-7 wing leading edge 'glitch' ?
Old March 7th 04, 12:27 AM
Charlie England
Default -7 wing leading edge 'glitch' ?
-7/-8 builders,
Has anyone noticed a slight dip about an inch above & below (back of the
actual apex) the rolled leading edge of their tank skins & leading edge
skins?
While handling one of my cleco'd tanks, I felt the dip, & thought I had
somehow dented the leading edge. On further inspection, the 'dips' are
slight valleys running the entire length of the LE & are identical on
all 4 skins. On the top side, it's about where the 2nd rivet will be in
each rib. It seems unlikely that it's due to the ribs, because there is
no difference in the valley mid way between ribs.
I might be good at messing stuff up, but I ain't THAT good.
Charlie
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
tail buffeting and leading edge fillets, strakes Wallace Berry Home Built 1 September 26th 03 10:48 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 02:33 AM
Slats and Fowler Flaps On Light Plane Brock Home Built 28 July 31st 03 10:12 PM
Wing Extensions Jay Home Built 22 July 27th 03 12:23 PM
