What is the most practical backup attitude gyro system that is truly redundant for general aviation single engine aircraft during IMC flight?
On Apr 10, 10:51*pm, Jerry39
wrote: What is the most practical backup attitude gyro system that is truly redundant for general aviation single engine aircraft during IMC flight? -- Jerry39 Jerry, the most reliable thing you can do is to stay proficient with your partial panel skills. Vastly underutilized is the magnetic compass, too. Go fly an approach or two under the hood partial panel and you'll soon appreciate how little you really need to control the airplane. |
I don't agree that that's the best answer. Don't get me wrong, I enjoy
partial panel practice, and have always maintained good proficiency with it. Compass turns are, well fun, but I'd be hard pressed to say much of anything else good about them. Timed turns work out much better, if you're in any kind of shape, but the OP is correct that a redundant AI really is the best solution, and I would even say highly recommended for any plane with a vacuum driven AI that is to be used in actual IFR/IMC.Those planes are getting older now, and many vacuum pumps have not been replaced in years. One of the most important choices is not what you buy (there are now a number of good devices on the after-market) but WHERE you put it.Over on the far edge of the co-pilot's seat is not the right place. In place of the turn coordinator is good if you have limited panel space, otherwise just as close as possible to the original AI. One of the best things about a backup AI is not just that you have something to use when the vacuum-driven device fails, but that it actually points up this failure before it happens. If you can see both at the same time, you can see when they start to disagree - and many AI or vacuum failures are slow, progressive events. If you start to see your two AI's out of lock-step, start making sure you've got both in your scan. Gives you a lot more time and comfort to run those textbook quizzes "which instrument is lying?"! In article , says... Jerry, the most reliable thing you can do is to stay proficient with your partial panel skills. Vastly underutilized is the magnetic compass, too. Go fly an approach or two under the hood partial panel and you'll soon appreciate how little you really need to control the airplane. |
wrote: What is the most practical backup attitude gyro system that is truly redundant for general aviation single engine aircraft during IMC flight? -- Jerry39 Jerry: The best that I have found is the Precise Flight stand by vac system: It works off the Intake manifold.... Make sure ALL of the hoses in the Gyro system have been replaced..... just have it done so you know for sure they have been replaced MAKE SURE the A& P is REAL careful with the hoses and to BLOW THEM OUT with hi pressure air BEFORE he installs....... them no rubber chips can remain in the hose(s) or WATCH OUT! Make sure ALL filters have been replaced. Send out your gyro's for overhaul the attitude indicator, directional gyro AND the turn and bank!! The turn and band indicator has a 'dash' pot that has thick oil in a piston the oil dries up in a few years making the turn and bank so floppy it can't be used! I send out my Gyros every two years for overhaul... if you are flying REAL IFR it's worth it! By the way....please check out my You Tube Video on the Four course Radio Range it was the back bone navigation system in the world from 1928 to 1970's just go to you tube..... in the search bar : Four Course Radio Range it will come up navigation in the 1940's please give it a look and make a comment on the You tube comment section Regards!!! Watch the time in service on the Vac pump right around 500 hours time in service WATCH OUT! |
Watch the time in service on the Vac pump *right around 500 hours time in service WATCH OUT! I've never considered replacing the vacuum pump as preventive maintenance, but looking back at my Mooney experience, that's not a bad idea. I don't think I've had one last as long as 1000 hours and two failed in the clouds. It goes to show the instrument failure gods have a sense of humor: I doubt as much as 20% of the time I fly with no outside reference, but two of four failures were in those conditions. Murphy was right: if it's going to go wrong it'll happen at the worst possible time. Thanks for a good idea: obvious once stated! |
Viva la mort! Viva la guerre! Viva la sacre, Mercenaire! Live To Spend It ! http://preview.xrl.in/4z9q |
On Sun, 11 Apr 2010 12:25:01 -0700 (PDT), a wrote:
-- Viva la mort! Viva la guerre! Viva la sacre, Mercenaire! Live To Spend It ! http://preview.xrl.in/4z9q |
Jerry39 wrote:
What is the most practical backup attitude gyro system that is truly redundant for general aviation single engine aircraft during IMC flight? Not really responsive to your question, but a GPS driven ADI makes a surprising amount of sense with software applied to a PDA with a gps dongle - and it can do a moving map display too for improved situational awareness in VMC... Brian W |
On Sun, 11 Apr 2010 08:44:49 -0700, Peter Taggart wrote:
It works off the Intake manifold If I'm recalling this correctly, doesn't this type of device require reducing MP to maintain vacuum pressure. And that means that a missed approach begins by reducing the pressure spinning the AI and DG. Or am I recalling this incorrectly? - Andrew |
On Sun, 11 Apr 2010 17:37:45 +0200, VOR-DME wrote:
In place of the turn coordinator is good if you have limited panel space I know that there's an AC out there saying that it is permitted to replace a TC with a backup AI. But can't AI's still tumble, while TCs are immune? - Andrew |
| Thread Tools | |
| Display Modes | |
| Backup Attitude Gyro | Jerry39 | Piloting | 0 | April 11th 10 04:51 AM |
| Backup attitude indicator on older Cirrus | [email protected][_1_] | Owning | 2 | April 13th 08 01:36 AM |
| backup for vacuum pump/attitude indicator failure | Kelly | Owning | 27 | November 29th 06 07:58 AM |
| backup for vacuum pump/attitude indicator failure | Kelly | Instrument Flight Rules | 26 | November 29th 06 07:58 AM |
| Attitude Gyro | Paul | Restoration | 0 | July 22nd 04 06:05 AM |
