contrails
Old January 16th 10, 10:36 PM posted to rec.aviation.soaring
Brian Whatcott
Default Global Warming/Climate Change (was contrails)
Gary Evans wrote:
http://tinyurl.com/yedncvo
This is a graphic by Monte Heib, who is called in the URL below "an
amateur climatologist" though he is credible in mine engineering.
Amusing that his graphic is "After Scotese"
who is a paleo-geologist.
"After..." That's a term used of works of art :-)
http://adamant.typepad.com/seitz/200...ologist-o.html
Brian W
  #242
Old January 17th 10, 05:37 AM posted to rec.aviation.soaring
delboy
On 8 Jan, 11:20, Tom Gardner wrote:
On Jan 8, 7:59*am, delboy wrote:
On 8 Jan, 06:57, Mark Jardini wrote:
While at one time it was valid to judge what was going on in the whole
world by what was happening in England, those days are passed. Your
local climate has little to say about what is globally in play with
climate. In fact, England should get a good deal colder with the
progression of global warming, the seas will dilute and the saline
gradient that drags warm water to your shores will cease to flow. It
would be catastrophic to many fisheries as well.
Mark Jardini
I did also mention Northern Europe and North America, so I was not
being a little Englander. Northern France and the other European
countries are also having a bad time.
The argument you are putting forward is that sea ice and the snow on
top of it will melt due to global warming and, being lower in salt
content, will dilute the salinity of oceans. In fact I wouldn't be
surprised to see an increase in sea ice this year. These things are
cyclical, and apparently there was little sea ice in the Medieval mini
warm period between the 9th and 13th Centuries. This allowed the
Vikings to settle in Iceland and Greenland. The ones in Greenland were
wiped out by cold weather in the 15th century. See:
http://en.wikipedia.org/wiki/Little_Ice_Age
The main reason our weather is so cold at the moment is that the
airmass is coming from the cold north-east polar regions due to a
blocking anticyclone, rather than from the more normal, more
temperate, south-west direction.
Derek Copeland
Don't forget Mark's second point, which appears to be the more
significant in the long term. If the Gulf Stream shuts down then
olar bears will roam London (same latitude as Churchill in
Canada), presuming they haven't become extinct beforehand - Hide quoted text -
- Show quoted text -
After a month in a mini ice age, the UK winter weather has become its
normal mild and moist self, so the Gulf Stream must still be working.
So sorry polar bears, your habitat range won't be extending to the
British Isles yet!
Derek Copeland
  #243
Old January 17th 10, 07:52 AM posted to rec.aviation.soaring
Fred the Red Shirt
Default contrails
On Dec 23 2009, 7:10 pm, Bruce Hoult wrote:
This is even before you get into the discovery that you can feed
totally random data into Mann's program and it still produces a
"hockey stick".
I don't believe that, but:
If the model is based on causality and not merely on correlation
then the long term prediction should be independent of the past
temperatures.
FF
  #244
Old January 17th 10, 08:04 AM posted to rec.aviation.soaring
Tom Gardner
Mark Jardini
Derek Copeland
British Isles yet!
Derek Copeland
I wrote nothing whatsoever that would justify your comment,
nor did I imply it.
Your attempt to associate me with such ignorant concepts
(not knowing the difference between climate and weather)
is offensive. *Please do not do it again*.
Unfortunately this kind of misrepresentation and
cherry-picking data appears to be all too prevalent
in the denialist community. Anybody reading your
comments with an open mind would start to doubt your
sincerity. It does the denialist cause no good whatsoever.
  #245
Old January 17th 10, 12:42 PM posted to rec.aviation.soaring
delboy
British Isles yet!
Derek Copeland
nor did I imply it.
sincerity. It does the denialist cause no good whatsoever.- Hide quoted text -
Being a bit touchy aren't we Tom? If you want to present AGW/Climate
Change as a religion (which it seems to have become), then I am
neither a believer or a disbeliever (denialist), but an agnostic. The
latest data on World temperatures, which show a slight cooling, do not
correlate with the theory, so that is why.
Unfortunately the UK Government have taken AGW into its policies, so
they have introduced various taxes and duties that are based on CO2
emissions. They are therefore trying to control and tax our population
based on an unproven scientific theory, which is what I particularly
object to!
Derek Copeland
  #246
Old January 18th 10, 01:06 AM posted to rec.aviation.soaring
Tom[_10_]
delboy wrote in
its normal mild and moist self, so the Gulf Stream must still be
working. So sorry polar bears, your habitat range won't be
extending to the British Isles yet!
Derek Copeland
nor did I imply it.
quoted text -
No, I'm not. I dislike other people putting silly
opinions/statements into my "mouth".
object to!
I'm sorry, I seem to have missed the causal connection
between those beliefs and your comments that I object to.
  #247
Old January 18th 10, 03:30 AM posted to rec.aviation.soaring
Eric Greenwell
Default contrails
"hockey stick".
Bruce, the "hockey stick" is not dependent on Dr. Mann or his program
(I'm not sure what program you are talking about, but it doesn't
matter). Dr. Mann was the first develop it, but others have corroborated
his work using different methods. A decent explanation:
http://www.skepticalscience.com/broken-hockey-stick.htm
If you want to delve into it more than that, search for "hockey stick"
on the same site.
  #248
Old January 18th 10, 07:44 AM posted to rec.aviation.soaring
delboy
Derek Copeland
nor did I imply it.
quoted text -
object to!
between those beliefs and your comments that I object to.- Hide quoted text -
Eric,
Obviously you must have some professional connection to the AGW scam.
Climate is surely just the long term average of weather events. Any
increase in atmospheric CO2 does not appear to have caused the
predicted increase in Global temperatures. Maybe the 'natural'
concentration of CO2 already gives the maximum greenhouse effect and
increasing it causes little or no difference. In any case CO2 is food
for plants, so I would expect to see an increase in plant growth, as
long as there are no other limiting factors.
Derek Copeland
  #249
Old January 18th 10, 09:06 AM posted to rec.aviation.soaring
Tom Gardner
Derek Copeland
nor did I imply it.
quoted text -
object to!
Eric,
I think the same assertion could be made about you, but on the
opposing side!
  #250
Old January 18th 10, 11:10 AM posted to rec.aviation.soaring
delboy
Derek Copeland
nor did I imply it.
quoted text -
object to!
Eric,
opposing side!- Hide quoted text -
I am not a professional climatologist, so I have no financial interest
in the topic of AGW, other than a desire not to be controlled and
taxed by my Government on the basis of CO2 emissions. I am a trained
and qualified scientist in a different field, so I am used to
evaluating data. I think I can spot dodgy and biased data being used
for political purposes when I see it.
Derek Copeland
contrails No Name Aviation Photos 3 June 22nd 07 01:47 PM
Contrails Darkwing Piloting 21 March 23rd 07 05:58 PM
Contrails Kevin Dunlevy Piloting 4 December 13th 06 08:31 PM
Contrails Steven P. McNicoll Piloting 17 December 10th 03 10:23 PM
