leading edge flaps
Old January 12th 04, 03:50 PM
Ed Rasimus
On Sun, 11 Jan 2004 23:36:55 GMT, "Dudley Henriques"
"Ed Rasimus" wrote in message
news
On Sun, 11 Jan 2004 06:05:28 -0600, "John Carrier"
If they extend when airpressure is reduced as airspeed slows, then it
would be redundant to add "also when a certain AOA is achieved"
because that is the inevitable, inexorable, undeniable result of
slowing.
Just musing here Ed; :-))))))
I might be missing something in what you're saying about slat extension Ed,
but FWIW, although it's true that dynamic pressure will bring out an
aerodynamic LE slat as airspeed is reduced and angle of attack is increased
as the result of that slowing, the only common denominator that SHOULD be
used for an aerodynamic slat extension parameter is aoa, not airspeed!
You are correct.
It's AOA, not specifically lower airspeed. They can droop under
acceleration when a design AOA is reached.
I got so wrapped up in trying to be all-encompassing while not
grabbing the tar baby that I mis-spoke.
Ed Rasimus
Fighter Pilot (USAF-Ret)
"When Thunder Rolled"
Smithsonian Institution Press
ISBN #1-58834-103-8
  #73
Old January 12th 04, 04:14 PM
Tarver Engineering
"B2431" wrote in message
You are correct. I guess I am not as perfect as tarver g
I am impressed that you were not a little turd for this thread, Dan.
  #74
Dudley Henriques
news
slowing.
Ed,
increased
You are correct.
I know the feeling. That ole' tar baby is one sticky character all right!
If you and Carrier ever manage to talk him into the back seat of a T38 for
just one flight......just ONE!!!.....I'll buy you both a case of Scotch if
you let me take him !! :-))
Dudley
  #75
Old January 12th 04, 04:15 PM
Tarver Engineering
snip
You really need to pay attention to what is being discussed. We were
discussing
aircraft, tarver, not "autos."
We discussing the complete name of control surfaces, no matter how
heartbraking it is for you to find out just how much of an idiot you are,
Dan.
  #76
Old January 12th 04, 04:29 PM
Tarver Engineering
snip
Now that you mention it, we did have Servair begging us to help them
interface new digital gyros to Houston's T-38Ns, but we rejected the work;
as the CCB system is too much overhaed. we offered a Part 25 type change,
but they did not understand.
  #77
Old January 12th 04, 05:45 PM
Ed Rasimus wrote:
You are correct.
Ed Rasimus
A gain of several notches.
-Gord.
  #78
Old January 12th 04, 06:06 PM
Mikko Pietilä
On Sun, 11 Jan 2004 20:14:26 GMT, "John R Weiss"
"Dudley Henriques" wrote...
The Blues bolted 'um shut. Can you imagine what would happen in a tight
diamond with an A4 if a wing position got an asymmetrical slat extension
with roll induced....say in a barrel roll? Not a pretty thought!! :-))
In over 1700 A-4 hours, I never had an asymmetric slat extension that I could
not quickly and easily control. After about 1000 hours, few of them were even
unpredictable...
I wonder if you could try to describe, as well as you can recall, what
exactly happens during an asymmetrical slat extension?
The reason I am asking such an obvious sounding question is that we
recently had a discussion concerning asymmetric slat extension of a
BF-109 in a Finnish newsgroup. While the immediate lay-man's reaction
is that the aircraft would, of course, violently roll away from the
extended slat (=extended slat up), because of the increased lift by
the slat, the situation becomes less obvious the more I think about
it.
Theoretically, from the textbook figure illustrating the effect of
trailing edge flaps and leading edge slats, one could argue that
nothing happens, since slats (unlike flaps) do not increase Lift
Co-efficient (CL) on a given Angle of Attack (AOA) but only increase
the maximum attainable CL. This at least in the case that the net wing
area does not increase when slat extends.
If the wing area increases (as probably is the case with A-4, judging
from the photo I have) as the slat extends, the aircraft would tend to
roll extended slat up. Right?
However, if the geometry is such that the leading edge moves down as
the slat extends, one could argue that the AOA of the profile
decreases causing roll towards the extended slat.
Or, if the slat extension causes a change of pressure distribution
around the aileron (the aileron snatch reported by the British BF-109
test pilots ?) moving the ailerons (probably not on the hydraulic
irreversible(?) control system of the A-4) until the pilot corrects
it, the roll could be either way.
Mikko
  #79
Old January 12th 04, 06:41 PM
Tarver Engineering
"Gord Beaman" wrote in message
Ed Rasimus wrote:
You are correct.
Ed Rasimus
And isn't it so much nicer to have a civil professional discussion?
  #80
Old January 12th 04, 07:53 PM
John R Weiss
"Mikko Pietilä" wrote...
unpredictable...
That part is easy -- the airplane rolls toward the side with the unextended (or
less-extended) slat.
The difficulties arise when the slat extension is either at greater than 1 G,
very close to another airplane, and/or in the hands of an unexperienced pilot at
the top of a loop. Higher G causes a higher roll rate. If you're in close
formation and do not correct in time, you might roll into the other airplane.
If you put in the wrong control corrections at low speed (e.g., at the top of a
loop), you may depart, stall, and/or spin the airplane. Most of the training
Command mishaps related to asymmetrical slat extension, with which I am
familiar, were of the latter variety (departure or loss of orientation and
control in "unusual" attitudes).
Normal correction was to simply "pop" the stick slightly to one side, opposite
the roll, and the other slat would extend normally. However, if (due to a poor
preflight) the second slat was sticky enough to not deploy, and the AOA was
maintained high enough to keep the first one all the way out, an unexperienced
pilot could lose control. Otherwise, the airplane was controllable with
asymmetric slats.
Right.
Though the dynamics may be a bit more complicated than apparent from a simple
illustration, the net result of slat extension, in all the airplanes I've flown
that had them, is an increase in lift. Contributing to the increase a
Increased wing camber
Increased effective wing area
Energized airflow through the slot delays flow separation further back on
the wing
Though the apparent AOA may decrease, I suspect the other factors prevail.
Remember that with an aerodynamically-controlled slat, the wing is already at a
relatively high AOA when it deploys. I am not an aerodynamicist, but somebody
else may be able to give some insight into the relative contributions of the
different factors.
I'm not familiar with the "aileron snatch" you describe, but I think I can
picture it in my mind. I would guess that has to do with the point at which
flow separation occurs on the wing. If flow is instantly, and asymmetrically,
restored over the aileron, the ailerons may be pulled in that direction, causing
the opposite roll. If this is the case, the AOA at which the slats start to
deploy, and the rate at which they deploy, would likely be adjusted in the
design phase.
FS - Propeller leading edge protective tape Sammy Home Built 0 July 6th 04 12:06 PM
Leading edge protection search Tim Hickey Home Built 0 June 28th 04 02:45 AM
A Bush C150? With Leading Edge Slats? [email protected] Home Built 33 May 27th 04 05:39 PM
-7 wing leading edge 'glitch' ? Charlie England Home Built 0 March 7th 04 12:27 AM
tail buffeting and leading edge fillets, strakes Wallace Berry Home Built 1 September 26th 03 10:48 PM
