Keys for older Cobra trailers
Old May 21st 10, 07:26 PM posted to rec.aviation.soaring
mattm[_2_]
Default Keys for older Cobra trailers
Hi, All,
I've got an issue with my older (1990) Cobra trailer. It has the
older style rectangular
latches that you have to press in to lock, and then use the key to
open. Where do
you get the key blanks for the locks? I've only got one key and my
local locksmiths
couldn't find any matching blanks to make copies.
-- Matt
Old May 22nd 10, 02:24 AM posted to rec.aviation.soaring
PK
On May 21, 11:26*am, mattm wrote:
Hi, All,
I've got an issue with my older (1990) Cobra trailer. *It has the
open. *Where do
you get the key blanks for the locks? *I've only got one key and my
local locksmiths
-- Matt
I experienced similar problems a few years ago when I bought my glider
and Cobra trailer. It is a problem since they are using metric,
European keys.
I finally find a "really pro" locksmith, with lots of key stuff, non
matching. He finally find a similar but not indentical one, made the
key said he could not promise it would work, but it did! 6PK
Old May 22nd 10, 04:25 AM posted to rec.aviation.soaring
Whiskey Delta
On May 21, 2:26*pm, mattm wrote:
Hi, All,
open. *Where do
local locksmiths
-- Matt
Try here if you haven't already: http://www.williamssoaring.com/index.html
I know they have a bunch of different blanks for Cobra trailer locks.
WD
Old May 22nd 10, 05:23 AM posted to rec.aviation.soaring
brianDG303[_2_]
Hi, All,
open. *Where do
local locksmiths
-- Matt
Try here if you haven't already: *http://www.williamssoaring.com/index.html
WD
I found a number on my Cobra trailer's lock cylinder and ordered 4
keys from Cobra.
Brian
Old May 22nd 10, 03:33 PM posted to rec.aviation.soaring
JS
I recently had the lock on an older (but with the wider body style)
Cobra trailer re-keyed to fit the new numbered Emka keys.
Took one of the readily available keys to the locksmith and... Voila!
It cost $20 US.
Old May 26th 10, 02:53 AM posted to rec.aviation.soaring
Fred[_4_]
My 40 year old trailer that was imported into the states in 1969, has
locks that use a Volkswagen blank.
On May 21, 1:26*pm, mattm wrote:
Hi, All,
open. *Where do
local locksmiths
-- Matt
Old May 30th 10, 10:01 PM posted to rec.aviation.soaring
mattm[_2_]
Hi, All,
open. *Where do
local locksmiths
-- Matt
Well, it turns out that my locks do fit the EMKA key shape, but none
of the "normal" EMKA keys actually work. The locksmith described my
lock and keys at the local locksmith convention and said everyone
there
thought he was crazy.
In the end, since my one key was actually locked inside the trailer,
I had to get in with a drill (I drilled out the rivets on the door
hinge).
I've got one pointer to a local lock shop that might have blanks that
will
work. If that fails I might just have the locks rekeyed to fit one of
standard EMKAs.
-- Matt
Aluminum top Cobra trailers leaks - how frequent? AK Soaring 2 March 31st 10 11:05 PM
Older Cobra trailer brake oscillation Brian Bange[_2_] Soaring 9 March 10th 09 07:41 PM
FS: AL-KO 14 inch brake kit for Cobra Trailers [email protected] Soaring 0 December 21st 07 03:22 AM
Cracking welds on older Komet trailers Bill Daniels Soaring 2 June 1st 06 03:09 AM
Solar vents delivered on Cobra trailers Dan Dunkel Soaring 7 April 4th 04 08:38 PM
