Cutting 57mm holes in the instrument panel.....how to?
Old November 12th 10, 07:20 AM posted to rec.aviation.soaring
Craig[_2_]
Default Cutting 57mm holes in the instrument panel.....how to?
On Nov 11, 9:42*pm, Bob Kuykendall wrote:
On Nov 11, 9:39*pm, Alia Kuykendall
Sawzall.
Much neater than the chainsaw, but not as cool as a loop of det cord.
Thanks, Bob K.
Oops, that was my post.
Thanks, Bob K.
We just figured your daughter was picking up the torch. Put a sawzall
in their hands when they're three and they'll never look back.
Craig
Old November 12th 10, 08:43 AM posted to rec.aviation.soaring
Peter Purdie[_3_]
The suggestion to use 2-1/4" or 3-1/8" hole saws is absolutely correct.
Those were the original standard instrument sizes (and you will find that
the P.C.D. of the fixing holes is also a neat measurement in inches.
Over here in metricland where they don't understand inches, it was
converted to the nearest integer millimetre.
And a hole saw (used on a panel clamped down to a good rigid drill press
bed for accuracy) is a damn sight less costly than a hole punch.
Although Bob's idea of a piece of det cord looks interesting, I must try
it. On someone else's panel...............
Old November 12th 10, 11:09 AM posted to rec.aviation.soaring
Derek C
it. *On someone else's panel...............
Surely you can order metric hole saws by the internet? The hard work
way of doing it is to scribe the correct size hole onto the panel,
drill out a series of adjacent holes just inside the scribe mark,
knock out the centre, and them finish to size with a half round file.
Derek C
Old November 12th 10, 03:38 PM posted to rec.aviation.soaring
Craig[_2_]
Sawzall.
Thanks, Bob K.
Thanks, Bob K.
New aluminum panels can be cut out pretty effectively by waterjet or
laser using a local fabricator. I think I paid $80 the last time
(aluminum included) and just had to give them the drawing file.
Craig
Old November 12th 10, 03:43 PM posted to rec.aviation.soaring
Dave Nadler
Sawzall.
Thanks, Bob K.
Thanks, Bob K.
laser using a local fabricator. *I think I paid $80 the last time
Craig
Aluminum panels are quite dangerous in an accident;
edge removed leg of a friend in a crash.
Please use fiberglass panel with a integral rounded
flange as do all modern manufacturers. If you have
an older glider with an aluminum panel consider
upgrading it (good opportunity to add an SN10).
No kidding here.
Best Regards, Dave
Old November 12th 10, 03:45 PM posted to rec.aviation.soaring
cfinn
One of the best ways is to use a hole punch. You need a 1 1/4 inch
size. Aircraft Spruce carries them. Here's a link:http://www.aircraftspruce.com/catalo.../knockout2.php.
Charlie
Charlie, I think you meant to type a 2 1/4 inch hole. 57MM equals 2.24
inches. Doug
Thanks for the correction. Fingers on the wrong key. I need to edit
better before punching the send button! At least the link was correct.
Old November 12th 10, 04:28 PM posted to rec.aviation.soaring
Craig[_2_]
Sawzall.
Thanks, Bob K.
Thanks, Bob K.
Craig
No kidding here.
Best Regards, Dave
I've had similar concerns about the aluminum panel and will probably
change to a fiberglass tilt up panel this winter. In the meantime,
I've set up the panel so that the upper bolts go through a vertical
slot that opens toward the bottom and the lower bolts are nylon that
will shear in an impact. I still have the sharp edge of the panel and
its weight to overcome, but at least it's free to break away from the
fuselage structure.
Thanks,
Craig
Old November 12th 10, 04:31 PM posted to rec.aviation.soaring
Craig[_2_]
Sawzall.
Thanks, Bob K.
Thanks, Bob K.
Craig
No kidding here.
Best Regards, Dave
change to a fiberglass tilt up panel this winter. *In the meantime,
will shear in an impact. *I still have the sharp edge of the panel and
fuselage structure.
Thanks,
Craig
P.S. If anyone's looking to sell their SN10, please contact me via
email.
Thanks,
Craig
Old November 12th 10, 05:34 PM posted to rec.aviation.soaring
bildan
Sawzall.
Thanks, Bob K.
Thanks, Bob K.
Craig
No kidding here.
Best Regards, Dave
Unless the older glider used the instrument panel as a load bearing
bulkhead.
Old November 12th 10, 07:25 PM posted to rec.aviation.soaring
Ralph Jones[_3_]
On Thu, 11 Nov 2010 21:39:30 -0800 (PST), Alia Kuykendall
On Nov 11, 4:09*pm, "John Bojack" wrote:
...what have others done when cutting new panels for 57mm
instruments?
Sawzall.
Thanks, Bob K.
But this is just the right size...
http://www.rt66.com/~korteng/SmallArms/57m18.htm
rj
WANTED: 57MM Avionic / Instrument - Stuff Scott Alexander[_2_] Soaring 1 October 25th 09 03:56 AM
WANTED: 57MM Avionic / Instrument - Stuff Scott Alexander[_2_] Soaring 0 October 25th 09 01:58 AM
DG-300 instrument panel [email protected] Soaring 14 January 29th 06 02:48 PM
LS 6 b instrument panel John Brenann Soaring 4 November 19th 05 04:37 AM
When Poorboys drill holes ...was: Drilling holes in steel tubing wright1902glider Home Built 4 November 4th 05 01:19 AM
