SPOT Messages?
Old May 14th 08, 06:08 PM posted to rec.aviation.soaring
Default SPOT Messages?
When configuring a new SPOT there are three areas in which you can
include custom messages. The OK message is easy, "ABC is still flying
and OK", the Help message is easy as well, which might be, "ABC has
landed out at the coordinates provided and is OK. My cell number is
xxx xxx xxxx." The 911 message is the sticker. Any ideas on what the
cavalry will need in this message? Something dire like, "This is a
life threatening emergency. Glider (N number) has crashed and is in
need of immediate help at the GPS coordinates provided." And ideas on
this?
Old May 14th 08, 06:22 PM posted to rec.aviation.soaring
chris
this?
for me ok=ok i make no mention of flying or not, because i may wish
to send a ok message after I've landed somewhere. I have the tracking
feature also so i have no intention of sending ok messages while
flying, that is too distracting.
Help = landed out send trailer and retrieve crew
under 911 my message reads:
"My primary [but not only] use of the Spot locator is for flying
sailplanes/gliders. Glider model X Nxxxx race # X.
My glider is also equipped with an ELT [Emergency Locator
Transmitter]. If triggered it will beep on 121.500 Mhz. This can
also be heard on old style manual tune AM radios at 1215 AM.
You may also try to reach me on aviation radio frequencies: 123.300,
123.500, 121.500 Mhz.
Cell 404-XXX-XXXX. My verizon phone is equipped with GPS Locate that
can be activated/located by emergency services if required.
I may also use this device for biking, hiking or other uses."
I should probably take out the hiking reference and just put that
under a different profile, just have not had time to set that up.
Chris
Old May 14th 08, 10:19 PM posted to rec.aviation.soaring
this?
for me ok=ok * i make no mention of flying or not, because i may wish
to send a ok message after I've landed somewhere. *I have the tracking
sailplanes/gliders. *Glider model X *Nxxxx * race # X.
Transmitter]. *If triggered it will beep on 121.500 Mhz. *This can
Chris
We@Post Mills Soaring Club, Post Mills, VT, have concluded that:
OK = "I have landed here. Come get me when the retrieve crew is
ready to. No rush." (The coordinates come with the notification sent
to the designees.)
HELP = "I have landed. I am OK, but I need non-emergency assistance
ASAP!" i.e., I don't wait for the day's flying activities at the
home field to end but send my retrieve folks now because there are
issues that are best solved while there may still be daylight with
enough hands, etc.).
911 = Just that. I am well enough tp press ths SPOT button, I'm
callng for EMERGENCY assistance at this location.
If I can't depress the 911 button, in all likelihood the aircraft's
ELT will already be activated...
And, Tracking = optional for friends, family and interested bystanders
granted access to one's SPOT account who want the thrill of knowing
where the winning pilot is on course.
Skip
N114JS
Old May 15th 08, 04:28 AM posted to rec.aviation.soaring
chris
Nevermind that rubbish about an AM radio, someone told me that years
ago and I believed them. A little thinking or testing proves it
wrong.
Chris
Old May 15th 08, 04:21 PM posted to rec.aviation.soaring
Al G[_1_]
"chris" wrote in message
wrong.
Chris
1215 AM = 1215khz = 1.215Mhz not 121.5Mhz, off by a factor of 100.
Al G
AFTN System Access??? Need to Send/Receive a Few AFTN messages NW_Pilot Instrument Flight Rules 4 October 7th 11 02:29 PM
AFTN System Access??? Need to Send/Receive a Few AFTN messages NW_Pilot Piloting 1 March 9th 07 07:44 PM
* water and bladders - 12 messages, 12 authors Peter Smith Soaring 0 February 5th 07 12:51 AM
Web site reply messages? Ed Majden Military Aviation 7 April 27th 04 06:56 PM
is anyone else having trouble getting messages downloaded? Gilan Home Built 1 August 22nd 03 01:49 AM
