contrails
Old June 5th 07, 02:09 AM posted to alt.binaries.pictures.aviation
Default contrails
It's not just jets. WW2 bombers, B17s and the like, also left contrails when they were on high altitude runs. Combustion produces water vapor, which under the right conditions condenses into a cloudlike trail of visible water droplets.
Contrails (water vapor condensation) can also form in wingtip vortices or propeller tips especially when pulling high G loads (high angle of attack accelerated turns) IIRC they happen in these contexts as the low pressure area over the wing (or prop) grows and the low pressure air can't hold as much water vapor as higher-pressure air can, so the relative humidity increases eventually to 100% of capacity at which point the H2O vapor condenses out as droplets.
Old June 6th 07, 01:22 AM posted to alt.binaries.pictures.aviation
whogoes
Default contrails
The other point about this is that when the source of pressure change is
removed, the air is essentially unchanged from its equilibrium state and the
water goes back into its gaseous form. However, the contrail from an engine
is adding substantial amounts of water to the atmosphere, hence this
contrail lasts substantially longer and decays only through dispersion..
news:3J29i.3772$jW6.3719@trnddc01...
Old June 6th 07, 02:16 AM posted to alt.binaries.pictures.aviation
Scubabix
Default contrails
Actually ice crystals.
Correct except that's not a contrail, just vapor created as you described.
Rob
Old June 22nd 07, 01:47 PM posted to alt.binaries.pictures.aviation
Default contrails
apologies for late reply:- Contrails will only form where the
condensed water droplets freeze. If they don't freeze they will
evaporate or just disperse.
As for the Gubmint conspiracy, how thick can people be? Yeah I know
How thick are two short planks.
"I have a cunning plan"
Posted with NewsLeecher v3.8 Final
Web @ http://www.newsleecher.com/?usenet
Contrails Darkwing Piloting 21 March 23rd 07 05:58 PM
Contrails Kevin Dunlevy Piloting 4 December 13th 06 08:31 PM
Contrails pictures GTH Home Built 1 June 3rd 05 02:02 PM
Contrails Steven P. McNicoll Piloting 17 December 10th 03 10:23 PM
Engine Contrails Bernie Samms Simulators 0 October 20th 03 11:21 AM
