Co-pilot gets sick, stewardess helps land airplane
Old June 23rd 10, 08:20 AM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
JohnT[_3_]
Default Co-pilot gets sick, stewardess helps land airplane
"Mxsmanic" wrote in message
As I've said, a lot of private pilots seem to give physical sensations
priority over everything else. But there's a lot more to flying than a
roller-coaster ride. I don't care much for the physical sensations
myself,
although takeoff and landing are kind of pleasant if they are smooth.
What physical sensations are you referring to? You don't fly and you know
nothing about flying. You just play a computer game in your cupboard in
Paris.
JohnT
  #162
Old June 23rd 10, 10:14 AM posted to rec.aviation.piloting
a[_3_]
On Jun 22, 9:45*pm, Wingnut wrote:
On Sun, 20 Jun 2010 11:45:01 +0200, Mxsmanic wrote:
Wingnut writes:
So, you're sayign that flight experience is irrelevant to flying an
aircraft?
That depends on the experience, and the aircraft. Flight experience in a
Cessna 152
Ah, the Cessna 152 strawman again. I was wondering when that would show
up. First sentence of non-quoted text as it just so happens -- which
means one of my co-workers owes me ten bucks. :-)
Just as experience in driving a Yugo doesn't necessarily help in
driving a Formula 1 car.
Experience driving versus never having sat behind a wheel should make
some difference. It's plain old common sense!
A person with experience in a Cessna 152 still has none in a 747, and so
he will not necessarily be any more useful in a 747 cockpit than a
non-pilot would.
There will be some commonalities. Zero experience in a plane will make
you worse than having had some experience. I don't claim you'd be
proficient; just that you wouldn't actually be *less* capable than
someone who knew *nothing*. Again, common sense.
Pilots of small private aircraft who believe that they could just slip
into a 747 cockpit and fly it are just as naive as non-pilots who
believe the same thing.
First of all, we weren't talking "pilots of small private aircraft", at
least not until you came along and introduced that particular strawman.
Second, they may not be able to do a good job, but the total non-pilot
will surely do a worse job.
Except in your earlier, specific scenario of being talked through a
procedure from the ground, where anyone with basic comprehension skills
will probably do about as well. (Someone with piloting experience might
more quickly be able to find and recognize particular controls or
instrument readouts though, and will be able to understand a more compact
jargon, so he may be a bit faster though other than that only as good as
the quality of the ground instructions.)
I don't think anyone here has claimed that. Though the less someone
knows about operating an aircraft, the poorer their odds.
Yes. I've heard many people claim this, however, and it only shows that
they are uninformed.
Someone who says that "the less experience a person has at a skilled
task, the poorer their odds of completing it successfully" is
"uninformed"? In what universe? In the one where I live there is this
thing called a "learning curve". It climbs steeply at first, then bends
over, but it's monotonic increasing, and it indicates task performance as
a function of experience. Performance improves with experience, slowing
down and eventually plateauing. For some things (e.g. Tic-Tac-Toe) it
plateaus fast and low; for others (e.g. chess) it plateaus much more
slowly and higher, because the thing being learned is more complicated.
But it does not actually dip down at any point.
Since this basic fact (learning curves are monotonic increasing) is
disputed by you, I'm forced to conclude that you're insane and thus not
really worth debating with any further.
Wingnut, I'm going to have to call you on your statement that learning
curves are monotonically increasing activities.
1) I have employees whose 10 years of experience can be characterized
as 1 year repeated 10 times. (That's OK depending on their job of
course.)
2) There are some who have posted here thousands of times and seem to
have learned nothing.
3) There are some here who even after repeated experiences have not
yet learned engaging others in the 'reality vs sim' experience doesn't
add value to the thread.
The major reason a non-certificate holder is one of the most frequent
posters here is because others of us, including me, took part in the
non-learning experience of engaging him on a topic.
It would appear MX's major recreation is sim and engaging in these
debates,other of his posts suggest he doesn't have much of a life
elsewhere. We've all seen literate failures at real life, he is most
likely in that class. Too many of us contribute to his recreation at
the expense of RAP (although these threads are better than the ****ing
contests others seem to enjoy). He is simply a non-pilot who enjoys
yanking on pilot's chains and does that fairly successfully.
You should note that when you simply reply to him, you postings are
also sent to other groups.
  #163
Old June 23rd 10, 01:21 PM posted to rec.aviation.piloting
On Jun 22, 6:20*pm, Mxsmanic wrote:
That's about 0.000001% of what you have to learn to deal with to fly
airplanes, and a great deal of what you have to learn (the great majority, in
fact) has nothing to do with physical sensations.
WRONG. Ignore what the plane tells you before a stall and YOU would
be dead.
One of the first things I was taught was to NOT ignore what the plane
is trying to tell you. It WILL tell you when it's ready to stop
flying BEFORE it shows on your airspeed indicator something you have
no clue about since MSFS doesn't indicate this. As others already
told you, you feel it in the controls (mushy, then shudders).
Same thing for landing, ignore what the plane when it's not ready to
land and YOU would be dead. You feel it before you see it indicated
on instruments. But of course YOU HAVE NO CLUE.
  #164
Old June 23rd 10, 01:29 PM posted to rec.aviation.piloting
also sent to other groups.- Hide quoted text -
Interesting and has me puzzled. All the threads I been participating
I thought has only been going back to rec.aviation.piloting. I see
what you are talking about though on certain threads???
Since we haven't seen new names pop up on the radar in this group his
trolling doesn't appear to be too effective in the other groups.
  #165
Old June 23rd 10, 03:32 PM posted to rec.aviation.piloting
a[_3_]
Interesting and has me puzzled. *All the threads I been participating
I thought has only been going back to rec.aviation.piloting. *I see
I'm using a Google group reader for this account, and when I click
reply the newsgroups being posted to appear in the newsgroup field.
Sometimes I forget to limit my responses to this group.
The OP was addressed to several news groups that would have found the
topic interesting, I have no complaint with that. Someone a long time
ago pointed out some of my comments were being cross posted, I
appreciated the head's up. Spammers like lots of groups, I don't want
to be a member of that tribe, either by cross posting or by content.
My 'content' speaks for itself, the cross posting is accidental.
  #166
Old June 23rd 10, 05:12 PM posted to rec.aviation.piloting
topic interesting,
I'm using Google groups so I can fully understand but I doubt that
rec.travel.air, rec.arts.movies.past-films, rec.arts.tv,
alt.gossip.celebrities would have been interested in this
discussion.
But then again, different threads may be xposted to different groups,
dunno. I just happened to pick one sub thread to extract the above
and the subthreads I have been participating in has only been to here.
Same here.....
  #167
Old June 23rd 10, 09:31 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
Mxsmanic
Wingnut writes:
It makes a difference, but not necessarily a useful difference.
Very little in common, and much of it too dangerous to use. For example, the
747 has flight controls, and so does the Cessna--but a Cessna pilot who
actually attempts to fly the 747 by hand will obtain even worse results than
he would if he simply stayed with the automation.
I don't claim you'd be proficient; just that you wouldn't actually
be *less* capable than someone who knew *nothing*.
You would not be less capable, but you would not necessarily be more capable
in any practical sense.
Virtually every pilot arguing about it here is a low-time private pilot. I can
spot them from a mile away. They're in the "danger zone" of low-time pilots,
where most accidents occur. Enough experience to feel confident, but not
enough experience to feel humble.
The results might be the same. The results for the pilot might actually be
worse if his experience encourages him to take risks that the non-pilot would
not (such as attempting to fly the aircraft by hand).
The only viable scenario is one in which the pilot/non-pilot is given
instructions by a qualified third party. It is unlikely that a non-pilot or a
pilot without experience in type would know enough to land entirely on his
own, without instructions.
He might find the magnetic compass faster, and he'd recognize the yoke and
rudder pedals and throttles. Beyond that, nothing is really certain. The real
risk is that he might think he knows more than he does, which means he might
do risky things that the non-pilot would not.
The accident rate for non-pilots is zero, because they do not fly. The
accident rate for pilots with thousands of hours of experience is very low,
becaue they've been flying for a very long time. The accident rate for pilots
with only a limited number of hours is very high, because they gain confidence
before they gain competence. A low-time private Cessna pilot is thus in a
dangerous zone (and most pilots of small Cessnas are also low-time pilots),
and he has experience that is irrelevant in many ways to that required to fly
a 747. He is thus at considerable risk.
  #168
Old June 23rd 10, 09:35 PM posted to rec.aviation.piloting
Mxsmanic
a writes:
I like to talk about aviation. Unfortunately, a small but vocal group of
people of high emotional tension and low intelligence will direct any
interaction with me towards a discussion of me personally (their bogeyman),
instead of discussing the original topic. And others, who might be interested
in discussing aviation, simply don't participate at all, which doesn't leave
many options other than the village idiots.
There are a few venues in which I'm able to sustain an intelligent discussion
of aviation without any reference to personalities at all, but in most venues
the angry young males are such a pox upon discussion that they eventually
overwhelm it.
It is interesting to note that sometimes the stupid ones (and the smart ones)
are not where or who you'd expect them to be.
  #169
Old June 23rd 10, 09:39 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
Mxsmanic
Hatunen writes:
Really? How many private pilots do you know well enough to make
that claim?
Quite a few.
If. I'm not particulary fond of hitting tubulence when I'm in an
airliner, but physical sensations are hard to avoid if you fly
much.
Sure, but they are not an integral part of flying, unless you fly specifically
for the thrill of sensations.
There are lots of YouTube videos of inexperienced, stupid pilots doing just
that. They don't always identify themselves, but eventually their names tend
to appear in NTSB reports.
  #170
Hatunen
On Wed, 23 Jun 2010 22:31:05 +0200, Mxsmanic
And all of those lowtime private pilots can spot a non-pilot who
thinks he knows-it-all from a computer game a mile away.
[Mixie has a way of mixing truisms that hardly need stating with
assertions that come from his apparent thinking that a computer
game gives him life experience, and with assertions that rely on
believing that a PC game is the equivalent of a large
professional flight simulator.]
************* DAVE HATUNEN ) *************
* Tucson Arizona, out where the cacti grow *
* My typos & mispellings are intentional copyright traps *
Pilot nearly crashes in IMC, Controller helps pimenthal Piloting 32 September 27th 05 01:06 PM
Aviation Conspiracy: Toronto Plane Pilot Was Allowed To Land In "Red Alert" Weather Bill Mulcahy General Aviation 24 August 19th 05 10:48 PM
2 pilot/small airplane CRM Mitty Instrument Flight Rules 35 September 1st 04 11:19 PM
non-pilot lands airplane Cub Driver Piloting 3 August 14th 04 12:08 AM
Home Builders are Sick Sick Puppies pacplyer Home Built 11 March 26th 04 12:39 AM
