O200 cylinder
Old October 18th 08, 01:13 PM posted to rec.aviation.homebuilt
Philippe Vessaire[_3_]
Default O200 cylinder
Hello,
I have one exhaust stud which has come out with all helicoil thread.
(pn 402151)
Does anyone know a repair way?
Thanks
Volem rien foutre al païs!
Philippe Vessaire Ò¿Ó¬
Old October 18th 08, 08:30 PM posted to rec.aviation.homebuilt
jerry wass
Philippe Vessaire wrote:
Hello,
(pn 402151)
Thanks
go to larger 3/8" repair insert--use 3/8" X 5/16" stud---I think I have
both--Jerry wassbiplane ---at---tds--.--net
Old October 19th 08, 01:16 AM posted to rec.aviation.homebuilt
jerry wass
Hello,
(pn 402151)
Thanks
You might have enough material to tap a 3/8"X16tpi standard bolt size,
in which case, the 3/8" X 5/16" stud would work by itself.
See how a 5/16" drill fits in the hole----If it's not too loose, you
might try running a 3/8" X 16 tpi tap into it---if the threads produced
look fairly good--go for it!---my 3/8" X 5/16" studs are slightly
oversized on the 3/8" end anyhow..( stud 1.7" overall, 0.6" 3/8" thd on
one end--0.9" 5/16" x24tpi on the other, 0.2" 5/16" smooth in center.)
I only have about 6 of them, but you can have one for a Dollar (U.S.)
If the above doesn't fix it, I have some 3/8" helicoils---drill size
0.386" dia-----tap O.455" max thread dia.
Hope this helps.
Jerry
Old October 19th 08, 11:21 AM posted to rec.aviation.homebuilt
Thanks...
anyway, I search online dealer for timesert repair kit from Wurth....
It may fit in the hole and I will keep standard stud. It is a tread
bushing...
Hard to find parts... (kit and inserts)
Known only for motorcycle engine sprak plug thread repair in Europe.
By
O200 engine Philippe Vessaire Home Built 7 August 17th 07 08:53 PM
Oil in cylinder, other cylinder issues Robert M. Gary Owning 8 May 27th 07 05:26 AM
Oil in cylinder, other cylinder issues Jim Burns[_3_] Piloting 2 May 24th 07 05:26 AM
Oil in cylinder, other cylinder issues Jim Burns[_3_] Owning 2 May 24th 07 05:26 AM
O200 nose Philippe Home Built 0 July 22nd 05 08:09 PM
