Co-pilot gets sick, stewardess helps land airplane
Old June 24th 10, 10:26 PM posted to rec.aviation.piloting
Mxsmanic
Default Co-pilot gets sick, stewardess helps land airplane
writes:
CORRECTION to my post above - You land a plane under VMC conditions
(VISUAL)
Almost, but not quite. Aircraft land in IMC all the time, and I've done it
many times.
  #222
Old June 24th 10, 10:36 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
The Starmaker
Mxsmanic wrote:
george writes:
On Jun 24, 10:05 pm, Mxsmanic wrote:
None that I found alarming. Downdrafts are harmless as long as you're well
above terrain.
Rotor ???????
Thunderstorm? Hurricane? Tornado? Nuclear explosion?
I don't recall losing 15,000 feet in a rotor on a commercial flight, but I
suppose anything is possible. A handful of exceptions does not disprove the
rule.
which version of microsoft flight simulator do you use?
  #224
Old June 24th 10, 10:48 PM posted to rec.aviation.piloting,rec.travel.air
rule.
Yet you seem to use exceptions quite frequently to "prove" you are correct.
Case in point: that some model C150s are prohibited from spinning to prove
pilots are doing reckless spinning.
Jim Pennino
Remove .spam.sux to reply.
  #227
Old June 24th 10, 10:57 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
Mxsmanic
The Starmaker writes:
FS 2004 (also called FS9)
  #228
Old June 25th 10, 12:53 AM posted to rec.aviation.piloting
On Jun 24, 4:49*pm, wrote:
Mxsmanic wrote:
writes:
(VISUAL)
many times.
Then YOU DID NOT SIMULATE LANDING THE PLANE. Did you????????????
DUH, AUTO LAND........ HELLO, anybody out there.
PILOTS LAND THE PLANE in VMC.in the real world.
As Jim already pointed out, YOU DON'T land anything. YOU SIMULATE
LANDING on MSFS.
WHAT PART OF THAT DO YOU NOT UNDERSTAND ABOUT SIMULATION?????
  #229
Old June 25th 10, 01:17 AM posted to rec.aviation.piloting
Mxsmanic
writes:
I've simulated all sorts of landings: hand-flown, autopilot (including
autoland), VMC, IMC, zero visibility, crosswinds, etc. The greater the variety
of situations you simulate, the more you learn.
A simulator allows you to gain experience with situations that you may never
encounter in real life. While simulation isn't perfect, the knowledge you gain
from the simulation of a specific situation is more useful than no knowledge
at all ... especially if that particular situation actually arises (I think Al
Haynes would agree with that).
Sometimes they do, sometimes they don't.
I think if you do a quick search on YouTube, you'll find that lots of landings
take place in IMC, including computer-controlled autolands in very low
visibility (apparently Cat IIIc autolands in zero visibility are not actually
done because of the difficulty in taxiing to the gate thereafter).
LANDING on MSFS.
I land in the simulator.
I might be tempted to ask the same question.
  #230
Old June 25th 10, 01:46 AM posted to rec.aviation.piloting
a[_3_]
Mxsmanic wrote:
writes:
(VISUAL)
many times.
Then YOU DID NOT SIMULATE LANDING THE PLANE. *Did you????????????
As Jim already pointed out, YOU DON'T land anything. *YOU SIMULATE
LANDING on MSFS.
Is there a point to this 'debate'? We know the rules of the game MX
plays, Continue if you enjoy being played.
Pilot nearly crashes in IMC, Controller helps pimenthal Piloting 32 September 27th 05 01:06 PM
Aviation Conspiracy: Toronto Plane Pilot Was Allowed To Land In "Red Alert" Weather Bill Mulcahy General Aviation 24 August 19th 05 10:48 PM
2 pilot/small airplane CRM Mitty Instrument Flight Rules 35 September 1st 04 11:19 PM
non-pilot lands airplane Cub Driver Piloting 3 August 14th 04 12:08 AM
Home Builders are Sick Sick Puppies pacplyer Home Built 11 March 26th 04 12:39 AM
