Drilling Template.
Old November 22nd 09, 09:36 PM posted to rec.aviation.soaring
Darek
Default Drilling Template.
Hi All,
I'm looking for a drilling template for Cambridge 302 and 303.
Can anybody help?
Darek
Old November 23rd 09, 12:43 AM posted to rec.aviation.soaring
Steve Koerner
I bought one long ago at Aircraft Spruce.
Old November 23rd 09, 02:12 AM posted to rec.aviation.soaring
Westbender
They fit the standard 57mm (2.25") instrument panel holes. Can't you
just take a 57mm instrument out of your panel and trace the instrument/
screw holes onto a piece of paper or cardboard?
On Nov 22, 3:36*pm, Darek wrote:
Hi All,
Can anybody help?
Darek
Old November 23rd 09, 01:42 PM posted to rec.aviation.soaring
Richard[_9_]
On Nov 22, 1:36*pm, Darek wrote:
Hi All,
Can anybody help?
Darek
Darek,
Instructions for constructing the perfect instrument hole.
http://www.craggyaero.com/Drawings/I...0Templates.pdf
Richard
www.craggyaero.com
Old November 23rd 09, 02:43 PM posted to rec.aviation.soaring
JJ Sinclair
Hi All,
Can anybody help?
Darek
I cut the head off some old junk instruments to make a perfect
drilling jig. Have one cut off an 80mm and another cut off a 57mm
instrument. Add another from an altimeter so's you get the cut out at
7 o'clock and your good to go. Helps in arranging things on the back
of a new panel to see just where everything must go. Not all
instruments are created equal..............measure twice, cut once!
Cheers,
JJ
Old November 23rd 09, 03:34 PM posted to rec.aviation.soaring
Dave Nadler
Cheers,
JJ
That's what I did. Tips:
Use some wingtip around the flange until the shell fits tight
in the new hole, which centers it and keeps it from moving
while you're marking the holes.
Use a centering punch to make precise marks for the holes.
Also, a metal "hole reducer" from Aircraft Spruce will
work in a pinch.
Hope that helps,
See ya, Dave "YO electric"
Old November 23rd 09, 07:48 PM posted to rec.aviation.soaring
Darek
Hi All,
Thank you for help.
Darek
Old November 23rd 09, 08:13 PM posted to rec.aviation.soaring
Dave Nadler
Cheers,
JJ
Use some wing-tape around the flange until the shell fits tight
work in a pinch.
Hope that helps,
Drilling out old rivets questions? Fonz Home Built 11 August 12th 08 11:42 PM
Hole template or Drawing for Altimeter Craggy Aero Home Built 5 November 15th 07 02:40 PM
3 1/8" instrument template [email protected] Home Built 4 April 15th 06 02:26 AM
Drilling a solid crankshaft Ole Moyer Home Built 8 November 2nd 05 05:17 AM
LS3 flaperon gap seal template needed Birdbones Soaring 2 May 14th 05 12:46 AM
