2 pilot/small airplane CRM
Old August 22nd 04, 04:36 PM
Mitty
Default 2 pilot/small airplane CRM
Can anyone point me to web or print resources with discussion of how to
best utilize two pilots in small airplanes? Who does what, etc. I have
found lots of airline-level material but really nothing that relates to
flying light singles. Or maybe someone who regularly flies with a pilot
spouse? How do you split the workload?
Old August 22nd 04, 06:54 PM
Stan Prevost
"Mitty" wrote in message
I fly with a nonpilot spouse who shares my workload. She has a copy of the
checklists, and some items are her responsibility. In preflight, she checks
switches etc. on her side (all identified on the checklist), verifies vacuum
at runup, watches me to make sure I don't miss things, issues certain
reminders at various planned times. After takeoff, she calls altitudes at
which I have actions to take (typically 400AGL and 1000 AGL), watches my
heading and altitude for compliance with clearance, calls attention to
deviations, announces approaching clearance altitude. She tunes the radios
to in-flight assigned frequencies, reminds me to make the call if I got busy
and forgot. She monitors the various checklists to make sure I don't miss
things (which I never do, of course g). She times the fuel tanks and
tells me when to switch. She gets out approach plates when I call for them.
etc.
Works well for us. The only problem is that I feel lost when flying alone.
Stan
Old August 23rd 04, 12:49 AM
fly low
Is your wife available to train other wifes?
"Stan Prevost" wrote in message
checks
vacuum
radios
busy
them.
etc.
alone.
Stan
Old August 23rd 04, 01:24 AM
Matt Whiting
What do you do at 400 AGL? I'm curious as I don't do anything until
1000 (fuel pump off, power set to climb, etc.).
Matt
Old August 23rd 04, 02:11 AM
Newps
You should be turning when you reach 400 feet.
Old August 23rd 04, 03:14 PM
Matt Whiting
I don't need a checklist item to make a turn.
Matt
Old August 23rd 04, 05:09 AM
Stan Prevost
"Matt Whiting" wrote in message
I make any required initial turn to follow an IFR departure procedure or
follow an ATC departure clearance. I also transition to climb power at that
altitude. Waiting until 1000 AGL for climb power is also a good practice;
some say to not fool with the engine until you can turn back to the field.
I just like to slow the prop as soon as I can for noise reduction.
Stan
Old August 23rd 04, 11:51 AM
Blanche
If the copilot is not familiar with the aircraft (radios, etc) then
it's difficult to have them do the communications, setting freqs,
etc. I had that happen with an instructor. I own a cherokee and have
upgraded (not hard, since few of the avionics worked anyway) the
radios, added an intercom and PS 6000, etc. Most instructors around
here are familiar with the King environment and not the PS/Garmin/UPSAT
configurations. Hence the inability to change freqs on a timely
basis when flying with me.
CRM only works if both parties are familiar with procedures and
equipment and agree to use the procedures.
Old August 23rd 04, 03:15 PM
Matt Whiting
Stan
I've used 1000 as that is what Flight Safety recommended.
Matt
Old August 22nd 04, 08:25 PM
Matt Whiting
Since I fly a fair bit of single pilot IFR, I want to retain proficiency
at that and not get dependent on another body in the cockpit. I use
another pilot or passenger to simply do things like hand me charts and
confirm altitudes and watch for traffic. I continue to perform ALL
flying, navigating and communication chores so that I stay proficient
for single-pilot flight.
Matt
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 December 2nd 04 07:00 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 02:31 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
