Has anyone had success with loading two 15m (Cobra or similar)
trailers into one shipping container? Better yet, have the two trailers come out nicely at the other end? Seems to me that one needs to go above the other in a high-cube: Tail first up top and roll the other underneath... Or both the axles removed and use a big Johnson bar (and a few cans of spray paint). Thanks, Jim |
On Feb 16, 1:50*pm, JS wrote:
Has anyone had success with loading two 15m (Cobra or similar) trailers into one shipping container? Better yet, have the two trailers come out nicely at the other end? Seems to me that one needs to go above the other in a high-cube: Tail first up top and roll the other underneath... Or both the axles removed and use a big Johnson bar (and a few cans of spray paint). Thanks, Jim IIRC, Karl Striedieck and the Eagle Field boys did this for one of the World comps not that long ago and posted pictures. I'm sure Karl or John Good could fill you in. P3 |
Two Cobra/Komet trailers will fit in a normal container with the axles
removed. Pictures have been sent to Jim. Karl Striedieck "Papa3" wrote in message ... On Feb 16, 1:50 pm, JS wrote: Has anyone had success with loading two 15m (Cobra or similar) trailers into one shipping container? Better yet, have the two trailers come out nicely at the other end? Seems to me that one needs to go above the other in a high-cube: Tail first up top and roll the other underneath... Or both the axles removed and use a big Johnson bar (and a few cans of spray paint). Thanks, Jim IIRC, Karl Striedieck and the Eagle Field boys did this for one of the World comps not that long ago and posted pictures. I'm sure Karl or John Good could fill you in. P3 |
On Feb 16, 7:53*pm, "Karl Striedieck" wrote:
Two Cobra/Komet trailers will fit in a normal container with the axles removed. Pictures have been sent to Jim. Karl Striedieck"Papa3" wrote in message ... On Feb 16, 1:50 pm, JS wrote: Has anyone had success with loading two 15m (Cobra or similar) trailers into one shipping container? Better yet, have the two trailers come out nicely at the other end? Seems to me that one needs to go above the other in a high-cube: Tail first up top and roll the other underneath... Or both the axles removed and use a big Johnson bar (and a few cans of spray paint). Thanks, Jim IIRC, Karl Striedieck and the Eagle Field boys did this for one of the World comps not that long ago and posted pictures. * I'm sure Karl or John Good could fill you in. P3 Since we are on this subject: has anyone ever tried to ship a trailer/ passenger car combination in a 53ft van trailer? Does anyone know a shipping company that would do a load like this? I am still looking for a way to get my rig to UT without putting 4k miles on it and it should fit. Uli Neumann 'GM' |
Trucking companies are always looking to fill their trucks with
anything instead of "dead heading" them (running the trailer empty). Since you're looking for pretty much an empty truck, you may not know what - if anything - is going to happen until right before shipping. Not much fun. The alternate of booking the trailer in advance you will probably find more expensive than it's worth. Loading a car and glider trailer into a 48' or 53' trailer is not as simple as it may seem. Easiest with a "straight" trailer, not one with a "dance floor" like a moving van. You must arrange to load and unload at warehouses or loading docks which have ample room (and a shallow enough ramp angle) to maneuver the glider trailer from street level to dock height and into the truck. Plan to provide all the straps to secure the load. Most trucks have E-track in the walls, but there's no guarantee (it might even be a flatbed). The truck may show up with only load bars for load control, or straps which look like hell. Examine your car and trailer to find the best way to secure them. Some ways of strapping the car or trailer will make the suspension more rigid, so the contents might not ride as you'd prefer. You may need 4 or 6x 2" 3000+ Lb ratchet straps with hooks on the ends, then 2 E- track to D-ring adapters for each strap. I believe that to be legal on a flatbed requires three straps for each piece. You can probably return what you don't use, but may lose straps as you will not necessarily be there to load and unload. E-track, for example: http://www.uscargocontrol.com/etrack...655140931a03f1 Strap: http://www.uscargocontrol.com/ratche...afb8b38895e1ac D-ring adapter: http://www.uscargocontrol.com/etrack...655140931a03f1 or http://www.uscargocontrol.com/6etrac...737ca867b64b01 Also look at this site for any moving supplies you can imagine. www.newhaven-usa.com Start by contacting trucking companies in the Salt Lake area and around home. And here's one link for a starter. www.dead-heading.com/ Jim On Feb 16, 7:55*pm, GM wrote: Since we are on this subject: has anyone ever tried to ship a trailer/ passenger car combination in a 53ft van trailer? Does anyone know a shipping company that would do a load like this? I am still looking for a way to get my rig to UT without putting 4k miles on it and it should fit. Uli Neumann 'GM' |
On Feb 16, 9:43*pm, JS wrote:
* Trucking companies are always looking to fill their trucks with anything instead of "dead heading" them (running the trailer empty). Since you're looking for pretty much an empty truck, you may not know what - if anything - is going to happen until right before shipping. Not much fun. The alternate of booking the trailer in advance you will probably find more expensive than it's worth. * Loading a car and glider trailer into a 48' or 53' trailer is not as simple as it may seem. Easiest with a "straight" trailer, not one with a "dance floor" like a moving van. You must arrange to load and unload at warehouses or loading docks which have ample room (and a shallow enough ramp angle) to maneuver the glider trailer from street level to dock height and into the truck. Plan to provide all the straps to secure the load. Most trucks have E-track in the walls, but there's no guarantee (it might even be a flatbed). The truck may show up with only load bars for load control, or straps which look like hell. Examine your car and trailer to find the best way to secure them. Some ways of strapping the car or trailer will make the suspension more rigid, so the contents might not ride as you'd prefer. You may need 4 or 6x 2" 3000+ Lb ratchet straps with hooks on the ends, then 2 E- track to D-ring adapters for each strap. * I believe that to be legal on a flatbed requires three straps for each piece. You can probably return what you don't use, but may lose straps as you will not necessarily be there to load and unload. * E-track, for example:http://www.uscargocontrol.com/etrack...2.html?zenid=5... * Strap:http://www.uscargocontrol.com/ratche...083.html?zenid... * D-ring adapter:http://www.uscargocontrol.com/etrack...enid=53c9c95b2... * orwww.uscargocontrol.com/6etrackropetieoff-p-185.html?zenid=5f59e9288b3... * Also look at this site for any moving supplies you can imagine.www.newhaven-usa.com * Start by contacting trucking companies in the Salt Lake area and around home. And here's one link for a starter.www.dead-heading.com/ Jim On Feb 16, 7:55*pm, GM wrote: Since we are on this subject: has anyone ever tried to ship a trailer/ passenger car combination in a 53ft van trailer? Does anyone know a shipping company that would do a load like this? I am still looking for a way to get my rig to UT without putting 4k miles on it and it should fit. Uli Neumann 'GM' Seeing as most freight trucks get 6-7 at best mpg and average price of diesel is about $2.75 per gallon that's about .045 cents per mile just for fuel X 4000 miles or is that one way half 2000 miles even at $1 per mile that's $2K? I know I own and operate 10 of these guzziling beasts but I run tankers so unless you run your trailer through a blender and add water I couldn't help you. Now my diesel pick up (4 wheel drive Chevy) gets about 16 mpg that brings the operating cost to more like .17-.18 cents per mile. I've got a friend that runs freight vans all 48 states that's based in Las Vegas Nv. where's your trailer originating from? You might look for a flat bed that will haul a LTL. Much easier to secure a load on a flat bed. |
On Feb 17, 2:20*am, glidergeek wrote:
On Feb 16, 9:43*pm, JS wrote: * Trucking companies are always looking to fill their trucks with anything instead of "dead heading" them (running the trailer empty). Since you're looking for pretty much an empty truck, you may not know what - if anything - is going to happen until right before shipping. Not much fun. The alternate of booking the trailer in advance you will probably find more expensive than it's worth. * Loading a car and glider trailer into a 48' or 53' trailer is not as simple as it may seem. Easiest with a "straight" trailer, not one with a "dance floor" like a moving van. You must arrange to load and unload at warehouses or loading docks which have ample room (and a shallow enough ramp angle) to maneuver the glider trailer from street level to dock height and into the truck. Plan to provide all the straps to secure the load. Most trucks have E-track in the walls, but there's no guarantee (it might even be a flatbed). The truck may show up with only load bars for load control, or straps which look like hell. Examine your car and trailer to find the best way to secure them. Some ways of strapping the car or trailer will make the suspension more rigid, so the contents might not ride as you'd prefer. You may need 4 or 6x 2" 3000+ Lb ratchet straps with hooks on the ends, then 2 E- track to D-ring adapters for each strap. * I believe that to be legal on a flatbed requires three straps for each piece. You can probably return what you don't use, but may lose straps as you will not necessarily be there to load and unload. * E-track, for example:http://www.uscargocontrol.com/etrack...2.html?zenid=5... * Strap:http://www.uscargocontrol.com/ratche...083.html?zenid... * D-ring adapter:http://www.uscargocontrol.com/etrack...enid=53c9c95b2... * orwww.uscargocontrol.com/6etrackropetieoff-p-185.html?zenid=5f59e9288b3... * Also look at this site for any moving supplies you can imagine.www.newhaven-usa.com * Start by contacting trucking companies in the Salt Lake area and around home. And here's one link for a starter.www.dead-heading.com/ Jim On Feb 16, 7:55*pm, GM wrote: Since we are on this subject: has anyone ever tried to ship a trailer/ passenger car combination in a 53ft van trailer? Does anyone know a shipping company that would do a load like this? I am still looking for a way to get my rig to UT without putting 4k miles on it and it should fit. Uli Neumann 'GM' Seeing as most freight trucks get 6-7 at best mpg and average price of diesel is about $2.75 per gallon that's about .045 cents per mile just for fuel X 4000 miles or is that one way half 2000 miles even at $1 per mile that's $2K? I know I own and operate 10 of these guzziling beasts but I run tankers so unless you run your trailer through a blender and add water I couldn't help you. Now my diesel pick up (4 wheel drive Chevy) gets about 16 mpg that brings the operating cost to more like .17-.18 cents per mile. I've got a friend that runs freight vans all 48 states that's based in Las Vegas Nv. where's your trailer originating from? You might look for a flat bed that will haul a LTL. Much easier to secure a load on a flat bed.- Hide quoted text - - Show quoted text - JS and glidergeek, excellent info here! I am considering driving from SC to UT using my Diesel Jetta, which gets around 35mpg with a trailer at moderate speeds. My problem is that with the 'generous' allotment of vacation time we tend to get in the US, I am pretty much blowing all my days. I am figuring on about 3-4 days per leg (2,100miles). So my motive is to save time by sending the rig ahead and to pick it up on the other end. Decisions, decisions .... GM |
Golf Mike,
One of my cousins, who lives in SC, is an independent trucker that makes cross-country trips all the time. Some time in the past, I enquired about him hauling my glider trailer from NC to CA and it wasn't going to be cheap. Something like US$4.00 per mile, if I remember correctly. I suppose he would find his own load for the return trip. If you are interested, I can e-mail him and get a price. But as JS stated, you'll need to arrange for places where the rig can be loaded and unloaded. Ray Lovinggood Carrboro, North Carolina, USA |
On Feb 17, 8:07*am, GM wrote:
On Feb 17, 2:20*am, glidergeek wrote: On Feb 16, 9:43*pm, JS wrote: * Trucking companies are always looking to fill their trucks with anything instead of "dead heading" them (running the trailer empty). Since you're looking for pretty much an empty truck, you may not know what - if anything - is going to happen until right before shipping. Not much fun. The alternate of booking the trailer in advance you will probably find more expensive than it's worth. * Loading a car and glider trailer into a 48' or 53' trailer is not as simple as it may seem. Easiest with a "straight" trailer, not one with a "dance floor" like a moving van. You must arrange to load and unload at warehouses or loading docks which have ample room (and a shallow enough ramp angle) to maneuver the glider trailer from street level to dock height and into the truck. Plan to provide all the straps to secure the load. Most trucks have E-track in the walls, but there's no guarantee (it might even be a flatbed). The truck may show up with only load bars for load control, or straps which look like hell. Examine your car and trailer to find the best way to secure them. Some ways of strapping the car or trailer will make the suspension more rigid, so the contents might not ride as you'd prefer. You may need 4 or 6x 2" 3000+ Lb ratchet straps with hooks on the ends, then 2 E- track to D-ring adapters for each strap. * I believe that to be legal on a flatbed requires three straps for each piece. You can probably return what you don't use, but may lose straps as you will not necessarily be there to load and unload. * E-track, for example:http://www.uscargocontrol.com/etrack...2.html?zenid=5... * Strap:http://www.uscargocontrol.com/ratche...083.html?zenid... * D-ring adapter:http://www.uscargocontrol.com/etrack...enid=53c9c95b2... * orwww.uscargocontrol.com/6etrackropetieoff-p-185.html?zenid=5f59e9288b3... * Also look at this site for any moving supplies you can imagine.www.newhaven-usa.com * Start by contacting trucking companies in the Salt Lake area and around home. And here's one link for a starter.www.dead-heading.com/ Jim On Feb 16, 7:55*pm, GM wrote: Since we are on this subject: has anyone ever tried to ship a trailer/ passenger car combination in a 53ft van trailer? Does anyone know a shipping company that would do a load like this? I am still looking for a way to get my rig to UT without putting 4k miles on it and it should fit. Uli Neumann 'GM' Seeing as most freight trucks get 6-7 at best mpg and average price of diesel is about $2.75 per gallon that's about .045 cents per mile just for fuel X 4000 miles or is that one way half 2000 miles even at $1 per mile that's $2K? I know I own and operate 10 of these guzziling beasts but I run tankers so unless you run your trailer through a blender and add water I couldn't help you. Now my diesel pick up (4 wheel drive Chevy) gets about 16 mpg that brings the operating cost to more like .17-.18 cents per mile. I've got a friend that runs freight vans all 48 states that's based in Las Vegas Nv. where's your trailer originating from? You might look for a flat bed that will haul a LTL. Much easier to secure a load on a flat bed.- Hide quoted text - - Show quoted text - JS and glidergeek, excellent info here! I am considering driving from SC to UT using my Diesel Jetta, which gets around 35mpg with a trailer at moderate speeds. My problem is that with the 'generous' allotment of vacation time we tend to get in the US, I am pretty much blowing all my days. I am figuring on about 3-4 days per leg (2,100miles). So my motive is to save time by sending the rig ahead and to pick it up on the other end. Decisions, decisions .... GM- Hide quoted text - - Show quoted text - In exactly the same boat here - it's the "extra" days that kill any hope of SW or West Coast contests for me. The one alternative that I've toyed with is finding club member (retired, under-employed, independently wealthy) who is willing to do the drive in return for some flying time. I'm willing to let him/her have the aircraft for up to a week either side of a contest. Especially if they are willing to share a hotel room with you, the incremental cost of paying for their food and a few extra hotel nights is probably cheaper than any other alternative. Plus, you then have crew for the contest... |
Tim Mara's website has some pics of 2 304's shipped to oz in one
container on his website - 25/09/2004, http://www.wingsandwheels.com/Owners.htm. One trailer w glider is under with axle removed, the other, dismantled. Some pics of loading with forklift as well. |
Trailer tires for old (1981) Komet Trailer | [email protected] | Soaring | 3 | May 13th 09 10:24 PM |
DC-3 on a trailer | Glenn[_2_] | Aviation Photos | 1 | April 13th 08 03:21 PM |
WTB: 15m trailer, CA (USA) | John H. Campbell | Soaring | 0 | March 11th 04 03:47 AM |
FS: 2-33, 1-34, trailer | F.L. Whiteley | Soaring | 0 | February 16th 04 05:59 PM |
FS Trailer | Joseph L. Hyde | Soaring | 0 | January 11th 04 05:39 PM |
