Drilling a solid crankshaft
Old November 1st 05, 08:27 AM
Ole Moyer
Default Drilling a solid crankshaft
Has anyone had experience with a solid Lycoming crankshaft modified
(drilled) to open oil passages required to control a constant speed prop?
I'm asking for a cousin with a friend who knows a guy with an airboat.
Old November 1st 05, 11:45 AM
Scott
Does he need a constant speed prop on the airboat???
Old November 1st 05, 02:15 PM
Cy Galley
They are already drilled! Need to remove front plug and insert rear plug in
the front of the crank. Can be done without disassembling the engine.
"Scott" wrote in message
Old November 1st 05, 03:55 PM
John Ammeter
I think he's referring to the hole drilled in the side of crankshaft;
the hole that allows the pressurized oil to enter the front hollow part
of the crankshaft.
I had an RV-6 with a Lycoming E2A engine and had planned to convert it
to constant speed. Assembled all the needed parts, governor, prop, nose
cone, etc and then pulled the old wood prop from my engine. Imagine my
delight when I discovered that the previous owner of the engine had
replaced the original crankshaft (which would have had the hole in the
side of the crankshaft) with a crankshaft that did NOT have the hole and
crossover tube.
John
Another Lycoming Crankshaft SB Doug Owning 13 July 20th 05 05:12 PM
crankshaft counterweights Dave Butler Owning 10 February 10th 05 04:08 PM
How to drill a cenetered hole in end of solid rod Scott Home Built 21 November 2nd 04 03:04 PM
Solid State Backup AI Dan Truesdell Instrument Flight Rules 20 January 15th 04 09:53 PM
Pictures Showing WWII Rotary Engine Crankshaft Arrangements: Where, Please ? Bob Military Aviation 8 November 8th 03 06:08 PM
