scratch remover. I once removed the stuff after 20 years...........Ugh! JJ |
In that case, would one of those steamer thingies that they use to
remove wallpaper be useful? -John On Sep 19, 8:27 am, JJ Sinclair wrote: Yeah, really hot water, boiling water won't hurt plexy and may loosen the stuff some. Scraping with wood will leave a rub mark, but this can be removed with canopy cleaner/scratch remover. I once removed the stuff after 20 years...........Ugh! JJ |
On Sep 19, 5:33*am, jcarlyle wrote:
In that case, would one of those steamer thingies that they use to remove wallpaper be useful? -John On Sep 19, 8:27 am, JJ Sinclair wrote: Yeah, really hot water, boiling water won't hurt plexy and may loosen the stuff some. Scraping with wood will leave a rub mark, but this can be removed with canopy cleaner/scratch remover. I once removed the stuff after 20 years...........Ugh! JJ- Hide quoted text - - Show quoted text - Worth a try, plexy doesn't yield until it reaches about 350F |
On Sep 19, 6:08*am, JJ Sinclair wrote:
On Sep 19, 5:33*am, jcarlyle wrote: In that case, would one of those steamer thingies that they use to remove wallpaper be useful? -John On Sep 19, 8:27 am, JJ Sinclair wrote: Yeah, really hot water, boiling water won't hurt plexy and may loosen the stuff some. Scraping with wood will leave a rub mark, but this can be removed with canopy cleaner/scratch remover. I once removed the stuff after 20 years...........Ugh! JJ- Hide quoted text - - Show quoted text - Worth a try, plexy doesn't yield until it reaches about 350F- Hide quoted text - - Show quoted text - This is from one manufacturer of acrylic plastic (Plexiglas is a brand name). Note the softening and melting temps are lower than some have suggested in this thread - - so don't heat it and then lean on it (g). "Thermal Maximum Recommended Continuous Service Temperature °F 170-190 Softening Temperature °F 210-220 Melting Temperature °F 300-315" I would do as JJ suggests, use boiling water. But use caution about getting "creative" while applying heat, My experience is the longer some such protective coatings are aged, even when not directly exposed to UV, the harder they are to remove - - UV makes is worse still!. So it's probably better to get on it sooner rather than later. If the coating is left on because the canopy is part of a building project, one might consider removing the coating and then using clear plastic sheet to drape the canopy. On a smaller scale, some of the tapes used to attach yaw strings can be hell to remove later after prolonged UV exposure - - - especially clear tapes. Ease of removal, leaving no residue even after years of exposure, is one of the benefits of my MKIV yaw string. bumper zz Minden |
Penalitel anit-corrosion coating | Jon Woellhaf | Owning | 2 | June 27th 07 06:11 PM |
Coating aluminum | Lou | Home Built | 23 | December 24th 05 04:11 AM |
How to identify fabric/coating process used? | Wallace Berry | Home Built | 7 | October 7th 05 07:14 PM |
Doors Open On New Powder Coating Facility Anaheim California United States | [email protected] | Home Built | 0 | October 21st 04 02:33 PM |
Suitable coating for spring-steel wire? | Wright1902Glider | Home Built | 6 | February 9th 04 04:12 PM |
