Anyone ever purchase a used glider with an experimental certificate,say for example, an ASW 19b, and change to a standard certificate?
I understand that some gliders were imported and flown as experimental such as jantars, due to govermental restrictions on reciprocal airworthiness circumstance. The ASW 19b has been given U.S. standard certificates. Just wondering Scott W. |
On Wed, 13 Jan 2010 04:02:38 +0000, shkdriver wrote:
Anyone ever purchase a used glider with an experimental certificate,say for example, an ASW 19b, and change to a standard certificate? I understand that some gliders were imported and flown as experimental such as jantars, due to govermental restrictions on reciprocal airworthiness circumstance. The ASW 19b has been given U.S. standard certificates. Just wondering Scott W. I looked into this recently and came up with the following, I didn't actually try to do this as I didn't buy the glider in the end. But the exercise was worthwhile.. First make sure that an equivalent model of the glider (make and model) has been certified by the FAA and as a cosequence there is a Type Certificate Data Sheet (TCDS) available for the type from the FAA (you can find these online by searching for tcds at www.faa.gov). Read the the description there and, at least for the types I was looking at, it specifies the individual serial numbers of gliders that shoudl be are conformant with the requirements of the TCDS, in my case it was listed as a bunch of specific serial numbers for earlier builds and a contiguous block for later builds of the type. As well as any mandatory modifications that need to be carried out for the FAA Standard CofA. One of the requirements stated in the TCDS is specific wording on the original Certificate of Airworthiness for Export from Germany (where the glider came from, the owner of the glider had this in his well documented glider, not sure how you would get one of these otherwise, perhaps the manufacturer or the LDB in the case of germany) My stumbling block was that the FAA TCDS specified particular wording that should be present in the Export C of A from Germany, this wasn't present in exactly the specified words for the the particular glider I was looking at (even though that particular glider was specifically listed as conformant by serial number). I think this was a timing issue in terms of which document was issued first... i never resolved whether this might be an issue. The final step is a rigorous inspection of the aircraft by an FAA designated Inspector (that the FAA do for free apparently...!! ), I forget the formal name for this inspection. But essentially it is just a very thorough Anunual Inspection. Once complete its a little bit of paper work and you are on the Standard Airworthiness Category. Let me know if you succeed, I'll be doing this sometime soon,.. Peter |
On Jan 13, 4:01*am, Peter wrote:
On Wed, 13 Jan 2010 04:02:38 +0000, shkdriver wrote: Anyone ever purchase a used glider with an experimental certificate,say for example, an ASW 19b, and change to a standard certificate? I understand that some gliders were imported and flown as experimental such as jantars, due to govermental restrictions on reciprocal airworthiness circumstance. The ASW 19b has been given U.S. standard certificates. Just wondering Scott W. I looked into this recently and came up with the following, I didn't actually try to do this as I didn't buy the glider in the end. But the exercise was worthwhile.. First make sure that an equivalent model of the glider (make and model) has been certified by the FAA and as a cosequence there is a Type Certificate Data Sheet (TCDS) available for the type from the FAA (you can find these online by searching for tcds atwww.faa.gov). Read the the description there and, at least for the types I was looking at, it specifies the individual serial numbers of gliders that shoudl be are conformant with the requirements of the TCDS, in my case it was listed as a bunch of specific serial numbers for earlier builds and a contiguous block for later builds of the type. As well as any mandatory * modifications that need to be carried out for the FAA Standard CofA. One of the requirements stated in the TCDS is specific wording on the original Certificate of Airworthiness for Export from Germany (where the glider came from, the owner of the glider had this in his well documented glider, not sure how you would get one of these otherwise, perhaps the manufacturer or the LDB in the case of germany) My stumbling block was that the FAA TCDS specified particular wording that should be present in the Export C of A from Germany, this wasn't present in exactly the specified words for the the particular glider I was looking at (even though that particular glider was specifically listed as conformant by serial number). I think this was a timing issue in terms of which document was issued first... i never resolved whether this might be an issue. The final step is a rigorous inspection of the aircraft by an FAA designated Inspector (that the FAA do for free apparently...!! ), I forget the formal name for this inspection. But essentially it is just a very thorough Anunual Inspection. Once complete its a little bit of paper work and you are on the Standard Airworthiness Category. Let me know if you succeed, I'll be doing this sometime soon,.. Peter The "Import C of A (certificate of airworthiness) done by the FAA inspector is not an annual inspection. It is an inspection to ensure that the aircraft conforms to the Type Certificate (Type Data Certificate). An annual inspection will have to be done by your favorite IA. When I have imported aircraft I have hired a Designated Airworthiness Representative to perform the C of A inspection for me. They are not free like the FAA but they generally are more knowledgeable and easier to work with. The worse case scenario is being assigned a FAA inspector who knows nothing about your glider. I have heard of aircraft being rejected for ridiculous reasons. Most of these inspections consist of the inspector looking over the paperwork very thoroughly and then a quick examination of the aircraft while comparing it to the type certificate. Any modifications make it very tough to pass the inspection. |
On Jan 13, 8:34*am, lanebush wrote:
On Jan 13, 4:01*am, Peter wrote: On Wed, 13 Jan 2010 04:02:38 +0000, shkdriver wrote: Anyone ever purchase a used glider with an experimental certificate,say for example, an ASW 19b, and change to a standard certificate? I understand that some gliders were imported and flown as experimental such as jantars, due to govermental restrictions on reciprocal airworthiness circumstance. The ASW 19b has been given U.S. standard certificates. Just wondering Scott W. I looked into this recently and came up with the following, I didn't actually try to do this as I didn't buy the glider in the end. But the exercise was worthwhile.. First make sure that an equivalent model of the glider (make and model) has been certified by the FAA and as a cosequence there is a Type Certificate Data Sheet (TCDS) available for the type from the FAA (you can find these online by searching for tcds atwww.faa.gov). Read the the description there and, at least for the types I was looking at, it specifies the individual serial numbers of gliders that shoudl be are conformant with the requirements of the TCDS, in my case it was listed as a bunch of specific serial numbers for earlier builds and a contiguous block for later builds of the type. As well as any mandatory * modifications that need to be carried out for the FAA Standard CofA. One of the requirements stated in the TCDS is specific wording on the original Certificate of Airworthiness for Export from Germany (where the glider came from, the owner of the glider had this in his well documented glider, not sure how you would get one of these otherwise, perhaps the manufacturer or the LDB in the case of germany) My stumbling block was that the FAA TCDS specified particular wording that should be present in the Export C of A from Germany, this wasn't present in exactly the specified words for the the particular glider I was looking at (even though that particular glider was specifically listed as conformant by serial number). I think this was a timing issue in terms of which document was issued first... i never resolved whether this might be an issue. The final step is a rigorous inspection of the aircraft by an FAA designated Inspector (that the FAA do for free apparently...!! ), I forget the formal name for this inspection. But essentially it is just a very thorough Anunual Inspection. Once complete its a little bit of paper work and you are on the Standard Airworthiness Category. Let me know if you succeed, I'll be doing this sometime soon,.. Peter The "Import C of A (certificate of airworthiness) done by the FAA inspector is not an annual inspection. *It is an inspection to ensure that the aircraft conforms to the Type Certificate (Type Data Certificate). *An annual inspection will have to be done by your favorite IA. *When I have imported aircraft I have hired a Designated Airworthiness Representative to perform the C of A inspection for me. They are not free like the FAA but they generally are more knowledgeable and easier to work with. *The worse case scenario is being assigned a FAA inspector who knows nothing about your glider. *I have heard of aircraft being rejected for ridiculous reasons. *Most of these inspections consist of the inspector looking over the paperwork very thoroughly and then a quick examination of the aircraft while comparing it to the type certificate. *Any modifications make it very tough to pass the inspection.- Hide quoted text - - Show quoted text - Ditto on the DAR. I was VERY fortunate to work with a good one in the past. Since he had been through the drill several times, he understood the glider world. The last thing you want is a guy who has never seen a glider before. Many of the things we take as routine in gliding (say inter-changeable tips) can throw a novice for loop. Suggest you find out from your local gliding clubs/FBOs who the "good guys" are. |
On Jan 12, 8:02*pm, shkdriver
wrote: Anyone ever purchase a used glider with an experimental certificate,say for example, an ASW 19b, and change to a standard certificate? I understand that some gliders were imported and flown as experimental such as jantars, due to govermental restrictions on reciprocal airworthiness circumstance. The ASW 19b has been given U.S. standard certificates. Just wondering Scott W. -- shkdriver I purchased a used ASW19B that had no US CofA. It was an import. As long as you have the Original Export CofA from the manufacturer and take it to a DAR you should have no problem. I did mine through Dave Monti in Minden and he did the annual along with it. The FAA DAR directory is here and you want the DAR maintenance guys. http://www.faa.gov/other_visit/aviat...rdirectory.pdf |
My ASW 15 went from standard to experimental shortly after it was
imported (the original owner had water bags installed). When I got it I had it switched back to standard after removing the ballast system. It was no big deal. The DAR inspected the glider and the only thing I can remember that he wanted changed was the fuses needed to be labeled. I can't even remember why I did it. Possibly lower insurance cost and no program letter or limitations (some of which were No Night Flight, No Passengers and No Towing Gliders). |
On Wed, 13 Jan 2010 05:34:49 -0800, lanebush wrote:
On Jan 13, 4:01Â*am, Peter wrote: On Wed, 13 Jan 2010 04:02:38 +0000, shkdriver wrote: Anyone ever purchase a used glider with an experimental certificate,say for example, an ASW 19b, and change to a standard certificate? I understand that some gliders were imported and flown as experimental such as jantars, due to govermental restrictions on reciprocal airworthiness circumstance. The ASW 19b has been given U.S. standard certificates. Just wondering Scott W. I looked into this recently and came up with the following, I didn't actually try to do this as I didn't buy the glider in the end. But the exercise was worthwhile.. First make sure that an equivalent model of the glider (make and model) has been certified by the FAA and as a cosequence there is a Type Certificate Data Sheet (TCDS) available for the type from the FAA (you can find these online by searching for tcds atwww.faa.gov). Read the the description there and, at least for the types I was looking at, it specifies the individual serial numbers of gliders that shoudl be are conformant with the requirements of the TCDS, in my case it was listed as a bunch of specific serial numbers for earlier builds and a contiguous block for later builds of the type. As well as any mandatory modifications that need to be carried out for the FAA Standard CofA. One of the requirements stated in the TCDS is specific wording on the original Certificate of Airworthiness for Export from Germany (where the glider came from, the owner of the glider had this in his well documented glider, not sure how you would get one of these otherwise, perhaps the manufacturer or the LDB in the case of germany) My stumbling block was that the FAA TCDS specified particular wording that should be present in the Export C of A from Germany, this wasn't present in exactly the specified words for the the particular glider I was looking at (even though that particular glider was specifically listed as conformant by serial number). I think this was a timing issue in terms of which document was issued first... i never resolved whether this might be an issue. The final step is a rigorous inspection of the aircraft by an FAA designated Inspector (that the FAA do for free apparently...!! ), I forget the formal name for this inspection. But essentially it is just a very thorough Anunual Inspection. Once complete its a little bit of paper work and you are on the Standard Airworthiness Category. Let me know if you succeed, I'll be doing this sometime soon,.. Peter The "Import C of A (certificate of airworthiness) done by the FAA inspector is not an annual inspection. It is an inspection to ensure that the aircraft conforms to the Type Certificate (Type Data Certificate). An annual inspection will have to be done by your favorite IA. When I have imported aircraft I have hired a Designated Airworthiness Representative to perform the C of A inspection for me. They are not free like the FAA but they generally are more knowledgeable and easier to work with. The worse case scenario is being assigned a FAA inspector who knows nothing about your glider. I have heard of aircraft being rejected for ridiculous reasons. Most of these inspections consist of the inspector looking over the paperwork very thoroughly and then a quick examination of the aircraft while comparing it to the type certificate. Any modifications make it very tough to pass the inspection. Yup, that's the name I couldn't remember, A Conformity Inspection or some such, its to ensure compliance with the TCDS requirements, check for unauthorised/unapproved work or mods and to trawl paperwork in detail, I was told that it was like having a combination of Annual and Ramp inspection all in one nice visit. You would also need to have the aircraft current in its normal Annual before this was done too... probably not a bad thing to help you prep the docs for the more detailed inspection. Peter |
A few days ago I was looking for something unrelated and came across
this document (a bit old) that may help you. This one is canceled, but it may help lead you to the current procedure. The document: 8130.15 dated 09/14/1979 Airworthiness Certification of "Prematurely" Exported Gliders http://www.airweb.faa.gov/Regulatory...gh light=8130 You might also try a google search like: convert type certificate experimental site:faa.gov |
I know a good guy DAR at El Monte CA if needed.
BT Ditto on the DAR. I was VERY fortunate to work with a good one in the past. Since he had been through the drill several times, he understood the glider world. The last thing you want is a guy who has never seen a glider before. Many of the things we take as routine in gliding (say inter-changeable tips) can throw a novice for loop. Suggest you find out from your local gliding clubs/FBOs who the "good guys" are. |
On Jan 12, 11:02*pm, shkdriver
wrote: Anyone ever purchase a used glider with an experimental certificate,say for example, an ASW 19b, and change to a standard certificate? I understand that some gliders were imported and flown as experimental such as jantars, due to govermental restrictions on reciprocal airworthiness circumstance. The ASW 19b has been given U.S. standard certificates. Just wondering Scott W. -- shkdriver The question I would ask is why? '19 is old enough that it would almost certainly have a permanent Experimental C of A. Thus no need for program letters and such. Condition inspection by A&P, IA not required. I would be astonished if it would add any value. Only reason I can think of might be a life insurance policy that says - no experimental aircraft. FWIW UH |
FAA Revoking Standard Airworthiness Certificate DG-505 | NG | Soaring | 32 | February 16th 17 02:23 PM |
USA Glider Experimental Airworthiness Certificate | charlie foxtrot | Soaring | 4 | April 15th 06 05:04 AM |
Weird Experimental Certificate wording - Normal? | Noel Luneau | Soaring | 12 | January 11th 05 06:11 PM |
Weird Experimental Certificate wording - Normal? | Noel Luneau | Soaring | 7 | January 11th 05 02:53 PM |
PA-32 on Experimental Certificate | Mike Granby | Owning | 3 | July 21st 04 03:04 AM |
