A friend in my club built a pair of winglets for his Standard Cirrus.
His glider is expirmental, mine is not. The total cost for him was just a hundred dollars for supplies, and some free guidance from a local IA/AP. The finished product looks fantastic! The mold came from an American Spirit, which I believe is a copy of the Ventus. And the result is that his handling has improved quite a bit. He did do some adjustments on the toe-out angle to fine tune it which supposively helped. I would like to do the same thing with mine using the exact same molds. My Cirrus is a standard airworthiness certificate. If I were to do the factory winglet or the Maughmer winglet, the cost is between 3,000-5,000 when it's all said and done. So that being said, this option, looks very appealing. Has anyone in this group dealt with the same sort of deal? I would be willing to change my standard airworthiness certificate over to an expiremental if that is the best solution. Any guidance is much appreciated. Thanks, Scott PS Happy Thanksgiving. |
On 11-20-2010 16:39, Scott Alexander wrote:
A friend in my club built a pair of winglets for his Standard Cirrus. His glider is expirmental, mine is not. The total cost for him was just a hundred dollars for supplies, and some free guidance from a local IA/AP. The finished product looks fantastic! The mold came from an American Spirit, which I believe is a copy of the Ventus. And the result is that his handling has improved quite a bit. He did do some adjustments on the toe-out angle to fine tune it which supposively helped. I would like to do the same thing with mine using the exact same molds. My Cirrus is a standard airworthiness certificate. If I were to do the factory winglet or the Maughmer winglet, the cost is between 3,000-5,000 when it's all said and done. So that being said, this option, looks very appealing. Has anyone in this group dealt with the same sort of deal? I would be willing to change my standard airworthiness certificate over to an expiremental if that is the best solution. Any guidance is much appreciated. Thanks, Scott PS Happy Thanksgiving. Here in the USA, it doesn't appear possible to go from certified to experimental (amateur built). You can possibly get it into special experimental (R&D perhaps), but you will be limited on what types of flights you may use it for. http://www.faa.gov/aircraft/air_cert...rt/experiment/ more info... http://ecfr.gpoaccess.gov/cgi/t/text... 1.3.9.8.11.14 |
On Nov 20, 8:39*am, Scott Alexander
wrote: A friend in my club built a pair of winglets for his Standard Cirrus. His glider is expirmental, mine is not. *The total cost for him was just a hundred dollars for supplies, and some free guidance from a local IA/AP. *The finished product looks fantastic! *The mold came from an American Spirit, which I believe is a copy of the Ventus. *And the result is that his handling has improved quite a bit. *He did do some adjustments on the toe-out angle to fine tune it which supposively helped. I would like to do the same thing with mine using the exact same molds. *My Cirrus is a standard airworthiness certificate. *If I were to do the factory winglet or the Maughmer winglet, the cost is between 3,000-5,000 when it's all said and done. *So that being said, this option, looks very appealing. Has anyone in this group dealt with the same sort of deal? *I would be willing to change my standard airworthiness certificate over to an expiremental if that is the best solution. *Any guidance is much appreciated. Thanks, Scott PS Happy Thanksgiving. None of these winglets appear to have STCs so the installation in a type certificated glider will be via 337/field approval (I doubt you'll find an A&P who would claim adding a winglet is a "minor alteration" although there could be corner cases...). Since likely you need an A&P/IA to file a 337 and work with your local FSDO that is where I'd start. OTOH if you can get a pair of winglets for $3k out the door, all approved properly, then I'd take that route. Darryl |
On Nov 20, 11:13*am, Darryl Ramm wrote:
On Nov 20, 8:39*am, Scott Alexander wrote: A friend in my club built a pair of winglets for his Standard Cirrus. His glider is expirmental, mine is not. *The total cost for him was just a hundred dollars for supplies, and some free guidance from a local IA/AP. *The finished product looks fantastic! *The mold came from an American Spirit, which I believe is a copy of the Ventus. *And the result is that his handling has improved quite a bit. *He did do some adjustments on the toe-out angle to fine tune it which supposively helped. I would like to do the same thing with mine using the exact same molds. *My Cirrus is a standard airworthiness certificate. *If I were to do the factory winglet or the Maughmer winglet, the cost is between 3,000-5,000 when it's all said and done. *So that being said, this option, looks very appealing. Has anyone in this group dealt with the same sort of deal? *I would be willing to change my standard airworthiness certificate over to an expiremental if that is the best solution. *Any guidance is much appreciated. Thanks, Scott PS Happy Thanksgiving. None of these winglets appear to have STCs so the installation in a type certificated glider will be via 337/field approval (I doubt you'll find an A&P who would claim adding a winglet is a "minor alteration" although there could be corner cases...). Since likely you need an A&P/IA to file a 337 and work with your local FSDO that is where I'd start. OTOH if you can get a pair of winglets for $3k out the door, all approved *properly, then I'd take that route. Darryl- Hide quoted text - - Show quoted text - Scott, Check with your FSDO on going from standard to experimental (exhibition & racing). I have done this twice. They will sak why and the reason is to add winglets that aren't available from the factory on your model sailplane. JJ |
Scott,
The 337 form can be sent in before the work begins. This allows for approval/disapproval before a saw is taken to the airplane. I imagine you will have to hire a DER (designated engineering representative) to do an engineering analysis to accompany the 337. Harold Kasola is very easy to work with and has Kasola Engineering in Albany, GA. A call to him would be worth the effort. Having just certified a club glider in experimental (last week), I can tell you it took a few days and a trip to the FSDO. |
On 11-21-2010 13:49, lanebush wrote:
Scott, The 337 form can be sent in before the work begins. This allows for approval/disapproval before a saw is taken to the airplane. I imagine you will have to hire a DER (designated engineering representative) to do an engineering analysis to accompany the 337. Harold Kasola is very easy to work with and has Kasola Engineering in Albany, GA. A call to him would be worth the effort. Having just certified a club glider in experimental (last week), I can tell you it took a few days and a trip to the FSDO. Cool! I would have thought a 337 would allow the glider to remain in the standard airworthiness class, if approved. On powered aircraft, I don't recall a 337 as changing them to experimental...and I would think it would be preferable to keep the glider in the standard class or it would have some sort of flight restrictions, wouldn't it? Scott |
337 has nothing to do with EXP/Std reg changeover. It is the number of the form that stands for "major repair or alteration" and is typically accompanied by a new weight and balance when major repairs (reattaching a tailboom for instance) or alterations (like winglets), although may not be necessarily in every case. My SZD59 is EXP reg, but I still went the 337 route when I modded my stock mechanical brakes to a hydraulic Cleveland setup. Didn't need the w&b for this job, since the part total was within 1.5lbs of the old setup and that is all predominantly on CofG, but I didn't trust my old one and wanted to put some weight in the tail, so a fresh w&b was useful to me to determine how much... And why exactly do you want to keep the std reg? Do you use it in a commercial capacity? (obviously not since it has 1 seat...) Exp rating allows you a lot more leeway with *legally getting your ship/cockpit dialed in etc. Work that falls somewhere between changing a tire and needing a 337 still needs to be signed off by an A&P, but a 337 needs an A&I and is much more involved. Std means anything beyond changing a tire/simple maintenance level work has to be farmed out to an A&P, regardless of your skills. -Paul |
On 11-21-2010 16:42, sisu1a wrote:
I don't recall a 337 as changing them to experimental... 337 has nothing to do with EXP/Std reg changeover. It is the number of the form that stands for "major repair or alteration" and is typically accompanied by a new weight and balance when major repairs (reattaching a tailboom for instance) or alterations (like winglets), although may not be necessarily in every case. My SZD59 is EXP reg, but I still went the 337 route when I modded my stock mechanical brakes to a hydraulic Cleveland setup. Didn't need the w&b for this job, since the part total was within 1.5lbs of the old setup and that is all predominantly on CofG, but I didn't trust my old one and wanted to put some weight in the tail, so a fresh w&b was useful to me to determine how much... And why exactly do you want to keep the std reg? Do you use it in a commercial capacity? (obviously not since it has 1 seat...) Exp rating allows you a lot more leeway with *legally getting your ship/cockpit dialed in etc. Work that falls somewhere between changing a tire and needing a 337 still needs to be signed off by an A&P, but a 337 needs an A&I and is much more involved. Std means anything beyond changing a tire/simple maintenance level work has to be farmed out to an A&P, regardless of your skills. -Paul Actually, I am not the one who started the thread about going into the experimental category. The reason "I" would stay in the standard category is to avoid any restrictions that may come with the experimental category, such as for exhibition only, etc. I'm pretty sure going to experimental would place various restrictions on the flying of the aircraft. Also, going to an experimental certificate won't eliminate the need for A&P inspections/sign offs. As far as I know, only people with repairman certificates can sign off work on an experimental "AMATEUR BUILT" aircraft and then only if they built a majority of the aircraft. Just putting winglets on a certified bird would not be a basis to get a repairman's certificate... |
On Nov 21, 10:12*am, Scott wrote:
On 11-21-2010 16:42, sisu1a wrote: * *I don't recall a 337 as changing them to experimental... 337 has nothing to do with EXP/Std reg changeover. It is the number of the form that stands for "major repair or alteration" and is typically accompanied by a new weight and balance when major repairs (reattaching a tailboom for instance) or alterations (like winglets), although may not be necessarily in every case. My SZD59 is EXP reg, but I still went the 337 route when I modded my stock mechanical brakes to a hydraulic Cleveland setup. Didn't need the w&b for this job, since the part total was within 1.5lbs of the old setup and that is all predominantly on CofG, but I didn't trust my old one and wanted to put some weight in the tail, so a fresh w&b was useful to me to determine how much... And why exactly do you want to keep the std reg? Do you use it in a commercial capacity? (obviously not since it has 1 seat...) Exp rating allows you a lot more leeway with *legally getting your ship/cockpit dialed in etc. Work that falls somewhere between changing a tire and needing a 337 still needs to be signed off by an A&P, but a 337 needs an A&I and is much more involved. Std means anything beyond changing a tire/simple maintenance level work has to be farmed out to an A&P, regardless of your skills. -Paul Actually, I am not the one who started the thread about going into the experimental category. *The reason "I" would stay in the standard category is to avoid any restrictions that may come with the experimental category, such as for exhibition only, etc. *I'm pretty sure going to experimental would place various restrictions on the flying of the aircraft. *Also, going to an experimental certificate won't eliminate the need for A&P inspections/sign offs. *As far as I know, only people with repairman certificates can sign off work on an experimental "AMATEUR BUILT" aircraft and then only if they built a majority of the aircraft. *Just putting winglets on a certified bird would not be a basis to get a repairman's certificate...- Hide quoted text - - Show quoted text - Scott, Any A&P can annual an Experimental or Experimental Exhibition aircraft. This is a lot easier formany people. Dan WO |
wrote: A friend in my club built a pair of winglets for his Standard Cirrus. His glider is expirmental, mine is not. *The total cost for him was just a hundred dollars for supplies, and some free guidance from a local IA/AP. *The finished product looks fantastic! *The mold came from an American Spirit, which I believe is a copy of the Ventus. *And the result is that his handling has improved quite a bit. *He did do some adjustments on the toe-out angle to fine tune it which supposively helped. I would like to do the same thing with mine using the exact same molds. *My Cirrus is a standard airworthiness certificate. *If I were to do the factory winglet or the Maughmer winglet, the cost is between 3,000-5,000 when it's all said and done. *So that being said, this option, looks very appealing. Has anyone in this group dealt with the same sort of deal? *I would be willing to change my standard airworthiness certificate over to an expiremental if that is the best solution. *Any guidance is much appreciated. Thanks, Scott PS Happy Thanksgiving. Hi, I'm curious, what kind of testing did your friend do to determine the tow angle needed tweaking? thanks, Brad |
| FAA Revoking Standard Airworthiness Certificate DG-505 | NG | Soaring | 32 | February 16th 17 03:23 PM |
| Airworthiness Certificate Replacement? | [email protected] | Soaring | 6 | June 26th 08 08:11 PM |
| USA Glider Experimental Airworthiness Certificate | charlie foxtrot | Soaring | 4 | April 15th 06 06:04 AM |
| Exhibition/Racing Airworthiness Certificate Question | bsquared | Soaring | 5 | June 22nd 04 07:24 PM |
| Airworthiness Directives for Jantar Standard 3 | Miguel Lavalle | Soaring | 5 | January 24th 04 11:55 AM |
