Cabeling of ILEC SN10B with Flarm
Old April 23rd 10, 07:15 AM
mkaiser mkaiser is offline
Junior Member
First recorded activity by AviationBanter: Apr 2010
Default Cabeling of ILEC SN10B with Flarm
Hi,
I have an ILEC SN10B and tried to connect it with a FLARM device. But unfortunately, the SN10B always tells me, that it does not get a GPS signal. Does anyone of you know how I have to cable both devices? In the end I'd like to use all features of the ILEC, like uploading tasks to flarm, etc., but first it would be great if I have a GPS signal.
I already have installed the latest firmware, 2.35.
Thanks for any advice,
Martin
Old April 23rd 10, 12:57 PM posted to rec.aviation.soaring
Dave Nadler
On Apr 23, 2:15*am, mkaiser
Hi,
Martin
mkaiser
Hi Martin - Many people are using ILEC SN10 v2.35
with FLARM. The FLARM connection is one of the
IGC "standard" connections, same as newer Volksloggers.
If your cable works with a Volkslogger, it should work
with FLARM.
Make *sure* you configure both FLARM and SN10
for communication at 19.2kb (19200) !
(Use the FLARM configuration tool or just edit
the FLARM configuration file on the uSD card...)
Hope that helps,
Best Regards, Dave
PS: Please post the problem you find to help others...
Old April 23rd 10, 01:58 PM
Junior Member
Quote:
Hi,
Martin
mkaiser
with FLARM.
Hope that helps,
Best Regards, Dave
Hi Dave,
thanks for your quick reply. The problem is, that it never worked before, also not with the Volkslogger, and I'm a newbie to this.
For the cabeling, does that mean that I just have to connect the 2 NMEA wires of the ILEC to the FLARM?
Best Regards,
Martin
Old April 23rd 10, 08:38 PM posted to rec.aviation.soaring
Dave Nadler
On Apr 23, 8:58*am, mkaiser
wrote:-
Hi,
tasks
Martin
mkaiser-
with FLARM.
Hope that helps,
Best Regards, Dave
Hi Dave,
wires of the *ILEC to the FLARM?
Best Regards,
Martin
mkaiser
Yes, per the ILEC SN10 manual:
http://www.ilec-gmbh.com/manuals.htm
Follow the diagram on page 82, just like
your were to hook up a Volkslogger.
Double-check your FLARM has this connector
(classic FLARM does, most do) - first !
Have fun,
Best Regards, Dave "YO electric"
Old July 12th 10, 04:04 PM
Junior Member
Hi Dave,
thanks again for your assistance. After one day search and complete disassembly of the plane I found the error in the cabling: Someone forgot to connect all data wires with Flarm (at a junction under the seat). Now the communication part between Flarm device and the ILEC is working.
But now I've got the next problem: I decided to put some new airspace and airport information onto the ILEC. So I deleted both pages for the ndb files. After I started the transfer software and connected the pc to the ILEC. The connection started and the ILEC displayed a dialog. Unluckily, I was unable to chose something, as no one of the buttons did accept any input. When I unplugged the serial cable, everything worked again, but then I was unable to transfer the file. So for now, I can't install the ndb files. Did you observe something like that before? Is there a way to install the files by installing them completely by using the PC? My ILEC software version is 2.35. I also tried 2.34, but also without success.
Best regards,
Martin
Looking for used SN10B yankeegolf Soaring 0 March 15th 10 12:21 PM
Documentation update for ILEC SN10/SN10B USB adapter Dave Nadler Soaring 0 February 22nd 10 04:15 PM
Help needed: ILEC SN10 pilots with FLARM Dave Nadler Soaring 2 December 1st 09 12:03 AM
ILEC SN10 and SN10B version 2.34 release Dave Nadler Soaring 0 September 21st 09 11:43 PM
Ilec SN10b screen reflections John Ferguson Soaring 1 June 22nd 05 10:32 PM
