New SPOT messenger allows custom messages
Old January 9th 10, 12:03 AM posted to rec.aviation.soaring
Darryl Ramm
Default New SPOT messenger allows custom messages
On Jan 8, 3:37*pm, Darryl Ramm wrote:
On Jan 8, 10:03*am, Steve Koerner wrote:
If the puck talks BT or similar to the handset then it's only a matter
of time until it is hacked.
Unless the link is properly encrypted.
Steve
Why would that be a problem? :-)
I've not heard for sure that the link is Bluetooth, but that makes the
most sense. On a new current device like this I'd expect Bluetooth 2.1
SSP with automatic pairing for ease of use.
ANd I'd guess the link protocol is likely just serial over Bluetooth.
You send known text from the keyboard unit over the link to the SPOT.
That makes reverse engineering the key relatively easy. Once you have
that it is just a matter of sniffing the control protocols for getting
the device to do stuff. You can also hack the initial paring exchange
with a man it the middle attack. Once you have their protocols for
sending text messages you go implement that in software on your
favorite PDA etc. and you can have that link equally encrypted as the
original device is.
I expect Gloablstar to be very careful about limiting transmission
rates and that kind of thing is embedded pretty deep inside the "puck"
not something you can mess with over bluetooth.
Like I said I expect this to be hacked. All kinds of folks might want
to play with this.
Darryl
Oops it looks like it is not Bluetooth but 802.14.4. See
http://www.equipped.org/blog/?p=207 and http://www.equipped.org/blog/?p=190
Some other interesting snippets there as well.
I'm less familiar with 802.14.4 (and Zigbee) security. But again since
you can do data injection attacks key discovery should be possible.
Zigbee USB dongles or CF cards are readily available for easy
connectivity.
Darryl
Old January 9th 10, 04:05 AM posted to rec.aviation.soaring
Frank[_12_]
OK, I stand (or sit) corrected ;-)
TA
On Jan 8, 10:10*am, "Rob.Russell" wrote:
On Jan 7, 4:49*pm, Frank wrote:
It appears from the advertising material that this device is a
combination of GPS engine, map display, and SPOT transmitter. *If so,
the texting and 'custom messaging' feature is just what a current SPOT
unit allows, i.e. they are 'custom' in the sense that you can set them
up to send whatever text you want, but they are *not* dynamic - the
message text is set by editing your account information on the SPOT
site.
From the press release:
“For the first time, people will be able to type custom text messages
using the Earthmate PN-60w internal keyboard and then transmit
wirelessly to the unique DeLorme SPOT Communicator for sending
satellite messages around the globe,” said Caleb Mason, DeLorme Vice
President.
Also:
"Users can send freeform text messages using the PN-60w’s keyboard to
select individuals or groups from the field even from remote areas
world-wide."
So, now we're left with a couple of questions:
- Is "transmit wirelessly" legal for cockpit use in your jurisdiction?
- Is this wireless protocol documented and open enough that other
devices (say, the theoretical upcoming LX69000, or maybe even XCSoar
if the wireless protocol is 802.11 or Bluetooth) would be able to also
send the text messages?
- Can we buy this wireless-capable SPOT messenger without buying the
Delorme gizmo?
Old January 9th 10, 05:04 AM posted to rec.aviation.soaring
Tony[_5_]
On Jan 7, 4:50*pm, sisu1a wrote:
* We have been nagging SPOT to include altitude, but so far no
progress. *I think it will come, but I don't know when
Maybe once the Gliding community nags enough for them to move in it,
they can call they're new altitude equipped units 'G-SPOT'... which
might even make them come quicker.
-Paul
Paul,
Just last week Scientists said that doesnt exist!
Old January 12th 10, 01:55 PM posted to rec.aviation.soaring
Rob.Russell
This is truly heartbreaking news.
Zigbee/802.14.4 licensing allows for free applications, and for paid
applications, but it doesn't permit Open Source applications.
This means that XCSoar will have a very hard time working with the
puck, and KFLog Cumulus will have an even harder time . . . and for
completely bull**** reasons: http://en.wikipedia.org/wiki/ZigBee#Licensing
Rob.
Old January 12th 10, 09:25 PM posted to rec.aviation.soaring
Darryl Ramm
completely bull**** reasons:http://en.wikipedia.org/wiki/ZigBee#Licensing
Rob.
It is not clear this is a problem. You may not need to develop within
the Zigbee stack or link to anything. You may be able to do enough
using third party provided Zigbee drivers (like those that typically
come with the Zigbee capable CF Cards or USB dongles).
The EULA with this Delorme device will he interesting to read.
Darryl
Old January 13th 10, 02:55 AM posted to rec.aviation.soaring
Rob.Russell
That's why developing with XCSoar for Windows Mobile might be
possible, but developing with XCSoar for Android or KFLog/Cumulus for
Maemo will be much more of a challenge.
Agreed! As will the service contract.
SPOT messenger [email protected] Soaring 32 June 17th 08 09:37 PM
SPOT messenger [email protected] Piloting 19 June 17th 08 04:42 PM
SPOT Messages? [email protected] Soaring 5 May 15th 08 04:21 PM
SPOT Satellite Messenger [email protected] Soaring 9 January 3rd 08 06:30 PM
SPOT Satellite Messenger Marc Ramsey[_2_] Soaring 7 October 3rd 07 10:30 PM
