hello,
I will begin the engine final assembly. I read I need to begin with the 3 dowel screws and the front two 7/16 through studs and low rear3/8 stud. I don't find the tight order after that. I guess it is better to tight all the stud nuts on big machined washer before the sealant cure and fit the cylinders next day. I own and read the overhaul manual. If I don't find any order, I will begin with center bearing, rear bearing next and remaining front bearing nuts. At the end, all the flange bolts. Thanks for any help -- http://www.youtube.com/v/k6AP4SbRHNo...s=1&rel=0 Philippe Vessaire Ò¿Ó¬ |
| C85 and O200 piston | Philippe[_4_] | Home Built | 2 | August 11th 10 06:47 PM |
| O200 overhaul | Philippe[_4_] | Home Built | 0 | May 30th 10 09:38 PM |
| O200 cylinder | Philippe Vessaire[_3_] | Home Built | 3 | October 19th 08 12:21 PM |
| O200 engine | Philippe Vessaire | Home Built | 7 | August 17th 07 09:53 PM |
| O200 nose | Philippe | Home Built | 0 | July 22nd 05 09:09 PM |
