On May 24, 4:44*pm, Mike wrote:
Andy, if the PNA's baud rate can be set by XCSoar it should work? It is my understanding that the HP31x will not support 4800 baud even if the port configuration menu of XCSoar or LK8000 suggests that it can be selected. So I'm curious to know if this PNA will actually support 4800 baud. The 302 can be configured for higher baud rates according the the port specification document but it defaults to 4800 on next power up. Andy |
Not to drag the thread off topic but does XCSoar (or KL8000) play well
with LX5000/700x systems? Like the 302, these devices provide pressure data (vario, airspeed, etc) via "WinPilot" sentences (but at a much higher baud rate). I prefer my PDA software to leverage these pressure data for its calculations where appropriate and not rely strictly on NMEA. (I can't imagine a thermal assistant or bread crumb implimentation that does not use real vario pressure data.) I've browsed the XCSoar wiki but unable to come up with a clear answer. ted/2NO |
I don't know the answer; however, here is the place where my may be able to find it.
http://www.postfrontal.com/forum/default.asp?CAT_ID=11 Wayne http://www.soaridaho.com "Tuno" wrote in message ... Not to drag the thread off topic but does XCSoar (or KL8000) play well with LX5000/700x systems? Like the 302, these devices provide pressure data (vario, airspeed, etc) via "WinPilot" sentences (but at a much higher baud rate). I prefer my PDA software to leverage these pressure data for its calculations where appropriate and not rely strictly on NMEA. (I can't imagine a thermal assistant or bread crumb implimentation that does not use real vario pressure data.) I've browsed the XCSoar wiki but unable to come up with a clear answer. ted/2NO |
On May 25, 7:59*am, Tuno wrote:
I can't imagine a thermal assistant or bread crumb implimentation that does not use real vario pressure data.) One of the attactions of an HP 310 with LK8000 was the expectation that it would provide a fully portable system that I could use when instructing or flying solo XC in club gliders. In other words, the expectation that it would work without needing an intelligent vario was significant to me. However, the internal GPS does not track the glider position properly in thermals and it therefore cannot produce a circling wind estimate. Most of the time it will not even transition to climb mode. Those that like to fly 2 county wide circles when thermalling may see different results. As Wayne suggested, the postfrontal forum is probably the best place to go for other user's experience with LK8000 interfacing systems. Andy |
Does this device connect to an LX5000/700x, or Cambridge 302, and if
so, how? |
On 25 Mai, 18:49, Tuno wrote:
Does this device connect to an LX5000/700x, or Cambridge 302, and if so, how? And another fake try! Put them side by side and facing in the sunlight not sunlight from the back!!!!!!!!!!!!!!!!!! |
On May 25, 8:47*am, Andy wrote:
On May 25, 7:59*am, Tuno wrote: I can't *imagine a thermal assistant or bread crumb implimentation that does not use real vario pressure data.) One of the attactions of an HP 310 with LK8000 was the expectation that it would provide a fully portable system that I could use when instructing or flying solo XC in club gliders. * In other words, the expectation that it would work without needing an intelligent vario was significant to me. *However, the internal GPS does not track the glider position properly in thermals and it therefore cannot produce a circling wind estimate. *Most of the time it will not even transition to climb mode. *Those that like to fly 2 county wide circles when thermalling may see different results. As Wayne suggested, the postfrontal forum is probably the best place to go for other user's experience with LK8000 interfacing systems. Andy Want to point you guys to Vladimir Flux's htttp://glidertools.com He has an interesting Bluetooth interface and a very interesting glider that's worth checking out too. Al |
On May 26, 3:58*am, TRKA wrote:
On 25 Mai, 18:49, Tuno wrote: Does this device connect to an LX5000/700x, or Cambridge 302, and if so, how? And another fake try! Put them side by side and facing in the sunlight not sunlight from the back!!!!!!!!!!!!!!!!!! You know what why don't you buy one and do it yourself!! Photo's were taken around noon so sun would be at its highest. You have the 2 devices side by side. There is not other test to do apart from you go fly with one you just bought unless of course your Grunau Baby does not have 12V power. Al |
On May 27, 3:41*am, "
wrote: On May 26, 3:58*am, TRKA wrote: On 25 Mai, 18:49, Tuno wrote: Does this device connect to an LX5000/700x, or Cambridge 302, and if so, how? And another fake try! Put them side by side and facing in the sunlight not sunlight from the back!!!!!!!!!!!!!!!!!! You know what why don't you buy one and do it yourself!! Photo's were taken around noon so sun would be at its highest. You have the 2 devices side by side. There is not other test to do apart from you go fly with one you just bought unless of course your Grunau Baby does not have 12V power. Al Al, you have what looks to be an excellent device but keep an eye on this. http://www.technologyreview.com/computing/25395/?a=f |
On 27 Mai, 11:41, " wrote:
On May 26, 3:58*am, TRKA wrote: On 25 Mai, 18:49, Tuno wrote: Does this device connect to an LX5000/700x, or Cambridge 302, and if so, how? And another fake try! Put them side by side and facing in the sunlight not sunlight from the back!!!!!!!!!!!!!!!!!! You know what why don't you buy one and do it yourself!! Photo's were taken around noon so sun would be at its highest. You have the 2 devices side by side. There is not other test to do apart from you go fly with one you just bought unless of course your Grunau Baby does not have 12V power. Al You are funny guy. I have Ipaq 3850, Ipaq H5550, Ipaq 310 and also made Photos and comparison. On direct sunlight the 3850 and the 5550 never never are so dark. So what do you try here? http://www.postfrontal.com/forum/top...Terms=sunlight Again, put both display in direct sunlight that is the best compare. The 3850 has the best screen for soaring. Everybody knows that, so your test and your pictures are very funny. |
Glide computer review | Itsaplane[_2_] | Soaring | 24 | December 11th 09 05:43 PM |
Cheap Glide Computer | Uncle Fuzzy | Soaring | 18 | November 9th 09 09:24 PM |
iPhone Glide Computer | Kloudy via AviationKB.com | Soaring | 13 | September 13th 07 03:41 AM |
Glide computer | Mark Siegelberg | Soaring | 1 | January 13th 07 01:08 PM |
Best Glide computer and why | Roger | Soaring | 10 | October 24th 06 08:28 PM |
